Replacement bolt fo...
[Closed] Replacement bolt for this?
I'm being a bit blonde this morning but need some stainless steel versions of this to sort our creaky bed out.
Thread measures 7.5mm x 14mm so assuming that's an M7?
Recommended sources?
Thanks
Chris
Posted : 12/04/2017 8:40 am
got a local hardware store? Probably will be one with nuts and bolts, just find what it screws into and get the corresponding bolt
Posted : 12/04/2017 8:50 am
What sort of stains do you need protect the screws from?
More likely to be M8, an M7 thread (like all threads) will be under the nominal size.
Posted : 12/04/2017 8:55 am
Thanks both. Don't need to protect the screws from any stains thanks.....just sicking of these soft steel heads rounding out so assumed SS was best?
Hard steel needed I suppose.
Posted : 12/04/2017 8:59 am
+1 for M8. Looks about right and likely to be slightly undersized.
More likely to round out a cheap stainless steel bolt that high tensile steel
Posted : 12/04/2017 9:00 am
Cool. Is there a specific high tens steel I should ask for?
Posted : 12/04/2017 9:03 am
You don't [i]need[/i] it to be high tensile for that application but anything that actually has a grading (such as 8.8 or 10.9) is likely to be better quality that one that has nothing on it.
Posted : 12/04/2017 9:07 am
I'd run a known size metric nut up there before pressing "buy" I've got a big "Box of Shyte" that I keep all the gash nuts and bolts in. The stuff that comes with beds/flat-pack etc may not be metric. I've found this more than a couple of times whilst rummaging for an an odd nut or bolt.
D.
Posted : 12/04/2017 9:12 am
a £1 ebay thread gauge from the far east makes all these discussions about pitch and thread much easier 🙂
Posted : 12/04/2017 9:16 am
theres an outside chance its 5/16unc... but if your metric allen key kits nicly i'd say its M8x1.25
if you are anywhere near essex you can come and raid the mighty drawer of fasteners i've got hundreds
Is you main issue is the small allen key size being to small so you can't lean on it then go to a normal cap headed bolt and a washer
Posted : 12/04/2017 9:21 am
Thanks all.
Porter_Jamie - The main problem is the sodding oak bed creaks like a bugger! I tried to tighten up the 8 bolts (2 each corner) and managed to round half them off 😳 - I think cap head would be an improvement.
I've read that applying wax to each surface sorts out creaks, but I now need to remove buggered bolts and then replace with something more appropriate for my mighty tightening strength!
Regrettably i'm miles away from Essex, but thanks for the offer anyway.
Posted : 12/04/2017 9:32 am
Deleted... Forgotten post now already discussed!
Posted : 12/04/2017 9:57 am
I can get them from the local nuts shop if you are certain what they are
I would imagine about £2 ish + postage as a guess
PM if you need me to do this
Posted : 12/04/2017 10:18 am
Thanks Junkyard - Think I might go and take a little sunshine stroll around Coventry shortly and see what the local hardware stores have in stock!
Posted : 12/04/2017 10:26 am
Screwfix do big packs of ss nuts / bolts very cheaply. Any time I need something I don't already have in stock I buy a pack so that I have spares for next time.
Posted : 12/04/2017 11:31 am
Thanks all. A little stroll down to a local DIY shop an I've got some hex head M8 bolts (checked against an M8 bolt and fits fine)....socket set should allow for decent torque and less rounding!
Any recommendations on removing the rounded bolts? Threaded screw extractor? Cut a slot for flat screwdriver?
Thanks
Posted : 12/04/2017 11:44 am
cjr61 - Member
Quote often using the next size up Torx socket will work - you might have to tap it in....
Or yeah, hacksaw a slot & use a screwdriver.
Regarding the creaking - might be worth getting some felt & cutting 'gaskets' to fit between the wooden parts...
Posted : 12/04/2017 1:47 pm
