Of course it does presume common-sense in the first place.only asks "are you sure?" when trying to step outside a few common-sense parameters.
A masterpiece of trolling SFB..
not really. just somebody who was offered advice from various users who use the software without issue every day.
but despite all this advice has decided that everyone else is wrong and he is right.
but then nobody ever changes their mind because of an internet forum 'discussion', as i'm still 100% certain that i'm correctly using a very capable well developed piece of software.
Blimey, you're right!
I used to niavely think they did, but you've just convinced me otherwise. 😀
I have done. I've learned stuff which I didn't know before, and been educated and enlightened.
A masterpiece of trolling SFB...
on a point of information, just because someone disagrees with you, that doesn't make them a troll. I believe what I'm saying, and I have a professional interest in program design.
It doesn't tell, it asks me what I want to do. It trusts my judgement.
right up to the point where you try to close a file, when it suddenly assumes (as do most editors) that you have decided to abandon your edit and discard all the changes you have made, but then pops up a stupid dialog to ask if you really meant it. In fact is should carefully and silently save all your work unless you click a thing saying "Throw all changes away I've changed my mind" - with me this would be about once a month.
You may be a programmer, but airing your view that PS is poor software design anywhere - and I mean anywhere - and you will get laughed out of there.
you are sadly mistaken if you think programmers talk to each other, except perhaps in expletives, though why I should be concerned about being laughed at I don't know :o)
God knows why I am sticking up for it. Adobe certainly doesn't need me to do that.
yes, I wondered that!
the advice was a ludicrously complicated workaround. I don't expect to have to pay through the nose for software which then needs to be customised to perform simple functions
Don't use adjustment layers, the whole point of them is that you can tweak them later rather than commit. If you then want to save as jpeg you have to flatten them before it can save as a jpeg.
So just use normal adjustments (Image > Adjustments) and you shouldn't be bothered with having to go through the save prompt.
If you don't want to use a PSD fine, but don't expect to be able to use all of Photoshops features properly. It's like you're saying photoshop sucks because jpegs don't support all the lovely tools they've created.
I can't believe you're still going! Can't you see you're only half doing it right? If you use layers you are making something other than a jpg, so you then have to build a jpg again.
You [i]can[/i] do all of the alterations you described the quick way, [i]and re-save the jpg just exactly as you want to do[/i]. Its just that you don't know how to, or a are being willfully stupid.
Don't know how much more simple it could possibly be. It only appears to not work in a simple way because you are doing it wrong! If you want to edit a jpg and do a straight save then don't put non-jpg features (layers) into it.
you really meant
It doesn't "assume" anything. By choosing to save the file as a 8-bit single layer JPG, rather than the standard multi-layer PSD you have EXPLICITLY told it that you would like to flatten and commit all your changes into a new file type.
about once a month.
The point of non-destructive editing is not just that you can throw ALL your changes away and get back to the original image, but that you can tweak the changes you have already made:
eg you might take an image, do a normal capture unsharp mask, fix the white balance, adjust the levels, straighten and crop it, convert to sRGB, do output sharpening save and print it.
If you then decide that the resulting image is still a little cool then you can re-open it, alter the white balance in your second step and leave the rest as they are.
A great trick is to use layers to do High-Pass sharpening and localised contrast. Means building one or two new layers, and takes time to learn, but its a really powerful move once you've got used to it. Naturally, you can write an action to create the necessary additional layers and set them up with a good first guess for settings.
I'm going to try a nice software metaphor:
Start Microsoft Word
Open a plain text document
Make some text bold, add some headings and a diagram
Now try saving it back as a plain text diagram...
Stupid Word complains. Says it will throw away my formatting if I save as plain text. That's ridiculous eh? 🙄
"simple functions" this is why you don't need photoshop.
there must be other software out there to do the basic tasks you require?
One more go, for the hard of understanding:
Open your pic.
Rotate canvas (image menu).
