Solar water thermal...
[Closed] Solar water thermal panels: The installation... (w pics)
41 Users
following on from [url= http://www.singletrackworld.com/forum/topic/solar-water-heating ]this thread[/url]
[i]first of all a massive thanks to smudger666 for his offline help, edukator for his posts and especially globalti for directing me towards Peter at http://www.solarproject.co.uk/ [/i]
A local specifier quoted for installing an 80 x 58mm tube system that was MCS certified (i.e. eligable for RHI payments) and came out at a number around £7,000. By my financial calcs, even with the gov RHI payments, Id not see payback for the best part of 17 or 18 years at that kind of capital cost.
Following globalti's lead I got in touch with Peter at solar project and with some help from him and other sources have designed and acquired the parts to install a 60 x 58mm tube set up (that can be easily extended at £460 per 20 tubes) for just under £2,000. Even without the RHI payments I reckon my payback is going to be closer to 5-7yrs. It also reduces the amount of wood pellet fuel I need to lug about over the summer months.
The system is to augment this biomass boiler set up. Both the boiler and the Solar panels connect to this 700L thermal store where the energy is stored for use.
[img] https://lh5.googleusercontent.com/-OftbVOu-DiY/TgjoO9gtigI/AAAAAAAAAB4/ZYLl1KExXy0/s288/IMG_9923.JP G" target="_blank">https://lh5.googleusercontent.com/-OftbVOu-DiY/TgjoO9gtigI/AAAAAAAAAB4/ZYLl1KExXy0/s288/IMG_9923.JP G"/> [/img]
Over the last few days and the next few Im in the process of installing the system myself. If you're interested, I'll be posting pics and notes on the install in here when I come in for coffee breaks.
This is where the panels are going. On the ground in a special bed in the garden. I dont like water services in roof space. Being on the ground means I can clean, repair and service the panels more easily. The gravel bed can be sprayed for weed control.
[img] https://lh4.googleusercontent.com/-AcokOmGw__I/Tg2HjC7acdI/AAAAAAAAAIs/csvFfEiRwpw/s400/P1000931.JP G" target="_blank">https://lh4.googleusercontent.com/-AcokOmGw__I/Tg2HjC7acdI/AAAAAAAAAIs/csvFfEiRwpw/s400/P1000931.JP G"/> [/img]
the ducting you see there comes up back in the boiler room:
first problem was that the DN20mm insulated steel pipe would not pull through the 50mm conduit. My fault, I thought there'd be more clearance and since its been over 9 months since I laid the conduit its probable that the run isnt un-obstructed by compression of the conduit along its full length. So a lot of cursing, swearing and thinking later...
...I cut a new shallow trench in the veg garden gravel and across my nice new lawn within which to lay some more 50mm conduit, but this time through which Id already pulled the hose whilst above ground and dead straight. Of course, this also meant breaking into the boiler room wall again. Fortunately I still had a spare "Insuduct" lying around that was about to go on eBay. This makes for a nice breakthrough.
2x 17m runs of DN20 soalr hose:
[img] https://lh5.googleusercontent.com/-nPREFNV72kU/Tg2GVh1RVLI/AAAAAAAAAIE/6O1Gu_Q10S8/s400/P1000975.JP G" target="_blank">https://lh5.googleusercontent.com/-nPREFNV72kU/Tg2GVh1RVLI/AAAAAAAAAIE/6O1Gu_Q10S8/s400/P1000975.JP G"/> [/img]
Finished installing the conduit yesterday so could then crack on with the first frame/manifold assembly so that I could get the copper flow/return tails in the right spot. Just about to go back out and assemble the next two panels before getting on with the copper work in the boiler room.
Any questions Ill answer when I get back in in a few hours time. But take some time to have a look over Peter's site for more info.
Posted : 01/07/2011 8:50 am
harrumph.
I thought there were more forumites interested in this stuff than that 🙁
ah well. for any lurkers then:
two more panel racks & manifolds assembled and all of them joined together
Posted : 01/07/2011 10:57 am
I like what you're doing! I'm just about to remove an old Parkray boiler and replace it with a Stovax Stockton 8HB Boiler and reconnect it to our radiators!
