Plumbers help, very...
[Closed] Plumbers help, very hot water.
3 Users
Been helping out at Dad's house and noticed hot water was very hot. Had new thermostat fitted now set at 50 but water still very hot, when I turn stat it clicks around 70-80. Tank is about 20 years old.
Posted : 13/11/2014 8:59 am
How is the water heated? Is it an immersion with a stat on the immersion heater or via oil/gas (indirect cylinder) with a tank stat. attached?
Rich.
Posted : 13/11/2014 9:02 am
Immersion with stat on it, gas boiler. Ta
Posted : 13/11/2014 9:09 am
I think there will be a thermostat that links to the boiler that you need to alter as this is what normally heats the water - you've probably altered the electric immersion thermostat.
Posted : 13/11/2014 9:18 am
