Community
Sorry... Excel Help...
[Closed] Sorry... Excel Help required
Hope someone can help me out here!
I need a lookup forumla that returns the value 2 rows below and 8 columns to the right of the lookup_value, so like a standard vlookup, that then drops 2 rows
Any ideas?
Posted : 05/11/2009 1:14 pm
offset function with vlookup maybe match as well
away from my desk right now. can help later if still stuck
Posted : 05/11/2009 1:18 pm
Copy column a, insert it into column a, insert 2 cells at the top of column a
Posted : 05/11/2009 1:28 pm
Yes, I had thought of that, but I have 8 rows to run the formula for and dont want to insert 8 columns then insert 1 to 8 rows at the top each time
Posted : 05/11/2009 1:42 pm
Assuming your lookup reference is unique, try:
=OFFSET($A$1, MATCH(A10, A1:A4)+1, 7, 1, 1)
where A1 is the top left hand corner of your table,
where A10 is the criteria you are looking up
where a1:a4 is the array that you are testing your lookup down
where +1 = 2 rows below
and 7 = 8 columns along
1, 1 just means bring back the contents of one cell.
Posted : 05/11/2009 3:45 pm
Brilliant, that works cheers
Posted : 05/11/2009 3:49 pm