I've had estimates from HETAS registered fitters and TBH they've not filled me with any confidence what so ever. In the I've gone with a local builder who isn't registered, but by using him I am saving way over the cost of getting building regs in (although that may cause problems in itself) and I feel a lot more confident in what he has explained to me.
Posted : 01/07/2011 11:28 am
Little concerned about the depth of that trench, take it the conduit is reenforced?
Posted : 01/07/2011 11:34 am
That is one big system!
Parents have just one panel and it already produces too much hot water for the house!
Make sure they are insured, they had a few crack over winter and had to make a claim.
Posted : 01/07/2011 11:38 am
I'll be interested to read when you've got some results to post. I'm 9° further south and my solar hot water heater works very well until about the end of October (which is when we fire up the wood burner for the first time) and from the end of March (which is when we last use the wood burner). The main problem in Winter is that I've got it a 30° from the horizontal (I could only get planning permission for integrating it into the roof), not great in the Winter but perfect in Summer.
You're near Worcester IIRC which means that in December the sun will be 90 - 52 - 23 = 15° degrees above the horizon at midday. I therefore reckon you've got the angle too shallow for optimum efficiency from October to March.
That area of panels would provide all your domestic hot water for the sunniest half of the year and I reckon you could boil the primary circuit unless you cover some of them in summer. People around here have to cover their panels when they go on holiday to prevent boiling.
I assume that all ball games are now banned in your garden!
Posted : 01/07/2011 11:39 am
harrumph.
I'm interested.
Posted : 01/07/2011 11:40 am
Wow. Impressed. My M&E colleagues have just specced a solar pre-heating system to accompany the air source heat pumps and under floor heating system, rainwater harvesting system and self contained packet sewage farm system for a project im running.
Whilst I don't have a clue how it all works, it sure sounds impressive, although having just opened the tender returns and found its £400k over the original budget estimate, the client suddenly thinks that BREEAM isnt so important afterall 😆
Posted : 01/07/2011 11:41 am
I'm interested. Keep on posting!
Posted : 01/07/2011 11:44 am
I would imagine that the water tube panels are pretty robust 🙂 Might be a different story with PV.
Posted : 01/07/2011 11:46 am
Looks like a great project!
If this ^^ is the case, how hard would it be to have the tubes on an adjustable 2-position frame that can be moved in the winter months to a more efficient position?
Posted : 01/07/2011 11:50 am
replacement tubes are only about £25 each, so not that worried about them nor about getting them insured separately.
its very unlikely that the system will boil the primary as there is over 900 litres of water to heat up first. That's over 100kwH of energy.
There's also a suppression system in the secondary circuit which kicks in at 95 degrees cooling down the thermal store.
Finally since Im using an unpressurised system, if the primary circuit were to overheat, it would simply boil out through the header tank. not the end of the world.
the trench is shallow but its located in a safe area. The conduit is twin wall poly, and robust enough to keep the insulated steel hose safe.
Strictly no cricket in the garden 😉
Edukator - the angle is interesting. Mine are somewhere between 35 and 40 and thats the frame setting. Im happy with them there for now. but will keep it under review.
I'm interested to see how well the insulation copes with keeping the water hot back to the boiler. 17M sounds a long way to me, not that I have any experience of building something like this - I'd just assumed the roof was the best place to avoid transmission losses and save a bit of space (not an issue for you it looks!)
Posted : 01/07/2011 11:53 am
stump - I was thinking about that, but since I have rigid connections between the panels and they weigh a fair bit, theres no way you could tilt all three of them simultaneously and not break something.
More use of flexible hose might solve the problem but I concluded that was probably too much faff.
Brassneck: Ill be able to check losses as I can simply measure the temp at the hot side of the indirect coil as it goes in to the thermal store and compare that with the return temp from the panel (there's a temperature probe port on the manifold)
as I said there's 13mm of insulation around the steel hose, then the twin wall poly conduit. And it's in the ground, nto the air. I think it'll hold up OK.