Adjust Levels if desired (shortcut is L)
Adjust curves if desired (M)
(Or, if that is too confusing use one of the other contrast adjustment tools, they all are different ways of doing the same thing)
Are you sure you like it?
Save (S)
Until you close the file the History line lets you undo anything you like.
And if that is all your doing then as MrsMith says, you are wasting your money on full Photoshop. Try paint.net, Elements, Paint Shop Pro, Gimp - all of which are free or considerably cheaper.
Or use CaptureNX which is hundreds of pounds cheaper and (IMO) has better support for that kind of basic non-destructive editting of Nikon NEFs.
Ha! Programmer meets end user!... Irresistable force meets an immovable object! A very good friend of mine, and veteran fellow photoshop user of several years summed this up perfectly using the following acronym....
"Its a PICNIC error, Problem In Chair, Not In Computer! "
Also called a PEBCAK:
"Problem Exists Between Chair And Keyboard"
Has he left the room?
"Stands up & punches the air"
I open a .psd and select "save for web..." and get:
[img]
[/img]
on a machine with at least 2GB free (bearing in mind Photoshop is using 900MB to edit a single image). No link to help to explain what this means or how to fix the problem, no tick box to say "don't show me this again"
so then I close the file, having only saved a reduced jpg version, and it says "do you want to save your changes ?". But I haven't made any changes, so it isn't protecting me from anything, just some lazy programmer seems to have assumed that [b]any[/b] action modifies the .psd. I checked and it doesn't even save the reduced size I used, so if I go back and try again it has jumped to full size again 🙁
What are the pixel dimensions of your image?
The warning pictured has nothing to do with computer performance - and everything to do with a sense of propriety and respect for web audiences/bandwidth.
4288x2848 like every other shot from my camera
but at the time the warning is displayed it does not know the final size because it hasn't given me the opportunity to tell it, unless you think it is able to anticipate my choice using telepathy ? FYI it always assumes full size...
"4288" har-de-har.
No. Save for web is not a tool to alter the pixel dimensions of an image. As I said before, it's an optimisation tool, allowing fine control over compression settings and colour palette.
What size is your screen? I would guess perhaps 1024 x 768 pixels?... then why in the name of f00k would you -or anyone else - want to look at an image on a website where you could only see 1/16th of the content at any given time?
Think about it. No, really... THINK. Please.
so why does it contain boxes to specify the dimensions? And surely since most web images will be smaller than the original, it should ? I draw your attention to the boxes bottom right which allow choice of dimensions and compression method - are these just to kid novices to the program ?
[img]
[/img]
1920x1200
indeed not, which is why one normally reduces the size...
My mistake. I don't have CS5. Must be a new feature.
Novices such as myself are obviously lagging far behind. There is nothing I can possible teach you.
Good luck with everything. Toodle-oo.
it goes back to CS3...
It does seem odd that it complains about memory. I agree that it shouldn't be an issue.
My best guess is that the Save For Web thing might be written as some kind of plug-in and may not have access to all the working memory pool that Photoshop uses so may genuinely run low on the memory it can access.
Or maybe it's just a bug? Possibly left in from when you had to resize before doing the Save For Wen thing.
except an actual plugin can load a 14761 x 2366 panorama without complaint ?
i would have thought that 'save for web' would be sRGB (or untagged) and have a different compression logarithm optimised towards smaller file size and smaller image dimensions.
if you wanted to make an image smaller you would re-size the image (apple>shift>I) and choose the resolution/dimensions/DPI/sampling method etc.
this would leave your profile intact and be re-editable by using history/snapshot or just saving a copy.
no idea about the memory error, get a programmer who knows about computers to sort it out.
so you mean I should ignore the tool designed for the job and do it a different way ?
that's not how it works, the Adobe programmers have to fix it.
A quick Google on the Adibe forums seems to suggest that the warning appears when the image is over 3374 x 2241 pixels.
http://forums.adobe.com/thread/369681
I guess the Save For Web thing does have a 4-up display so it may theoretically need 4 times the memory of the main image.
