You'd probably need a lintel to support the brickwork above the door position but that's not a huge job, just need enough brickwork at the sides to support it. The area of brick that it's actually supporting is v small, so you wouldn't need an RSJ.
I assume the chimney is unused and capped at roof level? The remaining void really should be ventilated to avoid the risk of damp through condensation.
Jeff
Posted : 27/10/2015 1:18 pm