Posted : 01/07/2011 11:55 am
Pah! Computer controlled sun tracking array would have been the way to go 🙂
Posted : 01/07/2011 11:56 am
I was wondering if I could rig something up with old chainrings and bike chains....proper heath robinson 🙂
EDIT: righto, off to do some copperwork.
Posted : 01/07/2011 11:58 am
Looking at the set up you have, is the a way of jacking up the wood base at one side to change the angle? It could pivot around the front edge and the connections would stay in place.
Posted : 01/07/2011 12:17 pm
Tracking mechanisms are not financially worthwhile for solar PV, so trying to move around that size of kit would be mad. However, a few wooden wedges at the back of the wooden base would shift the angles nicely for optimal winter sun.
*What headset for slackening solar thermal panel angles?*
Posted : 01/07/2011 12:39 pm
Interesting stuff.
Posted : 01/07/2011 12:47 pm
jeez Ive got to practice my soldering! 😉
Like a silver bukkake flick....!
Anyway, manifolds all plumbed in. Some joints more passable than others. Wont know just how crap my soldering is until I fill it. Fortunately the system will never run above atmospheric pressure, so it may be sympathetic to my awful copperwork 🙄
Two kinds of insulation: El cheapo stuff on the cold side, uber-expensive armourflex stuff on the hot side.
Tomorrow it's into the boiler room to do a load of soldering and connect up all the gubbins. First a trip to Bradfords for a bit more 22mm though.
Auto air vent at the highest point of the circuit. Will also need to use a couple of manual vents in the boiler room for some local high points that will be unavoidably built into the loop.
my [i]best*[/i] joint!
* only one that doesnt look like gash...
Posted : 01/07/2011 3:49 pm
Might be talking to total pap but I think using standard pipe insulation for the return pipe is a mistake as you will loose excessive heat and the panel will be fed with cooler water resulting in a lower temp of hot water leaving the panels.
I might be talking total rubbish. Love the project, you are very well setup.
Posted : 01/07/2011 3:55 pm
Losses are greater at higher temperature.
I think the losses on the cold side of the panels will be minimal. If the return temp is high (and therefore making greater losses), however, then I will already have to have masses of hot water in the thermal store.
(i.e. in order for, say 50deg water to be returning to the panel, the water at the bottom of the 700L thermal store must be nearly 50degs which means there's loads of 50deg + water in the tank, so to lose further energy is not really a worry)
Posted : 01/07/2011 4:01 pm
a friend was recently in Cameroon building a slap-dash version of what you've got going.
a large blue plastic drum for the tank, a load of pipes welded up like yours that sit beneath glass in a wooden tray. the whole lot then got painted black and the drum insulated. the drum was refilled by a stopcock type vavle.
think it cost about US$ 60 and it provided enough hot water for the church kitchen where lots of villagers go to eat.
Posted : 01/07/2011 4:25 pm
BTW, this is the approx layout.
A tip I was given was having the fill loop come up from below so as to prevent thermal syphoning of hot water into the un-insulated header tank.
The other tip was to add an expansion feed. Im guessing because it wont have the head of water on it making a quieter expansion route. Also apparently a small pin hole in the last 90deg of the expansion feed above the header is recommended, again to stop "glugging" and "bubbling" of expansion flows.
Posted : 01/07/2011 4:57 pm
Your costs sound similar to my folks collectors. They have 5 in the conservatory roof.
Posted : 01/07/2011 5:12 pm
Looks good. Do you think that 5-7 years is an acceptable payback period (for the average man) for this type of project?
Posted : 01/07/2011 5:18 pm
I plan on staying in the barn for at least 15-20 yrs. The installation without substantial rework [i]could[/i] last for 15-20yrs.
Payback for me is the replacement energy for biomass fuel (at about 5p/kWh)
If I was using a less bunny-cuddly fuel, Id be morally even more incentivised by the system even though, oil, say is about the same price per kWh as my pellets.
Posted : 01/07/2011 5:22 pm
If you decided to sell, how much of a selling point do you think it would be?
