Re-Capping an old A...
[Closed] Re-Capping an old Amp
6 Users
I bought a record the other day. You know a proper plastic one and everything!
Anyhow, once I'd got my deck out of the loft and plugged it all in, I realised my amp sounded horrid - nothing like it used to anyway. I figure the capacitors have degraded over the past 12 years since I last used it (the sound was horribly bright and lacked a good deal of bass) so I was wondering about replacing the old capacitors.
Is it a case of just buying the modern day equivalents and soldering them into place? As long as I keep the same capacitance/voltage etc then i shouldn't need to tweak anything else should I?
Any guidance would be appreciated!
Posted : 10/07/2014 4:14 pm
I think so, never done it though.
You will prob find audiophile brands if that's your thing.
Posted : 10/07/2014 5:12 pm
You don't mention how competent you are with electronics. Assuming it is the capacitors that have gone, be sure to discharge them first. I didn't know this when attempting to fix my amp and got the shock of my life. Some hefty caps in old amps.
Apologies if you're a wizard with the soldering iron.
Posted : 10/07/2014 5:22 pm
It is far more likely the cartridge has perished, especially if the amp has also been in storage. It has rubber suspension components that go after a while. Try replacing it with something like an AT95E which is around 20 quid and see if that works first.
Posted : 10/07/2014 5:30 pm
Ta for the advice - I'm not too bad with the old iron (made my own LED driver a few years ago)
Didn't think about the cartridge - it was almost new when I put the turntable away (and it's an AT95E) so yes it may have degraded and it would explain why the phono stage sounds much worse than the rest......
Cheers!
Posted : 10/07/2014 8:08 pm
I presume there's some sort of line input? Stick a cd / mp3 signal through it to check if the problem is the amp or TT.
I suspect caps mostly last longer than given credit for. We've got a Quad 33 / 303 pre/power amp in our kitchen stereo and they were last serviced in 1977! I'm sure they do need a recap by now (especially the big ones in the 303) but it doesn't sound bad, not horribly bright...Probably a trifle muffled if anything.
Posted : 11/07/2014 7:42 am
Yeah, it's a NAD 3225pe so not high end stuff. MP3 players etc don't sound too bad through it so the problem may very well be the cartridge. I don't really know what a degraded cartridge sounds like!
I have had the amp repaired before many years ago as a Jesus Jones album played too loud blew something. I'm not sure what was replaced but I have a feeling it's not been right since!
Posted : 11/07/2014 7:53 am
You'll probably find all the variable resistors have worn out, (treble, bass, balance, etc). They're normally carbon deposited on a pcb material and the carbon wears thin and then the contact becomes very intermittent.
Posted : 11/07/2014 8:24 am
