I just returned from a run of 4kms, and when I was about 2/3s of the way into it, I started getting 'spots' of white - like light spots - in my vision. No other symptoms (other than feeling more tired than normal before I began).
I have never had this happen before, and they eventually disappeared (after a few minutes). Finally, I don't know if it's relevant, but I was wearing my contacts, which I normally don't do while running.
Any thoughts, other than cat aids?
I occassionally get that. I haven't died yet.
I've been warned by my optition that if I get a lot of floaters it could be the sign of a detaching retina as I am at a higher risk due to a moderate astigmatism. I don't know if spots are included in this.
Sounds a bit migrainey. Which is influenced by blood flow "up there". Do you suffer, or do parents / siblings?
Detached retina sounds scary.
Definitely one to get checked out I reckon.
I read in a running magazine that it's probably due to blood being drawn to more active parts of the body during strenuous exercise. legs, heart, so on.
Sounds a bit like what I get when I'm running low on blood sugar when out on my bike- I start feeling a little bit dizzy and then I get coloured spots in front of my eyes. That's my signal to eat something.
Could be that, or migraine aura, which I also get sometimes.
Spots in my vision is also a warning that my blood sugar has dropped too low (type 1 diabetes) and I need to do something about it quickly
I get that if my blood pressures changes too much - like if I stand up quickly having crouched down for a few minutes.
I often see spots squatting or deadlifting near my max. I also go deaf for about 2 mins afterwards....
I used to get that stretching off after a hard ride sometimes. These days my physiological make up must have changed as I'm sure I would chunder before I got to that point.
If it's worrying you, go and see your GP about it. They won't usually send you for a catalogue of tests unless you need it or they're bored/fancy whoever they'd have to talk over the test results with.
