Before I go and spend my children's inheritance Gas or Charcoal BBQ ?
I'm not a BBQing man so this would be our first one bar disposable type
Budget £60ish I have gas cylinders already.
Many thanks in advance
Only ever used charcoal, gas BBQ is just cooking outside. However I can see the attraction when it comes to "impulse BBQs".
Charcoal
Weber charcoal.
MAN MAKE FIRE! MAN COOK* MEAT!
*or in the case of a good steak, man shows meat the fire, then serves it not beyond the help of a good vet.
Charcoal. More fiddly and messy but tastes better when you learn how to grill on coals properly.
Gas. Much less of a PITA so you'll use it more and easier to control the temperature.
charcoal (never had any trouble with it and wouldn't consider it "fiddly")
Yep.
Charcoal, but your barbe must have a lid and controllable air flow, to cook properly.
Charcoal.
Gas is an outside hob.
Charcoal=BBQ
Gas=Grill
If you just want a job outside then go ahead, just don't pretend it's something it's not.
Plus, if you run out of charcoal, you can improvise with wood from your STW mandated log burner.
Charcoal. Just bought me a new Weber go anywhere.
You can BBQ or grill with either gas or charcoal, but grilling and BBQing aren't the same thing. IME, gas is easier to control the heat, so I'd choose gas for BBQing. However, I've never used a high-end charcoal set-up, I imagine they would be pretty awesome.
[url= http://globalnews.ca/news/1392015/grill-vs-barbecue-do-you-know-the-difference/ ]BBQ versus grill[/url]
Edit: [url= http://amazingribs.com/BBQ_buyers_guide/grills/charcoal_grills_vs_gas_grills.html ]Useful comparison of gas versus charcoal[/url]
got one of these recently; awesome for beach BBQ! Probably want something a bit bigger for doing family meals at home though. If you go charcoal make sure you get a chimney starter - takes all the faff out of lighting & means you can start cooking a lot quicker!Charcoal. Just bought me a new Weber go anywhere.
Cooking properly with charcoal is more difficult but satisfying IMO. Gas makes sense though if you just want to get food cooked without having to think about it.
The fact that you're asking the question suggests that you'll find gas more preferable 😉
You can also do veg 😀
What's the point of a gas barbecue?
If you want to do that, just make everyone sit outside and when you use your kitchen hob open the window so you can talk to your guests. Same effect as a gas barbecue at zero cost.
Gas convert.
Much easier to chuck some meat on midweek and lava coals mean you still get good smokey flavour.
Also no need to clean ash.
If you decide on gas the Aldi ones were on offer midweek in store. Worth a look at.
Charcoal if you've got the time but gas is quicker/more controllable and you'll use it loads more - I chuck bacon on it for a butty in the morning, do garlic bread on it, all sorts of stuff.
If your limit is £60 then I'd go charcoal as cheap gas would be 'disappointing'.
Gas for me..
Charcoal. Anything else isn't BBQ.
charcoal
Weber charcoal at home and Weber gas for camping. Prefer charcoal but gas is quicker and the the Weber gas has an optional griddle which is great for a fry up breakfast.
After 25 years of charcoal I swapped to gas this year ( Weber Q)
I should have swapped years ago!
It's so much easier to regulate the heat, no messing starting the coal, simpler to clean after and no messy dead coals!
As for the taste my family have noticed the difference and they are happier.
Sorry gas for me
Listen to Hank
[url= https://m.youtube.com/watch?v=oSzncxYqOaQ ]y'all[/url]
Do you want an outdoor griddle or a BBQ? I think how you view a BBQ is fundamental to how you fuel it.
If you want to be cooking outdoors a lot, easy and quick to heat up and less faff the answer is gas.
If you want that traditional smokey flavour and are prepared to concentrate on making the right fire and adapting your cooking accordingly then I think a charcoal BBQ (ime) gives the best smokey, man+fire outcome. BUT it's so much easier to burn everything and leave the middle raw if you are not patient and don't adapt how you cook.
We've got a B&Q kettle charcoal BBQ. I never find it inconvenient. Light it, prep everything else then cook on it.
If you go for charcoal having a good lighting routine/technique is a must.
You want to be able to get it going reliably. A lighting chimney with fire starter blocks is one way but good basic fire lighting and a stock of kindling will work well too.
Between April and September we BBQ probably one out of every two dry weeks at some point over the weekend. We do veg as well as meat on there.
If we had gas as well we would possibly cook more outdoors in the week but my experience of going to other houses for gas BBQ food is it doesn't smoke in the same way (still make tasty food just it's more like indoor food) so for me only one BBQ means charcoal because otherwise I can do dinner in the kitchen and walk down the garden with it.