But I still can't see any good reason for that dialog on a machine with plenty of RAM.
yeah, thanks for the link, it looks as if it may be a hangover from previous days when images that size were too big to handle, but is symptomatic of inadequate testing if it's been left in.
Of course, that doesn't address the fact that using the tool makes PS think the original has been changed...
Another question, how do I create my own toolbars to perform custom functions ?
possibly yes. photoshop offers different ways to do similar things.
i can think of 4 different ways to sharpen an image, none of them is the 'correct' way but all have their uses and advantages.
the save for web facility is just one interpretation of saving a jpeg for web use. that interpretation of what constitutes a web jpeg may not be what other people want.
(personally i want to control the sharpening and resampling method when making small jpegs from large files as they can get too sharp/brittle looking with some subjects)
Jeez - colour balance ?? The tool applies to shadows, midtones or highlights, with no option to select all at once. And it's not calibrated in colour temperature, and there's no button to reset to original 🙁 I'm partially colourblind, but I can usually drag a single slider to get the colours about right, but THREE of them ??
I wrote an app once that did this as its default action. USers ****n hated it and after what i would consider hate mail i changed it back to what they 'expected'
Oh crap I seem to have just agreed with Sfb. Bugger. 😆
You generally do the white balance thing during conversion from RAW/NEF, where it will be labelled in temperature.
Doing it after the fact to a JPG isn't really the same thing at all.
What manual/tutorial for a partially colourblind engineer who wants to redesign the interface of the most popular image manipulation program? 😉 🙂
This might not be correct. but isnt the compression settings from save for web stored in the psd, so by altering the settings in save for web, youll need to resave the psd or discard the settings.
Those 3 different colour balance settings are for fine tuning, try variations or auto color instead.
own customised toolbar 😯 , not sure Ive been using the one provided by adobe since 1992.
An image that size will slow the computer down when saving for web, 2gb ram aint much when processing a 950mb image, save for web is effectively taking a huge 300dpi raw image, scaling and compressing 4 different versions of it.
hth
Jeez - colour balance ?? The tool applies to shadows, midtones or highlights, with no option to select all at once. And it's not calibrated in colour temperature, and there's no button to reset to original I'm partially colourblind, but I can usually drag a single slider to get the colours about right, but THREE of them ??
again multiple ways of changing colour. through curves(RGB channels), adding a photo filter (80A etc) hue/saturation, channel mixer,
photoshop assumes you are already aware of how additive/subtractive colour works and how the 80-82 85-81, red/green cc filters work etc.
a °kelvin adjustment is usually done when processing the raw.
you could also argue the other way, if the colour balance was global. why can't you adjust the highlights and shadows separately?
it's far more useful to have highlight/midtone/shadow controls.
Yet again you are essentially complaining that you don't know how to use the software. Colour Balance is only one tool for adjusting, er, colour balance. Other methods (curves for example, or hue, levels and more) do amend the full range of tones simultaneously. You need to find the one that suits you - I would suggest something but clearly you have no intention of listening.
In that save for web dialog screen grab you are still showing the image's original size. Are you saying it gives you a memory error even when you enter a more appropriate pixel dimension in the fields? What pixel dimension are you asking it to reduce to?
Yet again we come back to the beginning - your OP title is simple Photoshop question, but you don't have questions really (at least you are totally unwilling to listen to the answers that have been helpfully provided). You just want to piss, moan and troll. If you can think of something you want Photoshop to do, it will do it. You will, however, need to find out how it works first.
2gb ram aint much
Well no it wouldn't be, but Simon has 6GB of RAM and is seeing that message when doing "Save For Web" on a normal 4288x2848 photo from his camera, which will only be a couple of MB.
So why is there an issue?
dunno. but i doubt any prefs have been changed regarding cache/history states/scratch disk/graphics redraw/compression when saving/ amount of ram allocated to photoshop.
all of the above affect saving/working speed.