Posted : 01/07/2011 5:29 pm
tricky to say.
You could put a figure on it based on savings compared to an oil system.
In theory I [i]could[/i] generate around 100kWh per annum per tube (i.e say, 6,000 kWh from those three panels).
In biomass fuel terms, that's around £300 in today's prices.
in perpetuity at, say 5% (multiple 20) then that's worth say 6k.
Its not something that I think will be explicit in a house price, more that it might attract a particular kind of buyer.
More attractive still is my SAP/environmental impact rating of the barn. oodles of insulation keeps the running costs down.
Posted : 01/07/2011 6:34 pm
Stoner, that's looking fabulous. I wish I had the energy (sic) to do something as ambitious. So when we're riding in the Malverns do we come round to your place for a long hot shower?
Posted : 01/07/2011 6:40 pm
for you, moses, there'd even be a bed.
Posted : 01/07/2011 6:41 pm
Thanks but no need- I'll be in the van.
I owe you a tour of that anyway.
Posted : 01/07/2011 6:44 pm
then invite yourself up for a stopover/beers and ride.
Posted : 01/07/2011 6:48 pm
A CH pump circulates water so fast that you'll have trouble measuring differences around the primary circuit. On a German friend's system about a degree and it's no guide to how much heat you are losing or where from. I've insulated pipes with a normal pipe wrap like in your photos with a sewage pipe diametre insulator over the top.
Posted : 01/07/2011 7:07 pm
Excellent - did you need planning permission for the array?
Posted : 01/07/2011 9:32 pm
I, as you know, am an idiot, and don't understand this at all. Can someone explain how it is work please, in very simple terms? Thankz.
Looks good though. Can I get a smaller version stick on my balcony annoy my neighbour?
My tomatoes are better than his, as my balcony gets more sun than his. This infuriates him, but pleases me immensely. 🙂
Posted : 01/07/2011 9:36 pm
The sun heats up water in the tubes in that rack thing. That warm water is then pumped through to heat a big tank inside Castle Stoner, which in turn is used to heat the water and the radiators - if he so chooses.
The big tank inside is also heated using a big **** off wood pellet boiler - quite handy in winter when there aint enough sunshine, sunshine.
Posted : 01/07/2011 9:47 pm
My dissertation was on the thermal performance characteristics of solar collecting water heaters. Looks like a decent system for the money you've paid.
Fred - you get systems that have water running through them and you also get systems that have some other fluids that contain corrosion inhibitors and antifreeze which use heat exchangers to move that heat to the water.
Posted : 01/07/2011 9:53 pm
Surrounded By Zulus - Member
My dissertation was on the thermal performance characteristics of solar collecting water heaters. Looks like a decent system for the moeny you've paid.
*falls over*
Posted : 01/07/2011 9:54 pm
Does it actually work then, I mean, I can't see the amount of sun we get in this country being sufficient to heat an entire house just from heating some pipes.
And there'd be even less in winter, when you'd need the heat. So you've got to then burn fuel?
I'm assuming it's more efficient than a 'normal' system, but I am ignorant of such new fangledness, and curious as to how it works and it's benefits. Does it really save a significant amount of energy and money over a conventional system? Plus, it seems to take up quite a bit of space, and require quite a lot of materials and equipment.
Posted : 01/07/2011 9:59 pm
It works pretty well. Energy from sunlight equates to 1kw/m^2 even in winter.
Posted : 01/07/2011 10:03 pm
Good for water heating for 2/3 of the year. Less useful for space heating.
Posted : 01/07/2011 10:06 pm
So about a tenner then?
Posted : 01/07/2011 10:10 pm
Aye, around a tenner. Then around £20, then around £50, then this time next year Rodney we'll be millionaires.
Posted : 01/07/2011 10:12 pm
1Kwh/m2 ain't much sweetpea, or you could educate me.
Posted : 01/07/2011 10:15 pm
Just stumbled across this thread and I'm mighty impressed; that's a hell of a big collector you've got there. I wouldn't worry about thermal losses, you've got excellent insulation and any thermal loss will be a tiny proportion of what you're collecting.
