Snapped glasses arm...
[Closed] Snapped glasses arm repair
11 Users
Managed to snap the arm on my very old pair of oakleys, can't get a replacement so looking to fix.
Just glueing has never worked, was thinking a bit of prepreg carbon fibre might do the trick?
Any idea where I might get that as I wouldn't be needing large sheets of the stuff?
Posted : 08/10/2015 11:13 am
Could you disassemble some cheap shades and fit to existing Oakley hinges ?
Posted : 08/10/2015 11:21 am
Elastoplast surely?
Posted : 08/10/2015 12:18 pm
If they're plastic then drill some small holes in each bit of the broken arm and insert piano type wire into them and glue. The wire reinforces the glued joint.
Posted : 08/10/2015 12:20 pm
Fixed glass arms before with sugru
https://sugru.com/
Posted : 08/10/2015 12:23 pm
Where on the arm is the snap?
When I've done what wwaswas says I've also wrapped the join very tightly in cotton thread soaked in superglue as another reinforcement.
Posted : 08/10/2015 12:24 pm
How about some araldite and shrink wrap over the top?
A colleague has just done this to his regular glasses and seems to be holding fine.
Posted : 08/10/2015 12:28 pm
A few years back I snapped the arm off a pair of M Frames (the non hinged version).
I tried gluing it, which failed, then tried clipping some of the plastic of the ends of the arms and melting it with a soldering iron all around the break. This lasted for a little while but ultimately failed.
After all this faffing and butchering I rang Oakley UK and explained what I had done. I was originally inquiring whether I could just buy the frame but they said to send it back and they would provide a 'crash replacement' for £10. This is despite the mess I had made trying to repair them. All I needed was the original receipt, which thankfully I had.
It's worth asking them for a replacement?
Posted : 08/10/2015 12:35 pm
Do Oakley not warranty this sort of thing?
Posted : 08/10/2015 12:38 pm
[img] ?w=300&q=85&auto=format&sharp=10&s=5fbfbbc53567bff0be4fccfac0a1c1b0[/img]
Posted : 08/10/2015 12:42 pm
It's not a warranty issue if you've broken them and they're really old, but they might do a 'crash replacement' thing.
Posted : 08/10/2015 12:52 pm
What frame?
Posted : 08/10/2015 2:05 pm
It's the original fives from late 90s. Contacted Oakley who don't have and spares and they offered me 20% of a new other pair.
Tried gluing and adding extra support, doesn't hold for long as it's broken about 2/3 down the arm
Posted : 08/10/2015 6:00 pm