What GlenP said!
Why don't we all start a thread ridiculing programming language, illustrating our total lack of knowledge of the subject?..... "why oh why can't they just use plain english?"
Though you would hope that the world's best image manipulation software might manage to choose some sensible defaults for those preferences when provided with abundant RAM.
Nah I'm definitely with Simon (and the Adobe forum users) on this one - that particular Warning dialog makes no sense.
SFB
I only have CS2, but with most adjustment dialogue boxes, pressing alt (I think) turns either the 'OK' or 'Cancel' button into a 'reset' button.
Is this not the case with the colour balance bit you mention?
colour balance as an adjustment layer. you can turn it on/off, mask off areas, change it's strength as a percentage and edit it and edit it's mask in various different ways.
button.
Well you can't fault them for intuitive UI there can you? 🙄
I suspect, judging by the reference to colour temperatures, that there was some confusion between "White Balance" (as performed by the camera and/or during RAW conversion) and "Color Balance" (as used within Photoshop).
Simon:
A key advantage of using CaptureNX is that it uses the same familiar Nikon terms and controls that you'll find on your camera.
So you have White Balance with Shady,Sunny,Indoor etc, Exposure Compensation, Color Mode, Optimise Image, etc and they are all set to whatever the settings were on-camera when you took the shot, and use the same processing algorithms that are used on-camera, so you can move pretty seamlessly from the shot you captured to the shot you edit.
GrahamS - Member
2gb ram aint much
Well no it wouldn't be, but Simon has 6GB of RAM and is seeing that message when doing "Save For Web" on a normal 4288x2848 photo from his camera, which will only be a couple of MB.So why is there an issue?
RAW image is 300dpi ?
4288x2848 is a large jpg for a website?
So? It doesn't contain any more actual information. That's just a number.
Yes it is, which is why he quite reasonably opened the "Save For Web" dialog which lets you save off a JPG at a smaller size and different compression level without altering the main image.
What's wrong with a button press to change how something operates?
It means you keep one hand on the mouse to do whatever it is you are doing & then use your other hand to access other available options. Admittedly, it's one of those things that you need to know before you can use it, but no different to many other complicated software packages. Solidworks for example; manipulating a model on screen with pan, zoom, rotate etc. - different key presses combined with moving your mouse will result in a different type of movement, so you keep one hand on the mouse and the other can perform other tasks. It's not intuititve so to speak as you need to know what to press to operate it, but with something so complex there will also be a requirement to learn how it works. And when you have learnt how to use it properly, it is a very quick method of doing what you require.
Sounds like for the basic stuff that sfb and many others on here do (probably including myself), Photoshop is way more powerful than required and it is probably due to this complexity that certain things can seem long winded.
Photoshop can be using the scratch disk even when you don't expect it to. You can always purge the undo, history and clipboard before you enter that dialog, or make sure you have assigned a sensibly large scratch disk.
every designer/photographer/retoucher i know uses a wacom tablet/pen for photoshop unless it's just processing files.
if you have the pen rocker set up to operate the contextual menu or ctrl/alt it speeds up drawing paths or changing brush size/softness.
brushwork using a pressure sensitive pen is way better than using a mouse and a lot easier on the hands/wrist if you are working all day.
Whereas I don't know any (that use a tablet). Maybe I should try again, because I do get rsi in wrist and elbow from mouse.every designer/photographer/retoucher i know
glen p - tablet FTW, 2 week bedding in 🙂
best to not get the big a4 one unless you have 2x24in plus monitors side by side as big arm movements are not so good. i have an A4 which i mostly use with a 24in widescreen given the choice i would have an a5 widescreen tablet but they don't do them any more.
you can actually limit the image area of the tablet if it's too big but then you are just paying more for a bigger tablet.
