Anyone got any warnings about the above engines reliability?
Fsh fsh fsh .. Run if the turbos been changed , get the oil pick up filter changed
If its got more than about 30 k on the clock and no history . Run
This is the same engine that's used in Fords too isn't it?
I have a 2003 (so pardon me if the following is useless!), the rocker gasket is a common issue as is the rear axle being a bit weak and the exhaust being made of tin foil. The comms unit fatigues results in a floppy indicator too which is cheap enough to source as it's uced in Citroens too.
Generally fine day to day. Sheffield to Brighton and back is about £45 in diesel.
If it's the DV6 engine; AVOID.
Injector No.3 seal blows (anywhere from 50K onwards) , results in incomplete combustion, oil sludges, lunches turbo.
Change seal, change turbo and REPEAT.
The ford fix for this is to strip the engine/turbo lube system, replace most of the thin pipes and gauze filters and flush repeatedly with clean oil. Even then its no guarantee.
