Help this befuddled old man understand please
I am going to be traveling into places with no mobile signal on my own and have strongly been advised to get one of these for emergencies. I'm a bit of a tight fisted luddite so have no idea of what they are and how they work and resent spending the money. Help me out please.
We have a SPOT tracker. I can't remember the costs (maybe £18/month for the subscription?), but you buy it, and then you need a subscription to activate it. We start and stop the subscription to suit, eg if Mrs Yak has a bikepacking race then it's activated just for that month. You can choose how often it sends your location. Eg every 5mins, or much longer internals and then that will appear on the map that someone is following you on. There is a SOS button for emergencies too.
Garmin inreach is the other option, similarly needs a subscription.
Satellite tracking is coming to mobile phone,perhaps already for a few phones. I assume the cost is included in your contract. So if you can hold out for a while...
I had one a few years ago when I did a solo Munro round.
Then, it was limited to preconfigured 'I'm OK' messages to a preset list of contacts or a 'call the cavalry, I'm in the sh1t'!' message to Spot HQ. You pay for the unit and a subscription for monitoring. Tracking was an extra then and is similar to Garmin Livetrack but by satellite. IIRC, Spot is/was based in Houston and they contact the emergency services of the appropriate country on receipt of an alert.
Garmin have since released their In Reach products which are similar but reading the bumf, allow real time SMS if that's important to you. Big plus on the Spot I had was it took AA batteries which lasted an age. I'd imagine the In Reach is rechargeable.
If you don't need SMS or Tracking, look for an EPIRB instead. No subscription required and it'll scramble the equivalent of the big yellow taxi if you get in the doo doo.
I have the Spot X supplied by my employer for DOC on remote sites with no mobile signal. Also told I can use it outwith work.
The one I have is rechargeable and allows texts to be sent to any number.
It's not the most compact unit but I ain't gonna complain as it's free.
Yep, as @Yak says, you need a device and a subscription.firva tracker. You could buy a PLB which will work without but I guess you'd need to ensure it would work in the Antipodes. (Same us true of a tracker).
I have a, currently unused, Spot which you are welcome to borrow. It's a V3 so is configured with 4 buttons, 3 of which van send pre-programmed messages (such as "I'm fine) and the 4th is the SOS button that will alert the authorities.
A Tracking subscription is more expensive than a "messages only" subscription if you feel you want folk to know where you are without sending a message (all messages have GPS coordinates attached).Tracking also uses more battery.
My Spot uses 4 x AAAs. If not tracking, then when you want to send a message you'd need to power it on, wait for a satellite lock, and press the relevant button. If you're using tracking, that will consume battery power but you'll already have a satellite lock, so.less waiting time.
Oh, and you usually need clear line of sight to the sky/satellites. If you fall down a hole, are in a steep cleft or are being eaten by a tiger under jungle canopy, it might not connect, just like GPS...
Hmmm - ta folks. so you have to activate them if you are injured? No use if you are unconscious? Or I guess if they are tracking then someone could check and tell if you were not moving?
I don't particularly want or need the tracking - just a way of alerting the rescue services if I am stuck with no mobile reception
Garmin inReach Mini owner here. It won't trigger automatically if you fall (even though Garmin watches can set off their own alert via phone), but if you do pair it with a Fenix or Forerunner you will be able to manually activate it from the watch. Only situation I can think of where this might be useful is if your bag gets separated in an accident but is still within Bluetooth range.
I just use the belt clip, but it also has a carabiner attachment. I've come close to needing it once while running in a mountainous area. Depending on where you go it may be worth considering supplementary rescue insurance because I suspect the first thing to be lowered out of the helicopter in the USA will be a credit card machine.
It's a very useful thing to own, although not cheap from a subscription perspective. You're welcome to borrow mine if you only need it for a short period.
Epirb sounds like the cheapest option if you only want to issue a cry for help. But, sounds like tracking might be important if there's any chance you are if the sh1t and unconscious. Guess it depends who is tracking your activity and how well you communicate your routing if you don't have live tracking and anyone would know ish where to come looking
You can hire these, for example Track Trail will hire you a Garmin InReach for £45 a week. I've never actually used them but I looked into this a while back when planning a multi-day trip. The trip never happened as I twisted my knee while walking the dog.
