OSX experts - clean...
[Closed] OSX experts - cleaning up my mac
21 Users
I've been running my mac for 5 years now and I think it's time to ditch some of the rubbish hiding in the depths of my hard drive. Am a bit reluctant to just google 'mac cleaner' as I suspect that route will most likely lead to me dying in a fireball of porn. So here's what I'm after.
1 - Is there a good method/app for easily identifying big chunks of files I don't need and can delete happily? A bit nervous to just start zapping stuff if I don't know what it does but there must be a heap of crap I can dump.
2 - My iTunes library is a bit of a mess with duplicates and missing files. I've noticed there are a few apps available for dealing with this but can't really tell if any of them are any good.
Thanks in advance for any advice.
Posted : 22/04/2016 8:56 am
It costs a few quid, but I've been using 'Clean my Mac' for years. There is an add-on called Gemini, which looks for duplicates.
Seems to work well, and I just set it to try to run a clean every week or so - typically cleaning a 1-2 GB, but sometimes a lot more if I've been working on a video or editing a lot of images.
Posted : 22/04/2016 9:55 am
I've used Grand Perspective for years to help free up disc space
http://grandperspectiv.sourceforge.net/
It's a bit odd to start with but you soon get the idea. Set it to scan your whole hard drive. It represents all your files graphically by size so you can spot what is taking up space. I've often been able to clear out large chunks where I'd left an imported movie or similar.
It won't tell you what is safe to delete though but some things are obvious, like video files or music etc.
Posted : 22/04/2016 11:41 am
+1 on Grand Perspective.
Realised I'd left loads of GoPro footage on the SSD the other day for editing then wondered why I'd only got 8GB left...
Prompted me to move/delete about 100GB of other crap which I'd not moved to slower storage.
Posted : 22/04/2016 11:47 am
DaisyDisk is great for identifying chunks of space taken up on your HDD [url= https://daisydiskapp.com ]https://daisydiskapp.com[/url]
Cocktail is great for running maintenance and cleanup scripts [url= http://www.maintain.se/cocktail/ ]http://www.maintain.se/cocktail/[/url]
App Zapper is great for removing apps and their associated files [url= http://www.appzapper.com ]http://www.appzapper.com[/url]
Firstly in my HUMBLE opinion Mac's don't need to be "kept clean" like Windows machines as the OS does a good job on it's own. That being said I used Clean my Mac once and tbh I found the main thing it did was delete lots of very small driver/log files and empty the trash and most annoyingly the Downloads folder (I had downloaded stuff but not filed it elsewhere)
I am a bit out of touch but the old iPhoto app used to make a duplicate inside the Library of every file you imported. These days it makes sense to upload photos somewhere with large amounts (e.g. 1TB) of free storage assuming you don't have copyright issues.
There is another app called OmniDiskSweeper I use occasionally to find where all my storage was going. The main thing it flagged up was the backups of iPhone and iPad which I backup via iTunes. As my Phone/Pad are 64GB these backups are pretty large, its easy to forget how big the phone is relative to the Computer disk.
Posted : 22/04/2016 11:52 am
OmniDiskSweeper is a nice simple tool for seeing where all your space has gone and deleting files.
In general I really wouldn't worry about build up of small files (old preference files etc.), OS X is very resistant to that type of slowdown-due-to-cruft.
iTunes. Personally I'd pay for Apple Music, get all the files matched/uploaded to the cloud, backup all your stuff to an external drive and then delete all the files from the mac.
EDIT: ie. basically exactly what the dude above posted while I was writing that!
Posted : 22/04/2016 11:55 am
Thanks all. To clarify - I just want to get rid of files I don't need any more and suspect that 5 years of daily use has generated a bit of fluff that can be gotten rid of. Will have a look at the suggestions.
For iTunes - my library was originally imported from a knackered windows machine and there seems to be loads of duplicate files or just missing files. I know I can sort this manually but life is too short - does anyone have any experience of something like Song Sargeant (or something free that does the same job)?
Posted : 22/04/2016 12:17 pm
I just copy what i want to a hard drive, wipe the OS and then reinstall the OS then shove what i want back on.
Posted : 22/04/2016 12:47 pm
Just to hijack slightly, my Mac is running a lot slower than ever before, lots of wheel spinning especially on start up. Of the suggestions above is there one that would specifically root out the cause of the slow down?
Posted : 22/04/2016 12:55 pm
 kcal
Disk Inventory X seems very similar.
Posted : 22/04/2016 2:27 pm
Used th free trial of Disk Daisy to find all kinds of crap I don't need any more. Freed up another 50gb!
Posted : 22/04/2016 6:18 pm
Morning all
Bit of a thread resurrection. Any thoughts on on johnj2000 question:
I'm having the same problem. System spec as follows:
iMac (27-inch Late 2009)
Processor - 3.06 Ghz Intel Core 2 Duo
Memory - 4 GB 1067 Mhz DDR3
HD - 1TB, 598GB unused
OS X El Capitan 10.11.4
Ta in advance
Posted : 18/05/2016 7:07 am
Feed it more RAM
Posted : 18/05/2016 8:18 am
Yes, more RAM.
