Solar Powered Pump ...
[Closed] Solar Powered Pump trackworld
6 Users
In expectation of another blistering summer... I'm thinking of pumping water from a stream in our garden to water the veg beds.
I naively assume I could bodge a hosepipe onto a £50 solar powered pond pump, to fill a water butt.
Would need to lift water about 3 to 4 metres.
Any recommendations? Or advice on what power pump I would need please?
House deeds say that we have the right to take the water. Am not planning on creating a water feature or anything very thirsty. Our part of the country does not exactly suffer droughts regularly.
The previous house owners installed a water meter, and cut it off from the local spring source. Thanks for that.
Posted : 14/04/2021 8:57 pm
*off piste
What sort of drop do you have in the stream, ie any small waterfalls or lips etc.
If so check out a homemade hydraulic ram pump, using only some copper plumbing fittings, pipe and 2l coke bottle I was able to use a the drop of a 3ft high garden wall to pump water above a 2 storey house using only the water flow from the wall itself. (Invented/discovered by the Montgolfier brothers , as in ballon pioneers)
I just followed a simple diy plan on tinternet, and got all the bits from b&q, can’t find the example I followed many years ago, but an example below
*it seems you need a min drop of a foot to get one to work
https://lackancottage.co.uk/building-and-installing-a-ram-pump/
Posted : 14/04/2021 10:07 pm
Thanks Towzer 👍
Ram Pumps are really interesting techbology. I did consider them but thought our gradient was inadequate.
But it sounds like our 'drop' is about the same as yours. So mmaybe I'll give it a try. If I get around to it...
Thanks for the history facts too.
Posted : 14/04/2021 11:44 pm
There's probably and obvious answer (like my garden is above the house) but is the 'usual' filling the water but from a drainpipe not simpler? We have them on all corners of the house (and the garage and the greenhouse) and I use a pump and hose to move water to where it is most needed.
Also be aware that in theory taking water from a stream needs a licence. Won't matter for a bit of gardening but if you were setting up a larger irrigation system or household water use it might be required.
Posted : 15/04/2021 11:44 am
You only need a licence for more than 20m3 a day. That's a lot of water - certainly more than OP will need for his veg beds.
Posted : 15/04/2021 2:36 pm
 irc
Why not something like this. Pumps up to 16ft height.
https://www.amazon.co.uk/Umi-Essentials-Submersible-Oil-Filled-Structure/dp/B07VN3KVL4/ref=psdc_1939518031_t3_B08HH7C3CL
Posted : 15/04/2021 6:03 pm
Well that confused me. Wasn't sure what aspect of a pump track could be solar powered!
Posted : 15/04/2021 6:04 pm