Not quite the same, but newer iPhones can use the satphone network for messaging when out of tower range. I’d guess that combined with apple watch or garmin it could be set to auto alert if sudden stop detected.
https://support.apple.com/en-gb/120930
Yes, you need to activate manually unless being tracked. I'd be careful of false alarms here. You lost your Spot, broken it, lost signal, forgot to turn it off etc and someone tracking you has a fit and calls in International Rescue...
If you just want manually triggered emergency services activation at least cost, get an EPIRB (having made sure the satellites cover where you're going). If you want that plus bells, whistles, the ability to message all your friends ( 🙂 ) and tracking, get a free Spot on loan or an InReach if it has features important to you. Depending on trip length, the loan Spot plus sub may be cheaper than an EPIRB (£200-£300 last I looked). Of course you'll still have tge EPIRB at the end of the trip to sell on or keep come the Zombie apocalypse in Edinburgh... 🙂
I’ve been looking at this recently for my solo kayaking exploits off the west coast:
I had a Spot Gen3 for a few years until I gave up on Spot price-gouging me every year with the renewal - you have to phone them in the US threatening to shut your account before they offer a reasonable price. Subscription price is from £18/month. Used devices can be bought for £50.
Garmin offer the Inreach, some with better features but ‘usable’ subscriptions are about £32/month ie with decent tracking. Devices are better, some with built in GPS and mapping.
EPIRBs only work for emergencies, don’t offer tracking - cost about £300 and are sealed so expire when the battery runs out. No subscription needed.
iPhone from 14 onwards offer a sat phone connection capability through a subscription but not sure about availability in the UK
There are other devices but only available to US providers
You can hire devices from Globaltelsat but they cost about £9/day
Its a five month trip - 2 in NZ and 3 in Aus
Ta folks - I understand a bit more now - there is a possibility of hiring one in NZ I believe. Might be the best option as its the NZ leg that I really need it for - but only a few days / section of my trip
A few days? Yes, definitely hire one then. Will save lots of faff and cost. Have a good trip! 5months in NZ/Aus sounds great.
Ah - I am doing an 8 wk tour - but there are only a few sections each of only a day or twothat will be out of mobile reception but i would need to hire it for the full 8 weeks
Probably best/cheapest to borrow one then and pay for 2months subscription. Eg, take up Scotroutes offer and then it's from £16 for the 2 months.
Spot is standard for adventure moto riders. My in-laws have used them for over a decade on trips all over the world. Just back from Oman.
NZ for a bike ride then on to Aus
ta folks. I think I grasp what they are now
This Outdoor Gear Lab review might be helpful
https://www.outdoorgearlab.com/topics/camping-and-hiking/best-personal-locator-beacon
Yes, you need to activate manually unless being tracked. I’d be careful of false alarms here. You lost your Spot, broken it, lost signal, forgot to turn it off etc and someone tracking you has a fit and calls in International Rescue…
I know someone who left one in a hostel in the middle of nowhere as he wasn’t going to be doing anything risky when an earthquake struck. His contact back home was extremely concerned and he was so busy trying to help the locals he never even considered trying to get back to the hostel to send an “ok” message. A bit of an extreme example but NZ does get quakes, and they are the sort of thing that make traditional comms to say “tracking not moved is everything ok” impossible.
Arnt you going to new Zealand?
Where you going without signal. They had widespread signal 20 years ago.
We have a RescueMe Plb1
Paid about £180 although I am aware they have gone up since we got ours around 2020
It is tiny. It could be in your pocket and I doubt you'd really notice. It is easy to operate and test.
It's emergency only, no messaging. Madame and I discussed the options and concluded we didn't need messaging.
When it expires after 10 years I would buy another assuming nothing better has come along.
Garmin have recently made substantial changes to their Inreach subscription rates. It's now possible to get Inreach subscriptions from companies other than Garmin; you still use the Garmin Inreach device but pay the subs to the other company. I'm still investigating it but it may be more cost effective for occasional use.
This was a random YouTube video which popped into my feed which may be relevant to some. Near the end, he mentions that some of Garmin's cheaper subscriptions options are not published so require some clicking around to get the lower rates (though he is, I assume, US-based...)
