Recommend me a &quo...
[Closed] Recommend me a " how to make gates " book.
Can't be that hard shirley. I recently bought and fitted this gate for a client. Although very well made and the Client being v. happy with it the gate/s without hinges, fixings etc cost over a £1000. I think it's a lot of money considering the diagonal braces are only screwed ( not tenon/ mortice/ pegged )
[URL= http://i884.photobucket.com/albums/ac50/tymbian/IMAG0326_zps81479cf0.jp g" target="_blank">http://i884.photobucket.com/albums/ac50/tymbian/IMAG0326_zps81479cf0.jp g"/> [/IMG][/URL]
Posted : 20/05/2013 10:42 pm
You're asking a lot of those hinges 😯
Posted : 20/05/2013 11:00 pm
Why??? the left hinges are 1.2M long ( adjustable hook and band).
not your B&Q black T-hinge
Posted : 20/05/2013 11:07 pm
 br
Its the brickwork/morter that'll struggle - is there any central support?
Posted : 20/05/2013 11:11 pm
12mm Stainless threaded rod 150mm long, drilled 16mm, sleeved and set in epoxy resin.
Posted : 20/05/2013 11:15 pm
have they sagged yet
I'd see the left gate sagging over time. The fixings are quite close to the edge of the pier. Did you resin and threaded bar or just use rag bolts? I'd hardly suggest there's any centre support as the piers look 50+ years old. Nice gates tho...
Posted : 20/05/2013 11:16 pm
Are they softwood?
From your previous posts Tymbian, you sound well clued up about wood and constructing stuff with it. I would imagine you could make some gates that wont sag using your experience and knowledge.
Funnily enough, I'm in the process of restoring some oak gates at the moment, they dont have any diagonal bracing, but the top, middle and lower rails are nicely morticed and tenoned and held with double pegs in each joint. These heavy gates haven't sagged, they're probably about 40 years old, the issue with these is rot in the lower rails and styles.
Posted : 20/05/2013 11:17 pm
i went back after a month and they're spot on.
Fit a jockey wheel to the left hand gate. No problem.
Posted : 20/05/2013 11:19 pm
All good then sir nothing to see here.
Posted : 20/05/2013 11:20 pm
I surprised you haven't fitted a gate wheel. You're asking a lot of the diagonal bracing. imo
EDIT : As suggested by slackalice
The wheel is a good idea, purely for when you get little scrotes like my son who would have to swing on them 👿
Posted : 20/05/2013 11:22 pm
I couldn't find a jockey-wheel that I could set the height of the wheel. All the Jockey-wheels I saw had a wheel on a spring thus continually forcing the gate upwards.
@ slack..yes, treated softwood. probably Conifer. Hence I do expect them to sag over time. ( nothing adjustable hinges can't sort )
So any suggestions on books?
Posted : 20/05/2013 11:46 pm
