Simple geometry que...
[Closed] Simple geometry question
7 Users
If you've got a square-based and square-topped pillar, which is 50cm sq at the bottom, 30 cm sq at the top and 100cm high, what angle do the sides make?
I was always cr1p at maths.
Ta!
Posted : 16/05/2010 11:08 am
0.46 degrees to vertical
Wow, I'm bored.
Posted : 16/05/2010 11:15 am
I can't do trigonometry, but it will be the angle on a 10cm x 100cm triangle, whatever that is, assuming you mean what is the angle of the faces from vertical, not what is the angle at the corners of the trapezium face.
And, slightly off topic, why do schools always use cm for these type of questions, when everyone in the real world works in mm ?
Posted : 16/05/2010 11:18 am
Actually, I read that as 50cm^2 and 30cm^2 - you probably meant 50*50 and 30*30, in which case that will be wrong.
Posted : 16/05/2010 11:20 am
Oh yes, I meant 50*50 and 30*30.
Now I'm even confused about how I should say that - it's 30cm2, surely?
Posted : 16/05/2010 11:31 am
No, you're specifying the linear measurements, so it is 30cm square which is 900cm2
Posted : 16/05/2010 11:35 am
As has been said - right angled triangle 10cm at top - 100cm high Tan Ratio gives Tan Angle = 10/100 thus angle = 5.7degrees from vertical.
Posted : 16/05/2010 11:40 am
Thanks all.
Posted : 16/05/2010 11:59 am
Feel free to correct me if i'm wrong but I make it 11.31 deg. The above answer was 10/100 should be 20/100 as the difference is 20cm over the 100cm length. 50cm - 30cm = 20cm, 20 divided by 100 = 5 inv tan = 11.31 deg.
Posted : 16/05/2010 12:38 pm
All 4 sides slope in, so if the top is 20cm smaller than the base, each side slopes in by 10cm.
Although, now you mention it, that's not specified in the original question. I'm just assuming the two squares are concentric.
Posted : 16/05/2010 12:45 pm
It would make more sense than my answer.
+1 😳
Posted : 16/05/2010 3:23 pm
i always use mm in design and technology and it's them mafs and science bods who use cm,,,
often get students and teachers looking confused at a small square of wood when they asked me for something 50 X 50 I know what they realy want but i like being awkward sometimes
Posted : 16/05/2010 3:50 pm
MM are the standard unit of measurement in engineering and construction.
Schools are just confusing kids by teaching them to use CM.
Nobody sells 0.8cm x 2.5cm bolts or 5cm x 7.5cm timber.
Possibly an urban myth, but I heard of someone who wanted an adapter made to connect a round flue to the oval outlet of a stove.
He did a nice little sketch with measurements, but not the units, and handed it to the steel fabricator.
It came back exactly 2.54 times the size it should have been. 😀
Posted : 16/05/2010 4:14 pm
[pedant] No it's not, mm is though [/pedant] 🙂
Posted : 16/05/2010 4:21 pm
Both are stupid, it should all be done in meters as that's the SI unit. 😉
Posted : 16/05/2010 4:55 pm
