What pressure should the air jacket of a pressure vessel be set at? The same as the boiler blow off threshold or higher or lower?
normally 0.5to 1 bar on a standard house, be sure to test pressure with the heating not under pressure, IE pressure relief valve opened.
£45.00 paypal gift will be fine thanks. 😆
set the pressure at 1 bar but it must be done when the system is depressurized
Less than the blow off pressure btw
But still I am a electrician so wtf do I know 😉
Cheers lads. Payment in kind ok? 🙂
Unless it's on the unvented hot water side of course.....................
cheers for the help guys.
With a car tyre foot pump I found that the plumber had installed a 3 bar pre-charged vessel on the system that should have been no more than 1.5 bar to prevent litres of hot water being dumped every night!
Recharged correctly last night and pressure now being handled correctly! Nice one!
connected to this chappie:
About 1,000 litres all in 😉
To be fair to the guys it's not a standard job and everyone's been learning as we go along so It's a pretty easy mistake to make as 1.5 bar blow-off valves arent that common as I understand.