Latest on my own system is that I've fixed up a "dump" circuit to the main house cylinder downstairs with a neat little 12v diverter valve supplied by Peter at Solarproject. Just before this, in late April in really sunny weather we had our first boil, we got home from a day out and found the panel temp up to 108c, the pump had shut down and the cylinder top was at about 66c. It was completely un-dramatic, nothing happened and when the sun went down it all cooled down and went back to normal operation. Anyway now I've got the diverter set up we can send excess heat down and dump it into the main house cylinder if the attic cylinder is up to temperature. We have re-timed the boiler to come on at 7pm in order not to waste any of the excess energy.
Posted : 02/07/2011 7:23 am
It isn't a Kwh. When the sun is at 90 degrees to the surface of the earth and it is a clear day, the energy that strikes the surface of the earth is about 1000w per square metre. Using something like a solar thermal panel you can capture that free energy and use it to heat the water in your home. They are usually installed alongside another heat source as solar is 'as well as' and not 'instead of' in most places. Even in winter you can usually raise the water temperature a few degrees, so your other heat source doesn't have to raise the temperature as far to get it to a useful temperature, thus saving energy and therefore your cost.
So - once the panel is installed and working and other than maintenance, you have free energy.
Posted : 02/07/2011 7:35 am
looks good stoner, i live in worcs, would like to have a look at your system sometime ? thks
Posted : 02/07/2011 7:56 am
Archie - youd be welcome to. email in profile.
Im between malvern and upton.
global - because I have the suppression system in the boiler (linked to the store) I decided not to bother with a dump. For suppression a temperature sensor (95deg) opens a valve on a mains supply through an indirect coil. When it opens cold mains water runs though the coil extracting energy and runs out into a pan.
If I did need a dump, Ive got a spare control cable running from the boiler room to the UFH manifold & pump. On overheat I could just get the UFH pump to run and draw energy into the floor slab (1,500 sq ft of screed and limestone should take a fair bit! 😉 )
Interesting the differential of 108deg to 66deg in your tank on overheat. Is your pump running fast enough do you think?
Ive got to pop out and buy another length of 22mm. Then its on with some more spunky soldering.
Posted : 02/07/2011 8:32 am
 Olly
aprooval here. nice work.
Posted : 02/07/2011 9:56 am
<pedant>Free other than the cost of the pump / controller / valve electricity.</pedant>
I'm tempted by this - roof of the garage looks like a good location for the panels, back of the garage for heat store. It'd be good to get it working as a thermo-syphon to the main hot water cylinder - just wondering what size pipes I'd have to run? 3/4 inch seemed to be the size when I ripped out a back boiler 25 years ago.
Posted : 02/07/2011 10:52 am
Murray - the bit I wasnt able to do on my own when specifying was work out what size pipe to use.
For a single panel with not too long runs Peter sells a 12mm silicon hose.
He and others suggested I use 15mm given my runs. I decided to go all the way to 20mm (DN20) steel hose so that if I ever wanted to add another 40 tubes to mine (making 100 in total) Id have the flow rate. The copper work is all in 22mm (except for the header feeds) as the coil is 22mm and it makes sense to maintain the same bore throughout.
Posted : 02/07/2011 12:08 pm
BTW, re "free", it's a very good point. Its also why I dont favour heat source pumps as you are still pegged to electricity prices, although at a factor of between 2 and 3 to 1.
In this case, the pump will be run at position 1 which draws 35W.
coincidentally, a tube on average over the year yields about 35W.
So one tube per year replaces the energy that the electrical pump is consuming. The other 59 tubes are all mine 😉
Posted : 02/07/2011 12:13 pm
very slow business this soldering lark.
Not going to win any beauty pageants but Im getting better at it and they're water tight too.
Tails from where the DN20 hose comes into the boiler room. Bleeder's on top.
Posted : 02/07/2011 1:48 pm
Elfinsafety - Member
It's not really to heat the house its primary use is to heat the water.
