Pedantic English us...
[Closed] Pedantic English usage question
18 Users
Should the expression 'middle of nowhere' be hyphenated? To lay my cards on the table I'll say yes; middle-of-nowhere.
Posted : 22/06/2011 9:26 pm
How can a question be pedantic?
(See what I did there?)
Posted : 22/06/2011 9:27 pm
no
genius ^^^^^^ bot boring 😉
no
Posted : 22/06/2011 9:28 pm
the hyphen has a lot to do with general opinion about whether it's in common usage. With a hyphen it suggests it's new, without then it's common. So, in this case I say no hyphens.
Nope, it's the middle of nowhere.
Posted : 22/06/2011 9:30 pm
Do you hyphenate phrases such as Bob's your uncle?
Posted : 22/06/2011 9:31 pm
Hyphenating's good........do it as often as you can.
Is there any amiguity? If not, then I'd say no.
It took me ages to work out "average speed cameras".
Are the speed-cameras not particularly out of the ordinary?
Or, are the cameras to be used for measuring average speeds?
Posted : 22/06/2011 9:35 pm
However, if you use it before the nown as an adjective then hyphens can be used. "My friend bought a middle-of-nowhere retreat to get away from the madding crowd". Unless someone thinks differently?
Posted : 22/06/2011 10:01 pm
Depends on use; perhaps? In the middle of a sentence, as in Edukator's example, I'd say that hyphenation would be correct. If one was simply to say "the house is in the middle of nowhere", then I don't see the need for hyphens.
Posted : 22/06/2011 10:08 pm
What Edukator said. No other possible reason for hyphens.
Posted : 22/06/2011 10:18 pm
I don't believe the middle of nowhere exists so i think this thread is moot
Posted : 22/06/2011 10:21 pm
I dunno. I'm going to sit on the fence in a sit-on-the-fence fashion.
[url= http://www.englishforums.com/English/RulesForUsingHyphens/gqxx/post.htm ]Rules for using hyphens.[/url]
Posted : 22/06/2011 10:23 pm
of is in the middle.
Posted : 22/06/2011 10:40 pm
Thanks edukator, that's how I've used it..
Posted : 23/06/2011 8:16 am
 wl
Edukator and don simon are right - depends on context/ambiguity.
Posted : 23/06/2011 8:36 am
Drac - of is in the middle of the middle of nowhere. h is in the middle of nowhere.
Posted : 23/06/2011 8:42 am
If-you-use-gratuitous-hyphens-it-can-look-like-you're-speaking-really-quickly.
ADD-CAPITALS-AND-YOU-TURN-INTO-A-DALEK
Posted : 23/06/2011 8:43 am
 edd
I have a hyphen in my surname. I'm not sure if that helps.
Posted : 23/06/2011 8:51 am
Is it "The-Duck"?
Posted : 23/06/2011 9:00 am
 edd
Posted : 23/06/2011 9:02 am
Isn't h in the middle?
Posted : 23/06/2011 10:05 am
A white hole?
Posted : 23/06/2011 10:11 am
