recommend me... a b...
[Closed] recommend me... a book on Linux command line
4 Users
as title suggests, just installed and need to get to grips with command line
Ta
Posted : 06/05/2010 9:48 am
Sorry, I've just re-read your post, the book above might not be what you want.
The command line is a complex beast, there are thousands of commands available to you, each one could fill a small book with it's usage. The book I've posted explains how the command line, or shell, works as a seperate program (and also goes on to explain how shell scripting works).
Is this what you want or are you more concerned on what each of the commands do? In which case the best place is the included manual.
man man
Posted : 06/05/2010 9:55 am
thanks for the suggestion, I'm a relative beginner so looking more at getting to grips with the basics, downloaded a book on command line, but really need something on paper as reading large amounts on screen screws up my eyes
The suggestions on the amazon page has "Linux in Nutshell" which may be what I am looking for
Posted : 06/05/2010 10:08 am
The command line is a moving target, books go out of date but the internet evolves. I'd print from the net. Obviously the problem then is sorting the wheat from the chaff. Also, start getting a magazine, Linux Format is more beginner friendly than Linux User.
Posted : 06/05/2010 10:27 am
thanks for the suggestions, further use of google has given me some good on-line resources, and I'm just off out and will check out the magazine option
Posted : 06/05/2010 10:33 am
I use the net as my linux command line reference, Google finds everything you need but if you are newbie then there are loads of good intro books anything by O'Reilly is normally comprehensive..
Posted : 06/05/2010 10:56 am
