sealing a utility w...
sealing a utility worktop
13 Users
1 Reactions
 DT78
caulk or silcone?
and what colour? it's a light oak colour. went to use white silcone and it looked awful way to stark
so a tan silcone? Will it look worse if it's not the same colour.
clear is a possibility but walls aren't painted yet (well white base coat) and I don't want a white line when finally get round to painting / deciding if we will tile it
First World problems! can't make my mind up
would caulk now, and then paint followed by clear silcone be a silly idea?
gaps are 2-3mm
Posted : 28/02/2023 9:55 pm
 DT78
Well it is quite a dull question I know:)
Posted : 01/03/2023 7:25 am
Are you putting any sort of splash back up? A line of tiles/glass/steel etc. could hide the silicon.
Posted : 01/03/2023 7:45 am
Depends on the wall colour - try to match it?
Posted : 01/03/2023 7:57 am
 DT78
see this is the challenge, wifey hasn't decided on wall colours or tiles but wants it up and running
I have a lot of jobs so decorating won't be for a couple of months
that's why I'm thinking matching to the worktop if possible and then if we don't tile it'll be better than white
Posted : 01/03/2023 8:18 am
 DT78
worktop has walls either end so it's 3 sides to seal
Posted : 01/03/2023 8:19 am
I wouldn't have thought you'd want to put silicone where later you'll paint.
 DT78
so caulk the gap. paint and or tile and then a clear silcone after decorating?
there is a sink and it's laminate so I definitely want a water tight seal to avoid the risk of it blowing
Posted : 01/03/2023 9:37 am
If the gaps are 2-3mm can you silicone seal so that it is flush with the worktop? That way it seals the exposed worktop edges but doesn't have any vertical height like a normal bead would. Being silicone means it also has a bit of flexibility in it for movement of walls/worktop whereas caulk would just crack and isn't actually going to seal anything.
EDIT: Doesn't answer your colour question. I'd go for tan or clear. And if you decide not to tile you could add a small oak quadrant trim bead around the edges to hide the gap/colour difference.
Posted : 01/03/2023 10:04 am
How proficient are you at cutting this worktop ?. As you can scribe it exactly for a tight fit, without any gaps needing to be filled.
Posted : 01/03/2023 10:20 am
 DT78
It’s cut, I deliberately gave myself 2mm tolerance to ensure it fitted in the space, as it had to be lifted in at an angle in a tight space, I could push it back flush on the rear wall but I’d read you need minimum 2mm gap to have enough gap for sealant. Even if the worktop is flush water will still penetrate.
Maybe flush clear silicone is the answer. Can you see why I can’t make my mind up!
Still haven’t sealed the main kitchen yet either because it needs tiling and that was fitted in November….
Posted : 01/03/2023 11:10 am
 DT78
Liking the oak bead idea if we don’t tile. Good fallback
Posted : 01/03/2023 11:11 am
Just stick an upstand on it. Then make sure it's all good and sealed where the upstand meets the worktop. Then drop some clear, or coloured silicone behind the top of your upstand where it meets the wall to fill any gaps.
You say light oak coloured, is it real wood or laminate, not that it makes much difference.
You can then paint or tile above the upstand once you've worked out what to do. Which if you're like me will mean leaving it as is for many years 😄
Posted : 01/03/2023 11:31 am
wifey hasn’t decided on wall colours or tiles
Paint it white, bead of sillicone, then a single row of tiles. In a week you won't see it as it'll all be covered in cleaning products, washing baskets and odd socks anyway!
Posted : 01/03/2023 1:13 pm
jeffl reacted
Paint it white, bead of sillicone, then a single row of tiles. In a week you won’t see it as it’ll all be covered in cleaning products, washing baskets and odd socks anyway!
This - I have given up tidying our utility - 5 minutes later it is always a mess.
Posted : 01/03/2023 1:31 pm
If you are going to paint then don’t use silicone. The paint won’t adhere and no matter how careful you’ll get some residue on the wall.
Posted : 01/03/2023 1:44 pm
 scud
Personally i'd do a bead of silicon flush with the worktop, then if you tile, once done, run a second thin bead along to completely seal
Posted : 01/03/2023 2:45 pm
I'm going to offer the alternative opinion that I always feel that the uniform colour of tan / light brown silicon stands out too much from the texture of wood or wood effect and clear shows up blemishes more.
If white is out go with the current decorating zeitgeist ( and weather) and use grey silicone. It stands out less for me.
Posted : 01/03/2023 7:17 pm