Posted : 02/07/2011 1:55 pm
It's not really* to heat the house its primary use is to heat the water.
* although a substantially sized collector and large enough thermal store can have a measurable impact on the amount of fuel you need in winter. But as brick says, primary use is DHW.
Its not air temperature that youre using remember, but insolation.
Direct and diffuse insolation over the year. (@Dublin)
Link: http://www.solarbook.co.uk/solar-insolation.html
Posted : 03/07/2011 10:11 am
If it's not for heating the house what heating do you have and are you going to install under floor heating as that runs off hot water ?? I'm all for what you are doing as I think it's great, it's lucky ghat you know you can stay in the one house for such a long time.
Posted : 03/07/2011 1:12 pm
It is for heating the house to some extent as above.
The house has UFH throughout downstairs - water drawn from the middle of the thermal store (40-60degs) and mixed with return water to get to 40deg. With additional space heating from a log burner. Upstairs are low vol al radiators controlled by a separate controller and pump from the boiler tank and served at boiler temp (65-85deg) and individual thermostatic valves control room temps.
Posted : 03/07/2011 3:46 pm
Do you need such a high boiler temperature, Stoner? Before I replaced it with a wood burner I experimented with different combi-boiler temperatures. With the thermostat clicking on at 33° the radiators were plenty hot enough to reach 18° + with negative temperatures outside. The lower the temperature the more efficient the boiler and the lower the losses. The lower temperature also meant that the temperature in the house was more stable as the thermostat had time to react and no longer allowed an overshoot.
My friend that uses underfloor heating fed by a heat pump uses 25°C water.
Posted : 03/07/2011 6:15 pm
Don Simon - I dont get your comment. What are you trying to say?
Posted : 03/07/2011 6:18 pm
edukator - the difference in our approaches is the use of the thermal store and biomass. The boiler raises the store top temp to 85deg from 65deg (switch on) to maximise efficiency of generation (biomass cycling is inefficient, combis are efficient when cycling). The store is substantially insulated to minimise high temp losses.
And just realised there's a thermo mixer on the boiler that mixes flow and return to rads to bring temp down from system temp. Prob closer to 50-60deg.
I reckon 25deg water in UFH is too low in mid winter. Mine's set for 35-40deg but the room thermo is set at 17.5-18.5deg
EDIT: also 25deg might be all he can get from the heat pump anyway and so uses that temp by default.
Also I dont see the point of running a pump continuously (c100W on pos 3) for UFH.
Posted : 03/07/2011 6:29 pm
PLEASE use the thicker pipe insulation you should make sure the corners are covered 100% and that auto vent is toooo exposed
Posted : 03/07/2011 6:44 pm
Explanation understood.
The temperature needed depends on how well the house is insulated, in his case 25°C water is fine. The whole heat pump assembly is inside the house so energy used by pumps isn't lost. It's an impressive system that takes heat from the ground (about 10°C in winter) and is about 450% efficient. Expensive though, over 15 000e several years back.
Posted : 03/07/2011 6:49 pm
ts - that thinner insulation is on the cold side.
exposed vent is something I do need to look at though def.
Posted : 03/07/2011 7:12 pm
450% efficient.
really? Ive not heard of GSHP getting better than a COP of 3.
Our barn is v well insulated (pleasure of converting an old building under modern regs). The 40deg is needed because it's feeding 6 zones, 1,500 sq ft or about 500 metres of UFH pipe. Much less than that and it wouldnt deliver enough energy into the floor slab I reckon.
Posted : 03/07/2011 7:15 pm
Yup really. It's what he claimed and having quickly checked a few sites it's an entirely plausible figure for an efficient heat pump that only needs to raise the temperature of the water from 10° to 25°. Do a bit of Goggling and you'll find COPs of up to 4.5 are often quoted.
I had a quote done for a 12 000e system that claimed 4 if I wanted 35°C water and drilled vertically to find ground temperatures of around 12°C. the idea at the time was a straight replacement for the central heating boiler but in the end I opted for the wood burner.
