Router bits - buy o...
[Closed] Router bits - buy one at a time as and when?
9 Users
Are there any sets of router bits that offer good value for money, or should I just do what I do with drill bits and buy a decent single bit as and when required?
Posted : 07/03/2019 2:43 pm
Depends how much variety you plan on doing.
I think it's worth buying good quality, often replaceable bladed versions for things you'll do a lot of, but if there are some you'd maybe only use now and again, then part of a set can make sense.
I've bought the sets from Rutlands before, and they sometimes have them on offer.
I bought one of the bigger sets once when I was buying for a furniture making course and I have to say I was impressed at the quality and how they lasted.
I've also recently bought a Rutlands tongue and groove set and again, the quality is very good.
Posted : 07/03/2019 4:15 pm
I think it's worth having one of those sets just to see what bits you need and some 'just in case' bits. Go for a cheaper one then you can then buy better upgrades of the ones you use. I pretty much never use the fancy shapes but have a quite a big range of straight cutters, 45s and round overs.
Posted : 07/03/2019 8:02 pm
Wealden tools are good for single bits.
Posted : 07/03/2019 8:54 pm
Have a look at Axminster Power Tools.
Always found their own brand products OK.
Posted : 07/03/2019 10:54 pm
The trend sets you can get in B&Q give you a reasonable quality little-bit-of-everything for the price of two good cutters. I seem to end up with a few of those packs as its often the only way I can buy any kind of usable router bit on a Sunday!
I find where lower price bits can really let you down is anything with a bearing guide. Other bits can just go blunt (or in the case of 1/4" shanks snap) which can be annoying but is fair enough. But bearings sheering off and the bit munching its way into the workplace is a really quick and effective way of ruining all your hard work - especially as its a bit you'd often use as a finishing touch. I rarely use fancy profiled bits. I treat 12mm straight fluted bits as consumables (and as hidden screw detectors) but spend good money on bearing bits
Posted : 08/03/2019 12:21 am
I just bought as I needed and have settled on 4
Round-over bit (can't remember the radius, but it's probably around 1/2")
Flush trimmer
Straight 6mm (or 1/4" depending on source of timber)
Straight 15mm (because I work in 15mm birch ply all the time).
Posted : 08/03/2019 10:25 am
Thanks guys. I think I might need to take a step back before investing in anything, so I've started a new thread outlining project I'm undertaking: https://singletrackworld.com/forum/topic/woodworktrackworld-help-with-joints-and-construction-of-a-cabinet/
Posted : 09/03/2019 11:48 am
Could I use this in a hand held router or will I need a table?
https://www.axminster.co.uk/axcaliber-bearing-guided-chamfer-cutters-ax802658
Posted : 08/07/2019 1:29 pm
Router on a track is a half way house to a table. I know Festool's routers can run on their track, so I guess other manufacturers support it...
Posted : 08/07/2019 7:22 pm
Which size? The largest is starting to get a bit large. Might be a bit less gnarly in a table.
Most of them would be fine hand held I'd have thunk as long as you understand cutter rotation  in terms of feed direction and that.
Posted : 08/07/2019 7:26 pm
Which size?
Probably just the smallest for tidying up edges. I have to make some blocks to go on the wall for mounting stair gates on. They're 15mm thick to match skirting and I'd like to put a chamfer on the edges to make them look a bit nicer.
Posted : 09/07/2019 12:41 pm
I can't give you any useful feedback on the OP's original question but for anybody starting to get serious about woodworking tools I found Lumberjack Tools to be excellent value.
I have their table router and it's spot on. Nice to be able to move the cutter up and down without having to get tools out and move the workpiece.
Posted : 09/07/2019 1:21 pm
