Sky Router Wireless...
[Closed] Sky Router Wireless Speed slow
5 Users
I have recently updated to fibre
With the ethernet cable attached I am getting about 38 mbps.
Through wireless it ranges from about 8 to 26 mbps. This varies what appears to be randomly. Currently its at about 10mbps.
I have tried changing channels, some make it worse. 'Auto' appears best.
Any ideas what else I can do?
Ta
Posted : 06/01/2015 9:19 pm
Try changing the encryption type to AES if it is TKIP if this is a modern wireless box. You've tried the standard things and the channel is usually the problem but as that hasn't worked I have found that TKIP is very occasionally the problem
Posted : 06/01/2015 9:28 pm
Have you tried switching it off and back on again?
Is it a new router? Could be broken, ring the provider?
Posted : 06/01/2015 9:30 pm
The routers are rubbish and if you ring sky they'll tell you to test the speed on the cable as they don't guarantee speeds on the wifi.
I replaced mine with an Asus touter that does faster speeds on the wifi.
Posted : 06/01/2015 9:45 pm
What are you connecting from ? does it support 'n' ?
Posted : 06/01/2015 9:46 pm
Ah, I missed that it was Sky. They'll probably tell you that it's your fault for not using a yellow cable.