Posted : 03/07/2011 7:36 pm
pump & heat transfer tech must have come on a bit since I was looking at them then.
Since GSH can only ever augment an alternative energy source do you think COP of 4.5 all year is high enough when you can get much higher COP equivalent with solar thermal in summer and just higher during spring/autumn?
Posted : 03/07/2011 7:40 pm
[url= http://solaire2000.pagesperso-orange.fr/FAQ/FAQ_CHAUF_HAB/GEOTHERMIE.htm ]This site is interesting[/url] because it make the point that there's no point having a system with a COP of less than 3.3 as you'd be less efficient using electricity generated with fossil fuels to power your heat pump than burning the fossil fuel yourself at home.
Posted : 03/07/2011 7:41 pm
Ed can you translate this for me please?
ou d'un forage sur nappe phréatique)
Posted : 03/07/2011 7:43 pm
That site doesnt actually say why 3.3 is the minimum...does it?
In order for that figure to be right, doesnt it mean that distribution losses and generation inefficiency of carbon elec gen would have to be 1-(1/3.3)?
Posted : 03/07/2011 7:46 pm
...and...anyway, Im talking fincancial efficiency, not bunnyhugging!
Posted : 03/07/2011 7:47 pm
No need to wink, I agree entirely. Everything I've done so far will pay for itself within 12 years. Some of the initial insulating paid for itself in four or five years though the stuff I'm doing now will only save me sweat chopping wood. The wood burner will pay for itself in six years (including the cost of a chainsaw and other tools) though it would have been nearer 15 years if I bought chopped wood. The PV is on target for 6.5 years and the solar thermal will be 11 or 12 years. Even a more efficient oven will pay for itself in about 10 years.
Edit and the translation: "drilling into ground water (the aquifer)". Quite easy where I live, the neighbour has a well with water at 3m.
Posted : 03/07/2011 8:04 pm
nicely planned out.
Its hard sometimes to justify incremental capital cost.
For example my Biomass boiler is £10k compared to say, £3k for an oil set up.
Solar thermal is £2k
Log burner for £1.6k (including new flue)
So £10.6k incremental capital cost to try and recover in savings...
From my SAP DER
My DHW requirement is c. 6,000 kWh
Heating of 18,800 kWh
the TER is 7,500 kWh and 23,000 kWh respectively so my insulation already makes an impact
Ive still got to knock out c.25,000 kWh a year for this house but even at oil price of 5p/kWh that's only £1,250. Hard to make much savings from that to pay back £10k+ unless oil inflation really gets going.
Posted : 03/07/2011 8:17 pm
PV will be my next experiment. Need to have a good look at FIT vs capex.
Posted : 03/07/2011 8:18 pm
This house is much smaller, the ground floor is only 68m2 and there's no need to heat the loft. The previous owner (two people) was getting through 2000kWh of electricity and over 1000m3 of gas (about 1300e worth at current prices). We got down to 2200kWh of elec and 230m3 of gas before fitting the wood burner. We now use 2200kWh of elec and 5000kWh of wood (a lot more than we were using in gas). :-/ Something to do with three of us and especially madame taking delight in throwing on logs and feeling no guilty conscience.
Edit: The PV produces 3300kWh a year so we have a net production of 1100kWh.
Posted : 03/07/2011 8:38 pm
I think we're closer to 3,000 kWh of elec a year based on last 3m readings, but then we work from home.
How do you calculate your wood kWh?
Posted : 03/07/2011 8:48 pm
[url= http://www.crpf-limousin.com/france/fiche603-unites-mesures-bois-energie.php?quest=444 ]Three and a bit "steres" of poor quality wood is about 5000kWh[/url]
Posted : 03/07/2011 8:51 pm
Interesting measurement:
Un stère correspond à un m3 d’encombrement, soit à un cube d’un mètre de coté (bois + air). Mais en matière de pouvoir calorifique, un stère de bois frais de bouleau n’a rien à voir avec un stère de charme sec.
check this out too:
http://www.cosi.co.uk/Logs%20for%20sale.htm
Posted : 03/07/2011 8:55 pm