Depending on what you are doing in NZ, I am not sure you will really need one, a bit of prior planning and informing accomodation in advance of route and expected arrival and you should be fine imo. You know, old school. If you are planning an unsupported week long trek then yes it would be good, otherwise, well I suppose it depends on your attitude to risk.
Might be the best option as its the NZ leg that I really need it for – but only a few days / section of my trip
One of the lads i used to work with if from that neck of the woods and does multi day enduro mx rides. Some of the stories of the weather and the environment (and the helicopter rides!) makes me think that a SPOT tracker for that bit would be a very, very good idea. Especially as he was riding 'local' trails.
https://www.theguardian.com/australia-news/2024/nov/23/leg-amputated-tasmania-rafting-franklin-river
I read this story and wonder how the smart watch made the call...not sufficiently up on what a smart watch can do these days........presumably his phone was nearby and it did the calling, triggered by the watch. And did the poor guy manually press something on the watch or did something about his movement (or lack of) initiate the call...
Whatever.....pretty grim story - trapped in the rapids for 20hrs and finally being freed minus your leg. Remarkable resilience though.
Another spot owner, but I went for annual sub to monthly recently and not had cause to trigger paying for a month (though there is an annual fee for having it in this dormant state). I've now gone to a RescueME plb1 for a daily carry on the surfski and inland WW or in the hills. Probably only flash the Spot up again when on multi days where its useful to be able send basic comms back home that every thing is fine.....or not. The ability to send non emergency service level 'emergency' messages to friends in the are who could come and help me or a message back that says I'm find but running late on schedule so don't panic messages is very useful.
Has anyone actually used one of the Smart Phone options? (just iPhone and Pixel options as far as I can tell)
I have an aging PLB, and a phone that got dropped badly, I really I just want something for single day runs, occasional overnight trips. Kinda feels like a basic in-phone option is a better choice if the risk of a dead battery is minimal.
Not sure I'd want to rely on random third party companies to monitor my emergency calls and act accordingly. At least SPOT and Garmin are well known in this area and have (apparently) good reputations.
I'd also not want to rely on phones. I also don't rely on them for nav or pics in the hills. I know it's probly a bit Grandad but I want to be able to navigate/photograph/talk/text without potentially compromising the other elements especially nav.
I've also no idea of how that man's smar****ch called the cavalry but the whole thing reminded me if 127 hours... Imagine being battered by white water for 20hrs then having your leg lopped off... Grim indeed.
Well, some valid points.
Although I dont use my phone for nav, it's just a phone and a camera, and phones are so good at dealing with water these days, a waterproof phone in a dry bag is nothing I'm concerned about.
And im certainly not replacing my PLB or buying a Spot tracker. I cant even remember the last time I bothered to pack it.
Might go take a look at how the software works and the data flows.
FWIW as I was planning to upgrade my Pixel 6 anyway, I considered the Pixel 9 Pro and having access to satellite comms was a potential benefit. However, it still requires a subscription (after a couple of months trial) and then there was still a question regarding the robustness of the phone.
I saved enough money by buying the Pixel 8 Pro instead that I could, should I wish, splash out on a subscription for the Spot I already own. I'd certainly be less worried about that coming to grief in a fall, river, etc. Not only is it a lot cheaper, it's also built to take a bit more rough handling.
My other option is to buy an Inreach Mini with the money I saved on the phone.
Stupid question - does location sharing via satellite on an e.g. iPhone 16 cost? And if so, how much?
I got an InReach mini in 2021 and use it about two weeks a year. I pay an annual subscription of not much (I'd have to look it up) and then Garmin enables the monthly subscription to stopped and started at will.So I fire it up every year as required and then cancel it when back from my trip, just paying for the one month.
So far only used it for basic tracking sharing and a preset morning/evening message.
Stupid question – does location sharing via satellite on an e.g. iPhone 16 cost? And if so, how much?
I'm not entirely sure, it looks like they give you two years for free on an iPhone if it is an option on that model, and appears to be Apple software rather than 3rd party.
Sadly, Garmin have discontinued that (the 'Freedom plan') for new activations and from the next annual renewal for existing plans. You can still deactivate when you're not using it, but it's £40 to re-activate it.
See https://www.garmin.com/en-GB/p/837461
You can also get subscriptions for using an Inreach from non-Garmin sources, such as https://www.protegear.de/en-gb which may be better value.
