Pdfs from Quark mis...
[Closed] Pdfs from Quark missing images
5 Users
Doing some work on old quark files, first artwork converted to pdf okay, but second one which is principally the same bar a few different images, is not displaying a couple of Illustrator eps files, another one of the eps files is showing which is baffling.
If I take the images off and put them on a blank sheet and pdf that, it works, . . . baffled?? So it doesn't appear the images are the problem?
Ideas?
Posted : 01/11/2011 10:27 am
Sorry no direct help but I have recently been updating some old PageMaker files to get PDFs off of them. Had to reset the target printer PPD which changed the layout and mucked up some embedded images, eps mostly from MathType equations. The layout changed too so kerning was out and all sorts.
Does Quark have the same "Target printer" dialog in the document set up settings? If the printer driver has updated this may help/hinder!
Posted : 01/11/2011 12:25 pm
try bringing them back in in a new picture box - remember quark was always funny at times, thank the lord for indesign!
Posted : 01/11/2011 12:27 pm
Quark has always been like this with PDF's. With my tin-foil hat on I think Adobe are engineering incompatibility with later versions of Quark. Its got worse, not better
Are they big documents? I know its a last resort, but have you thought about exporting the pages as eps files then converting them to PDFs from that. Its a bodge, but it'll work
Amen to that brother!!
Posted : 01/11/2011 12:31 pm
Ahh but you can't cmd/alt/shift/ctrl/delete in InDesign can you.
Posted : 01/11/2011 12:54 pm
dodgy eps, brought back in, all okay now.
Posted : 01/11/2011 1:38 pm
well bodged sir! 😉
Posted : 01/11/2011 1:41 pm
