Quick Question - wi...
[Closed] Quick Question - will a cheap multimeter work as a continuity tester?
6 Users
Like [url= http://www.screwfix.com/p/lap-mas830b-digital-multimeter-600v/75337 ]this one from screwfix?[/url] It's only £9.99.
I have a few days of putting down silly electrical UFH matting and as part of the procedure (which I [i]have[/i] to follow), I need to check continuity before covering it with timber. So I need a continuity tester - not really a tool in your average floorist's kitbag. 🙂
So will that one do the trick?
Posted : 11/11/2015 7:56 am
That'll be fine. Just use a low resistance range. One with a continuity test 'beep' might be a little easier as you don't need to look at it, though.
Posted : 11/11/2015 8:08 am
yep, its the setting at nearly 6 o'clock
Posted : 11/11/2015 8:10 am
Should be ok but it does depend on if it's just continuity you need or a low ohms reading. I thought some of the ufh elements worked on a low resistance which you need to prove prior to overlaying the floor. If the resistance is well under an ohm then that meter may be no good. If it's just a beep you need then it's fine.
Posted : 11/11/2015 8:21 am
I have that one, it is what it is, seems decent enough. Goes down to 0.1ohm which may or may not be low enough for your needs.
Posted : 11/11/2015 11:55 am
Seems like most cheap ones have the continuity mode, check if it has a beep, it's useful.
However, it's NOT suitable for insulation testing (which might be a useful check), i.e. testing if there might be a short circuit. Because they use low voltage, of course, and some insulation problems might cause a short circuit only when voltage is high. My dad used to use a thing called a Mega* which IIRC was more expensive, but it was pretty ancient so that may have changed.
Might be a good idea to make friends with a sparkie who could test it before you put flooring down?
* EDIT just googled, it's Megger.
Posted : 11/11/2015 12:12 pm