I reckon charcoal are overall more pricey than gas from a fuel perspective.
I am probably totally biased as I was fortunate enough to be a scout and was therefore trusted to cook on wood fires and BBQ s from my early teens. If you can cook two meals a day for a week on an open fire then charcoal is a doddle.
Not cheap gas! We got given one and it was horrid. Really non-uniform heat distribution. Rancid greasy residue on the lava rock.....gross. I'm sure decent gas ones are fine, but for cheap and cheerful it has to be charcoal.
Weber, charcoal.
Love all the comments about gas BBQ just like cooking outside. That's right, well done. Those of that opinion maybe don't cook with gas. As someone who probably has at least one BBQ per week, either on charcoal Weber or a gas BBQ with lava rock I do see myself favouring gas these days for the reasons most have highlighted. Very little difference in flavour if done right with lava rock, chips etc.
I just got a gas BBQ. I like it cos I am much more likely to use it, and once I have convinced the Mrs that BBQ food isn't burnt cheap burgers I will get something a bit more adventurous. Might well go charcoal for that.
Gas, all BBQ is just cooking outside. 90% of people simply want to cook the food - most have no concept of smoking things etc.
Gas is faster, you will use it more. It's more controllable so you can cook on time, it's cleaner, it's great for things that get smokey so you can just do them outside any time of the year.
I'd happily cook something for the charcoal snobs and see if they could tell the difference but you will have pay your own flights 😉
I use wood
We've had 33 BBQs (yes gf records them) this year. Use it as much as we can.
It's gas. A Weber spirit thingy.
We just wouldn't have done that with coals.
The quality of the meat and how well you cook it is the overriding flavour giver.
That said I can see the appeal of charcoal for one BBQ a year.
[url= http://amazingribs.com/BBQ_buyers_guide/grills/charcoal_grills_vs_gas_grills.html ]Once again for people that are too set in their ways to read a link[/url]
went to gas(weber Q2200) after being a staunch charcoaler for years.
gas has a couple of advantages for me.
1 . takes no planning. Ie i can be doing something - decided to BBQ what ever it is we are eating and be BBQing it in about 10 minutes. + finding good quality coals was always an issue in november....
2. Its portable - in that it heats up and cools down quickly that i can put it in the van and take with.
3. Much easier to clean , gets a pressure wash once every couple of months.
With the addition of the smoker box and a DIY heat deflection plate & some hickory chips ive smoked up some real nice stuff.
At work we have a charcoal braai and it works fine but it takes 2 hrs to get it up to temperature (tis a huge lump of steel)
Over the years we've had gas and charcoal, but this last year we've got one of these
https://www.andrewjamesworldwide.com/kitchen-c1/kitchen-electricals-c7/raclettes-grills-c48/andrew-james-teppanyaki-electric-table-grill-p170
So far, I would'nt go back to gas or charcoal.
Charcoal for me, had a relatively cheap Outback which was crap. I but would happily switch to gas if I could afford the quality of BBQ you need to sear meat properly and not have constant flaming. when the fat starts to run off the meat.
Heart says charcoal, head says gas.
After years of using a Weber charcoal BBQ< I swapped to a gas one and, whilst it is not as much fun to cook on, it is far more convenient. You don't have to wait for the col to heat up. You don't have to burn a fiver's worth of briquettes very time you fancy a steak...
The obvious answer is both! The important thing about bbq'ing is the social experience and enjoyment if basic cooking as much as it is the food.
I only use charcoal to grill, bbq and smoke food although I certainly don't look down on anyone who chooses gas. Reading the link on the last page, I "cook" pretty much everything indirectly with the lid down before searing with the lid up. All of my bbq/grill/whatever is cooked through and not burned!
Having charcoal bbq's encourages me to put more effort into preparing my food so i make burgers, sauces, rubs etc. Not sure id put that level of effort into cooking on a gas hob.
I'm looking for a good sausage maker if anyone has any recommendations!
Gas for me too. Had several charcoal BBQ's of various costs, a cheap gas and now a Weber.
Having 2 small kids who love a 'bbq', it's so much quicker and easier to fire up the barby and slap some food on it.
We used to live in the sunny south - before having kids we had a big south facing garden, and would routinely cook outdoors on the deck, using a gas bbq to grill stuff. Since moving to Scotland 12 years ago, having more kids, fighting with midges, cooking on the bbq became an infrequent thing, having to clean all the cast iron plates, and to pull the spiders out of the stove a couple of times a year.
