STW niche DE razor ...
[Closed] STW niche DE razor incident! First Aid advice.
7 Users
I have just sliced about 1mm of my finger tip off by digging around in my soap bag and using my Merkur razor as an upturned, extremely sharp, woodplane.
A tad sore.
Biggest problem is it won't stop bleeding. It's not a cut but a slice and is about 5mm2.
Any advice?
Posted : 05/09/2016 9:26 pm
Don't be tempted to eat salt n vinegar crisps.
Posted : 05/09/2016 9:30 pm
styptic block. And a broom handle to bite down on 🙂
(dont do this BTW)
ouch.
Not much useful advice. Id probably just hold some towel against it tight for a while and then dress it once the gusher had subsided.
Posted : 05/09/2016 9:31 pm
It will eventually. I took a bit off my finger the other day with a scalpel blade. Just kept holding kitchen roll on it and eventually it stopped. Your blood will do its thing given time.
Posted : 05/09/2016 9:56 pm
I did the same within very, very sharp knife. It'll grow back.
Keep it elevated and under some pressure. Be sure to release that every few minutes though. A plaster to keep it clean once it looks like clotting s bit.
Posted : 05/09/2016 10:01 pm
Are you asking for tips?
#badumtish
Posted : 05/09/2016 10:02 pm
Wrap it up & rest it on your shoulder. Luckily it was only a nic, sounds like you had a close shave.
Posted : 05/09/2016 10:05 pm