InReach Mini2 user here - had it a few years. Bought it after an outdoor first aid course kept on saying "you're a couple of hours away from the road / no phone signal and you find a casualty - what do you do?"
My answer when I requalify is "press the button"
The wife was doing a lot of ultra training, typically out in the middle of nowhere - I will routinely go out on my motorbike for the day "no idea where I am off to - will be back for tea" - the lad uses it now when he goes hill walking, so lots of opportunity to use it actively. Garmin plan is now £8 a month, 10p per tracking position sent - so a day out on the bike costs about £6 - if/when we are at busier times of the year then we take a more expensive plan from Garmin with more bells and whistles. Each to their own - the major benefit for me is that the Mrs can put the kettle on when I'm 10mins from home....
I’m not entirely sure, it looks like they give you two years for free on an iPhone if it is an option on that model, and appears to be Apple software rather than 3rd party.
When the emergency text facility was first introduced, it was free for the first two years of ownership of the phone. However, its now over two years of those original phones and so far Apple aren’t introducing any charges, and there’s no indication yet of them giving any date. Apple have just given another big cash donation for further expansion of the facility, and it’s been expanded to full messages instead of brief responses to given questions.
So far there’s been a number of reports of the system actually saving the lives of people in remote locations.
Sadly, Garmin have discontinued that (the ‘Freedom plan’)
@Greybeard, thanks for pointing that out, I hadn't noticed. I last used the subscription in August this year for our summer hols in the French Alps. Not sure what I paid at the time as it is all automated. No idea how it compares to other services now, but as I own the actual bit of kit, the start stop subscription still seems reasonable for peace of mind..
Cheers @Counzero
Having thought about this, I think I'm perfectly comfortable with a less robust device and a marginally increased level of risk over carrying a dedicated device which I currently dont carry anyway, and am perfectly comfortable with that and associated risks already.
So a phone with Satellite SOS would be a selling point between phones rather than a "I want to be able to make a Satellite SOS".
I'm also completely indifferent to the day today differences between Android and IOS. Although I do like being able to switch loads of stuff off with my current android via dev options.
According to locals the long distance offroad routes have lots of gaps.
maybe things have changed with the shutting down of the old technology . i guess we didnt need 4g to make a phonecall 20 years ago.
The long distance cycling offroad routes apparently have big gaps - you can be out of contact for a day or two. Local advice
As above. I am normally with you on this but several locals have said get one. However they do seem to have a very risk averse attitude
My feeling is given I will be on my own and thats the advice I have been given maybe it really would be a good idea to have one. I*'m not sure I would bother if I was with someone else.
Trailrat / AA
Apparently the long distance cycle routes I want to take have a few sections where you can be out of contact for a day or two. I have been advised by several locals t get one. I think the fact I will be on my own means that it probably tips over towards getting one.
The locals do seem very risk averse tho
FFS -single track hamster kept on throwing errors at me hence the multiple posts
Can we clarify what apple are offering
I think my iPhone 14 can summon help via satellite
i think in the USA it can message
I didn’t think it could do tracking via satellite any where
1. Looking forward to the pictures of your travels.
2. You would feel a fool no doubt if you'd been told about this, not taken the advice and found yourself in trouble.
3. "Take care of yourself" is probably the advice you'd give to someone else, doctor, heal thyself etc etc...
For the cost of renting, when compared to the cost of your tour in general, including flights, why wouldn't you?
Also - are you taking bike and trailer? I was wondering how much baggage costs for that would be.
Its like an insurance policy....you do not know if you will ever need it. My Spot helped keep my wife happy on my adventures for many years , esp big rides in winter in Scotland and thus money well spent! Also the fact that you can create a webpage and share with others is a good feature, esp if raising money for charity etc. and for big endurance events helps keep you going as you have the thought that people at home are watching! So thats a good thing too. I think the Spot is fairly robust too. But Tech has moved on a bit and mobile phone coverage is so much better now as well esp in UK . I just wished spot would reduce prices a bit as some other tech is a bit better now . Mine is currently not on subscription for this reason . I did also like to carry it switched off on shorter trips , but knowing that if I ever met a hiker or biker in trouble I could call in the cavalry to rescue them no matter what the mobile phone coverage.