Recently went back and bought a new weber, currently cooking on charcoal a coupe of times a week - firestarter chimney brings things up to speed quick enough, tastes fantastic (we've learnt to use the cover on a charcoal bbq, so this could be technique). Overall, man make fire isa lot more pleasure - if you have the time (and at a price point of £60) I would be getting charcoal.
Chicken Teriyaki last night on bbq - nom[img]
Assuming the post lets me see the picture - which it might not..
Quick Q....those on gas BBQ's (specifically Weber), do you use the flavoured wood chips?
Looking to improve my cooking/flavours and thought these might add a little bit of flavour.
that was mostly done with the contents of the kitchen cupboards before hand.
Weber charcoal here for £64 (reduced from £80): http://www.bbqworld.co.uk/weber-barbecues/charcoal/weber-compact-47cm-charcoal-bbq-black.asp
Yup, a good marinade or rub will help a lot with flavour. Try putting your meat in the fridge overnight with your desired spices, some olive oil and a bay leaf or two.
On that it was probably the other way around for me,knowing I had a controllable cooking temp and variety with heat etc. I'd probably put way more effort into the food for gas, could do a huge variety of stuff on it for one meal.
Look at it this way.
Man fires up gas BBQ and gets to work straight away.
Man lights charcoal then drinks beer whilst BBQ heats up.
No contest.
Man/Woman preps food with a beer/glass of wine, turns on BBQ, cooks food and chills out? Contest?
If you're going to buy a Weber kettle, please take my advice and get the bigger one with the gourmet system thing. Its a pleasure to use and people can buy you the inserts (sear griddle, wok, rotisserie etc etc) for presents.
on that it was probably the other way around for me,knowing I had a controllable cooking temp and variety with heat etc. I'd probably put way more effort into the food for gas, could do a huge variety of stuff on it for one meal.
That's equally as valid! I dunno, I just took more pride cooking over coal. It's undeniably harder to get good results and takes a lot of practice but satisfying when you make something really good!
That's where you're wrong. I cook with gas all the time. In my kitchen.
last time i put a steak on the gas hob without a pan it didnt end well.
What you lay food out on top of your gas hob? How very strange
Sounds like you need some cooking lessons.
No, I lay my food out on my charcoal BBQ. I don't own an outdoor grilling device because I have a grill and a hob in my house.
well i dont use a pan on my gas bbq so i figured if i wanted to replicate the experiance in doors i shouldnt use a pan there either ?
Your gas BBQ doesn't have a grill?
well it does - but when i turned the grill upside down in the kitchen the clock didnt read right and the controls were at the bottom. and when the fat dripping onto the element to smoke up and give it flavour and flames it shorted out the electrics.
It all sounds like a bit of a compromise. Given that you're looking to create smoke for flavour, I wonder if there are any other options that might do the job better?
Aye your right I bought a gas BBQ and a smoker box then put it in the garden.
Now the clock reads the right time and my food tastes indistinguishable to the charcoal food I used to do.
Spending a year in nz and Oz where gas is king for the daily BBQ was my education. Realised I really couldn't tell the difference when a good cook was on the tongs
But haters gonna hate
Undoubtedly there are more expensive and involved ways of recreating the effect of a cheap and simple charcoal bbq.
aye 12 quid. broke my heart uses much less hickory to create the smoke than the ongoing cost and hassle of sourcing decent charcoal over the garage grade chemical infused crap.
Blimey! Calm down.
Trailr_rat votes gas and Ransons Charcoal.
aye 12 quid.
You got a gas bbq for £12? I expect the gas bottles are free as well.
Look at it this way.Man fires up gas BBQ and gets to work straight away.
No contest.
Man (or woman) get's home from work at 7:30 and want's to enjoy the last of the sunshine without waiting till 9:30 for £5 of coal to burn to cook his £1 burger.
Gas BBQ's are great, I can have a BBQ whilst doing the garden/bike maintenance at the weekend without getting shitfaced waiting for it to warm up!
Alternatively, I can get sozzled and socialise, then have a BBQ, rather than try and multitask.
I suppose that it might take a couple of hours to burn through a whole bag of charcoal, and in fairness, you can be sure that your cheap burger will be thoroughly cooked.
theotherjonv - Member
I started reading the link, and decided my original "gas bbq is just cooking outdoors" opinion is correct.
Also, smoky charcoal bbqs will repel midges a bit, which is useful in Scotland.
Disclaimer - I'm vegetarian so I'll be building a wood fired pizza oven when I have the time and find a good gluten free pizza dough recipe to keep my (coeliac) wife happy.
