I can't afford to pay out for Sky Multi room and was wondering what the options are to be able to watch Sky in more than one room?
Am I right in thinking that you have to watch the same thing in every room?
I have seen two options; a video sender, or coax from the Sky + Box and a Magic Eye. Any advice, experience using them and or alternatives?
What would be the point in that? 😕
would SKY in the living room (main TV) and freeview in the others not do?
If you wanted to watch TV in bed, rather than downstairs in the lounge.
Depends what channels you're after I suppose.
It's called Sky Multi room.
Thanks Jon, it's for when I am not in the lounge, i.e. in bed, or on the rollers in the spare room.
Coax from the 2nd coax socket is the most robust method
There's ways around the multi-room charges but you still need to invest in kit
I've used coax to each room with a sender unit in the roof and it works great. Yes all the telly are being sent the same picture, but would work great for your requirements.
Our Sky box is 'attached' to a plasma which has built in freeview, so if the girls want to watch Hanna 'bloody' Montana they can go into another room while the 'grown-ups' watch something boring via freeview.
Shark Bait, how have you done that? One coax feed from the Sky box going into the roof and into a sender (booster/splitter I presume?) and then feeds going into each room?
Thats what I have
Only prob is depending on the splitter / booster your magic eye probably wont work
Seems to work better too if the coax from sky to splitter is a s short as poss and good quality connections
Was thinking of multiroom (or main TV is now in the back extension and its HD) does anyone know if they will install without a phone connection to the box, its not possible to run a phone cable due to wooden floors, fireplaces and not wanting to mess up decor?
Sky website says both must be connected to a phone line, obviously once its in I would poss disconnect it anyway but would they even install without?
It should work fine, make sure you've switched the 12V DC output on for RF2
Anyway - these work well for what the OP wants
http://www.bitzshop.co.uk/acatalog/Amps___Splitters.html
They will but you'll have to buy an unsubsidised box - which makes it quite expensive
Better off buying a second hand one & taking a card only deal
I got a video sender thing from Maplin for £40, plug one into the Sky box, the other into the second TV, it works perfectly, includes an IR thingy so the remote works in either room.
Sky are c*&ts btw. I ordered Multiroom when it was free, but they "forgot" to include it in my order!
So anyway, what we have now, is a Sky box connected in another room, with a unregistered (purchased for £20 or £30 from Sky) viewing card, which gives channels 1-4 and nothing else.
It's connected to the satellite dish and not the aerial, so can't get any freeview channels.
The phone and satellite cables are run around the outside of the house, so as not to wreck decor.
I guess we'd have to subscribe again to get the other Sky Channels, but can't be bothered.
DezB - just buy a cheapy Freesat box & connect that to it
wireless video senders are great, get one with the highest frequency
Yep, exactly that. I use one of [url= http://www.tvlink.co.uk/acatalog/tvLINK_Amplifiers.html ]these [/url]distribution units with the magic eye and have not had a single problem in 8 years.
I put in the video sender from Maplin too, watch which one as the cheaper ones conflict with wireless... as I found out.
Need another Sky remote too.
Great if the main telly is been used for xbox/dvd etc, then have full sky functionality upstairs for no extra monthly cost.
[i] just buy a cheapy Freesat box & connect that to it[/i]
Cheers, uplink. Will look into that.
Speak to Ton - he works for a wholesaler
Thanks, lots of good tips there.
