PDF writer problems...
[Closed] PDF writer problems - help please!
hello.
i am trying to use Cute pdf to convert a document to PDF.
i have used this before, without problems.
but occasionally, which increased to frequently, and now every sodding time, i get a few pages converted, then a blank page, then an error report printed in the document that says:
error - stack underflow
offending command - stack.
wtf?!
please help, people's lives are at stake.
of all the things in the universe, i am only capable of truly hating computers.
Posted : 13/07/2010 9:38 am
What are you creating the document in, e.g. Word, Excel, etc? Which version?
Posted : 13/07/2010 9:40 am
1) Download and install OpenOffice.
2) Open document.
3) Go to file menu and choose "Export as PDF".
Posted : 13/07/2010 9:42 am
I use; http://www.primopdf.com/
Posted : 13/07/2010 9:45 am
Ox - i can't do that, i'm using a 'controlled document' - created in Word, which means the quality office at work will cut my balls off if i start using openoffice.
(it's not just as simple as 'open with swriter - export to pdf, i'd need to re-jig the formatting, which is a no-no with controlled documents)
but thanks for trying!
what i find incredibly frustrating is that it worked fine last week, no problems whatsoever.
Posted : 13/07/2010 9:49 am
might be obvious, but have you tried deleting and reinstalling cute pdf writer?
Posted : 13/07/2010 10:17 am
Although I don't know what a controlled document is exactly (and am willing to be educated), it is actually that simple - why should you need to re-jig the formatting?
But, you may also want to look at Primo PDF which is a free PDF writer - been using it for yars and it's great.
Worth a try if you're still stuck.
Posted : 13/07/2010 11:32 am
because when i open my word document in open office, it's gone all screwy - all the images have been overlaid in one box, all the text has been squeezed into one box, fonts and sizes have changed - that sort of thing.
this particular controlled document is an inspection report; i measured something, someone wants to read about it, i want to write a report for them, i have to do it using an approved template.
Posted : 13/07/2010 1:11 pm
Another vote for PrimoPDF. Been using it for years also, installs as a printer. Never had any problems.
Posted : 13/07/2010 1:35 pm
We use pdfcreator at work, worth a try? Might be easier to try something totally new rather than fix the problem
Posted : 13/07/2010 1:42 pm
I would uninstall it and reinstall it. I use Cute PDF too but no problems here.
Posted : 13/07/2010 1:46 pm
As I said above, which version (of Word?) If it's 2007, you can download a free PDF plugin - works a treat (with no watermarks or formatting issues).
Posted : 13/07/2010 2:20 pm
IF you read the OP, he is already using a PDF plugin, CutePDF, which isn't working for some reason. it doesn't matter which (year) program he is using to create the document as CutePDF serves as a printer like the Microsoft XPS creator.
Posted : 13/07/2010 2:26 pm
Are you on the latest update of cutepdf/ghostwriter? Using with Word 2007 and 2003 on XP and 7 here. No issues.
http://www.cutepdf.com/Products/CutePDF/writer.asp
Posted : 13/07/2010 2:28 pm
This gave me the impression the document (in template format or whatever) exists in Word ... perhaps I misunderstood ...
Posted : 13/07/2010 2:42 pm
If I get this right, you're using one document as a template and repeatedly overwriting it?
If so your master document may have corrupted.
Try creating a PDF from an earlier version/report, if it works then you know it's not your PDF creator.
And if it works, use that file as the template.
Posted : 13/07/2010 3:11 pm