Rest assured my burgers are still hand patted on the thighs of virgins from 120% organic beef from cattle kept warm by a mixture of wood burning stoves (using responsibly sourced wood) an their future eaters sense of smugness in winter.
I just can't afford to shop at Fortnum and Masson at the moment so have to substitute with supermarket mince .
I see the argument for both, but come on now. Anyone who burns £5 of coal to cook a burger is an idiot and should probably not be allowed control of either a gas or charcoal cooking device, or sharp thing such as pens and screwdrivers.
http://www.garden4less.co.uk/proddetail.asp?PROD=HB16KG&partner=fr&gclid=COG2w4Cp29QCFUy77QodVLkEyg
£1.75/kilo. Great stuff, but there are cheaper and good options.
I mince my own from the butcher's chuck steak. You get a better texture and nicer flavour than from using supermarket mince, which is usually too lean and minced too finely to make anything close to a decent burger.
The best burgers I have cooked were 70% butchers mince (Morrisons since you ask, but very much like Ransos' recipe, dark red and very fatty) and 30% bacon (beaten up in the processor). Nothing else, and they took to being flipped very well.
Oh, and if wallop is still reading; Home sense have the Pitt Cue book at £8 reduced from £25. One of the better BBQ books I have. Which I paid full price for a year ago......
Who is this silly man (or woman) who's wasting the precious summer away?! Personally I ride home in the glorious sunshine & get in about 5.30 then fire up the coals with a chimney starter (google it as you've obviously never heard of one) which takes 15 minutes tops. 🙂Man (or woman) get's home from work at 7:30 and want's to enjoy the last of the sunshine without waiting till 9:30 for £5 of coal to burn to cook his £1 burger.
Depends what you are planning to cook and when I think.
I have a reasonable 4 burner gas BBQ (from Homebase - in a sale for about £200 and made of stainless steel) and a 46cm Webber kettle charcoal BBQ.
If I'm just cooking a quick bit of food in the week for the wife and I, or I'm cooking for quite a few people then it's gas all the way (sometimes supplemented with charcoal as well).
If I'm cooking something special or for 4 or so people and I have time I'll use charcoal. It's especially good for slow cooking joints of meat with an initial seat over direct heat, then the majority of the cooking over indirect heat.
No matter what anyone says I find food cooked on charcoal tastes more special / bbq'd. I have flavour bars on the gas BBQ and have experimented with smoker boxes but it's not quite the same. Although food on the gas BBQ does taste more bbq'd than something on the hob / in the oven etc.
If you go charcoal make sure it has a lid, and also buy yourself a BBQ chimney starter for lighting the coals. They really work and make starting charcoal bbqs pretty much foolproof.
Don't listen to anyone who tries to tell you gas is just like cooking on a hob outdoors - clearly it isn't as you are cooking with flames, not a hot pan.
£60 isn't a great budget for either type of BBQ - think the Webber I have is about £100 unless you find a sale and the gas BBQ was a lot more than the budget you've set.
Decide which fuel type you want to use and hunt the sales online and see what you can get. End of the summer is better for this - I got my Webber for £49 in a sale a couple of years ago.
Charcoal, and wood..
As a farmer mate of mine would say when asked how he'd like his steak done..'take off the horns and wipe it's arse'.
Charcoal everytime op.
This may be pedantry of the highest degree but BBQ needs to be an indirect heat (charcoal to one side (or both sides)of the BBQ and the food not in direct contact, or the gas burners only set for one side of the BBQ) and the lid closed.
Cooking over direct heat with no lid is grilling.
I have a weber charcoal - the one touch GBS big kettle - and I use it mainly to indirect cook big pieces of meat with lots of smoke - just eaten a salad with the remains of the brisket I smoked for 5 hours yesterday. It obviously grills very well too.
I also have a Cadac which I use as a gas grill and also have the griddle and other attachments.
The gas is really quick and easy to cook a steak etc so the kitchen does't get all smelly etc, still a decent charred and smokey taste. But the true, intense, BBQ flavour only comes from it's partner in crime.
Even if you don't want to do indirect cooking/smoking etc a lid really helps to speed things up and you can also buy a pizza stone and get some really good results - almost as good as dedicated pizza ovens
Don't waste money on charcoal things, dig a hole in the ground, get those disposable one offs, charcoal for the beach, out camping whatever, at home it's Gas, handy for when your brand new all singing all dancing electric induction hub keeps blowing the house electrics over Christmas when the entire family is down.
For many years I used to gas barbecue the Christmas Turkey (big bird for 8 of us) tasted way better than the conventional oven, we had one of those Outdoor Chefs, marvellous device.