MrSmith - maybe, but for the occasional user such as myself I can't justify forking out on a tablet on top of all the other things that I can't afford to buy, when a keyboard & mouse works OK.
GrahamS - Member
POSTED 11 HOURS AGO
GrahamS - Member
So? It doesn't contain any more actual information. That's just a number.4288x2848 is a large jpg for a website?
Save as > jpg would do if you dont want to see the results.
Save for web is used for optomising for website use. The average screen size is 1280. Only 25% of the image would be viewable from a jpg that size.
disclaimer : some numbers are a rough estimate.
which is why it has 2 boxes to set the size you want (or a %age)...
Not sure why your quoting thay back to me as the Adobe forums seem to agree it is a bug, or at least an out of date warning based on an arbitrary limit.
FFS Yes yes I know.
That's why one might use the Save For Web dialog to [u]reduce the size of the image[/u] so that it fits on a web page!
i.e. one of the functions of Save For Web is to RESIZE the image. Simon even supplied a screenshot pointing out those controls.
there are reasons not to use save for web but to first resize the image to 72dpi from it's native 300dpi first.
but:
i can't be bothered to explain the why's and wherefore's, it will take me too long to explain.
i'm going out for a bike ride as the sun is shining.
Agreed that the Save For Web dialog is not really fit for purpose.
For one thing I generally want to apply output sharpening once I have the image the size I want it and it doesn't let you do that (or at least didn't in the old Photoshop I have).
I have no idea why the dpi setting would matter for web images as it is completely ignored by web browsers as far as I know, but you would think the SFW dialog would do that for you too.
FWIW I find myself aligning with sfb now: Photoshop is incredibly powerful, which is why it is so deservedly popular, but its user interface is distinctly shonky in places.
Quoting back to you because, you asked a question, answered it yourself then started being pedantic because another user may use the program differently to you.
[url= http://en.wikipedia.org/wiki/Dunning–Kruger_effect ]No disrespect intended...[/url]
I'm not being pedantic. You were claiming that it was too big and you have to resize the image before opening the dialog for resizing the image.
I'm saying that's a bit mental.
The time it takes to apply sharpening is the same whether you do it to your optimised export or before you make the export, so I can't see how the way it is arranged currently is "daft" at all. Just do all your adjustments except sharpening, export at the correct size and re-open the exported jpg to double-check and do sharp etc. You're going to double-check it anyway, so no big deal.
Ha Ha!
Jucky Jim hits the nail firmly & squarely on the head!
....."I'm rubbish, me!"
glenp: if you export an optimised JPG, then open it and sharpen it and save it again then it is no longer optimised and is now lower quality.
Fair point, I put that wrong. So you need to do image size and save a psd (or other lossless), and then make optimised at correct pixel size. So, it is true to say that the ability to re-sze as part of the save for web dialog is of (slightly) limited value.
GrahamS : apologies for calling you pedantic 🙂
limited value.
I'd say so, yes.
I guess not everyone bothers to sharpen after resizing an image, but it can make a pretty big difference.
But I suspect, as others on this thread have suggested, that a large percentage of users don't use the Save For Web dialog when saving for the web - which kinda suggests poor UI to me. 🙂
I'm an engineer. It's my job to be pedantic. 🙂
Sharpening is over-used in my view. Like all effects it is best to be sparing with it anyway.
It may have some less than 100% perfect areas, but it still pretty stonkingly good. I won't be learning another package any time soon, put it that way. But - if I were batch processing lots of images I certainly would. Not only is that not the perfect territory for Photoshop, Adobe themselves have another product for that purpose!
Agreed.
Over-saturated and over-sharp seems to be the norm on the web where many folk will be using crappy 6-bit TN film monitors with the brightness at max and the colours all wrong 🙄
But when you're taking a full size original and resizing it to maybe 10% of its original size then a (lightly applied) Unsharp Mask can bring back some of the lost detail quite nicely.
sharpening. a whole new can of worms 🙂
each image usually needs totally different sharpening depending on the lens used, subject, and intended output and size.
big fan of the highpass filter > soft light/hard light method myself.
High pass is the way to go - two or three layers with different radius high pass, then juggle transparency settings, usually soft light for the local contrast layers and hard light (turned down) for the fine sharp. Means you can go back and edit the layers. I often go right ahead and build two or three high pass layers (as above) plus a levels a curves and a hue/saturation adjustment layer. Once you're used to is it takes seconds to set up and you can do it while you're having your first look of the image.
but there are many circumstances in which the jpg is all you have...
why would one bother with ancient history when a simple slider is so much more obvious ?
to the contrary I'm reading all the comments hoping to learn something useful
yes, it pops up as soon as you click the menu item 🙁 The size I get to is irrelevant as it only happens afterwards, but typically 1000 pixels high...
no, I said Photoshop hogs 950MB with one image loaded. Having just turned on it's at a sensible 88MB, so I guess that means it's not releasing memory. I just loaded a 21MB file and its usage jumped to 240MB, and didn't drop when I closed it.
I prefer the programmer to sort that kind of thing out and not need handholding...
and drag through endless menus and needless dialogs to achieve it 🙁
Hey! Thanks for the tip, however, pressing the ALT key requires you to look away from the screen to find it. I can never remember keyboard shortcuts, being visually orientated (as I imagine many photographers will be) and want something on screen to click instead
yes, I do get them mixed up as it has nothing much to do with 'white' and is in fact about the representation of colours. So, yes, I want a white balance adjustment layer, as images can easily have multiple light sources ie sun/skylight or daylight/artificial indoors near a window...
people keep saying this, but I'm wondering if they're confusing power with complexity of presentation. The things one needs to achieve are simple and intuitive, whether getting the image to correspond more closely to the original scene, as captured by 2 pieces of face jelly, or creative distortions. The complex bit is telling the program what you want.
I think that may be the most useful tip so far, as the mouse is a hopelesly crude tool compared to the pen! I shall buy one ASAP. Any recommendations ?
so resizing then saving to web is somehow better than doing it in one step ?
sorry can't help you there.
I have a new inexplicable one, if I drag the crop rectangle, when it gets close to the edge, it snaps to it. Why does it think it knows where I want the edge to be better than I do ? The only way I can find to crop near the edge is to zoom right in close...
The normal way to crop right to the edge is to try to drag beyond it - which is supported too.
it's something very easy to turn off but it's buried in a menu somewhere or you can use a shortcut to turn it on/off.
found it:
When you’re trying to crop an image using the Crop tool (C), your cropping border tries to snap to the edges of your document window. This might also be happening when drawing large Marquee selections as well. Solution: Press Command-Shift-; (PC: Control-Shift-;), which is the shortcut for turning off this snapping. The only downside is it turns off all snapping (like Snap To Guides, Snap To Grid, etc.). If you just want the Crop snapping (or Marquee snapping) off, go under the View menu, under Snap To, and choose Document Bounds, and your tools will no longer try to snap to your, well, document bounds.
phew! For a while I'd thought I was imagining it! It's not at all clear to me why this would be the default as it seems counterintuitive when there's already an obvious metaphor for going to the edge...
> Doing it after the fact to a JPG isn't really the same thing at all.but there are many circumstances in which the jpg is all you have...
Yep, fair enough, but White Balance is really an input parameter of the RAW conversion.
If you are working with a JPG then that cake is already baked.
I guess they could offer a dialog that simulated something close to the same effect based on a similar colour temperature slider, but that might just add to the confusion.
Photo Filters seem to be the easiest way to apply a full image colour adjust after the fact. See http://www.earthboundlight.com/phototips/white-balance-photoshop.html
thanks - but doesn't this beg the question why you can't do the same with a colour temperature effect ? I don't know the figures in millireds or K, but I suspect a percentage of 85 warm isn't the same as a smaller colour temperature correction