I create a Mac OS boot SD card and completely wipe the disk every year or so. Then reinstall the Mac OS and restore my home folder from Time Machine backups.
Takes an hour or so and keeps my 2012 MacBook Pro really speedy.
Rachel
Posted : 18/05/2016 8:54 am
Feed it more RAM
Feed it an SSD, I'd have thought.
Point of note, neither does Windows.
Posted : 18/05/2016 9:04 am
I'm not an expert but here's my 2 cents
In my experience with Mrs B's Mac Book Pro more RAM alone will make little difference (took hers from 4 to 10)
@beamers (and probably @john too) yoir problem is likely to be an old / wearing out hard drive. I assume its on the original drive spinning at 5400rpm and at 6 yes old it's tired (Mrs B's machine was 2012 and this was the case)
Download Blackmagicspeedtest and run it. My guess is you'll see 35-40 as read/write speed. I put a Western Digital Black 750gb Hard drive running at 7200rpm in my 2009 Mini and it scores 100-110. The Samsung Evo SSD I put into the Mac Book runs at 225
I have done 4 disk replacements and RAM upgrades (Mini and 3 Macbooks oldest 2008) not too difficult and the disks make the biggest difference certainly once you have 4gb ram minimum. The iMac looks a bit more tricky on YouTube as you have to take the screen off but still do-able at home. Then you have the software install/cloning/restore from backup.
A 500gb SSD is about £100. @Beamer you might look at a 1tb hybrid drive (mix of ssd and spinner with the os on the ssd bit) or payup for a 750 ssd. RAM is easier to add than drive, I found ine 8gb chip cheaper than 2 x 4 so took out one 2gb and out in the 8 to go to 10 = 2 + 8. Cost about £60. Drive is more important. You need a small phillips screw drive and a torx 10 (£3-ish) and for the imac suction cups (not sure if you can bodge without, watch videos)
If you are interested we can discuss on here or you can get a commercial quote (components + £100?). @John I'm not around Hampshire for a bit or I'd offer to help.
Posted : 18/05/2016 9:06 am
Agree.
Chances are they have a 5400rpm drive spinning away in there. The only issue is drive swapping on an iMac is a pain, [url=
impossible[/url], but a pain.
The fact Apple were still shipping their 2013-2014 iMacs with a 5400rpm drive was a joke.
Thanks all. Really helpful advice.
Posted : 18/05/2016 9:15 am
Agreed, my 7200rpm drive was pretty cheap in 2012 and is high quality. I can't understand why they persist with the 5400 ones
Posted : 18/05/2016 9:20 am
@beamers - make sure you are backed up via time machine or at least photos (flikr ?) and key docs (dropbox, google ?) to the cloud. Sooner or later your drive will expire
Run the blackmagic and post resukt here if you wish
500gb SSD £110
1tb SSD £225
1tb hybrid £100
I have 750gb 7200rpm imo not worth it for you go ssd, cost £65
You can add an external drive 1tb for backup etc for £60
You can buy a usb caddy to old your old disk in for £15 so you can still use it
Posted : 18/05/2016 9:21 am
Yep, all backed up on on TV, dropbox, Flickr etc. Original drive was replaced under warranty in 2012 so there should be a bit of life left in it.
Posted : 18/05/2016 9:31 am
It's old - get a new one!
Posted : 18/05/2016 9:36 am
@beamers cool. If you decide to get a replacement machine (@muffin 🙂 new retinas are amazing) instead I may be interested in your current one as a project. IMO for most of our usage your machine has ample horsepower, fabulous screen just the drive which is now really dated performance wise.
Posted : 18/05/2016 9:55 am
cocktails good, but RAM is the answer, then don't bother about it.
Posted : 18/05/2016 10:21 am
@muffin new retinas are amazing
They are - I'm sat in front of one right now!
Posted : 18/05/2016 10:23 am
@jambalaya - No plans to change the machine at the moment. No funds for that kind of expenditure at the mo.
Trying to get into the App store at the moment to to download and run blackmagic. I'll share the results when I have them.
Posted : 18/05/2016 10:33 am
@muffin g1t !
4 to 10 RAM made virtually no difference to 2012 MBP, transformed with an SSD
@beamers I hear you ! £100-200 spent and it will be faster than many brand new machines. Boot up goes from 2-3mins to 20-30 seconds and new programmes open almost instantly
Sweepstake ... 37 😉
Posted : 18/05/2016 10:38 am
Read 79 (max) / write 51 (max)
Posted : 18/05/2016 11:41 am
jambalaya - Member
@muffin g1t !
Sweepstake ... 37
Edit, "RAM's the easier answer", obviously, SSD is better, if you can be arsed reinstalling or cloning and swapping over.
Posted : 18/05/2016 12:24 pm
The big pain though is actually *getting* to the disk. It's fiddly on a 2009 iMac (I have the same 27" model and don't want to open the damned thing). No USB3 or Thunderbolt so no external booting via fast media. Firewire 800 wouldn't be fast enough either.
I'd love to put an SSD in my iMac to speed it up.
The next machine will be one where I can get into it. I love my mac but it's just too locked down, hardware-wise.
Posted : 18/05/2016 1:06 pm
Tick
Posted : 18/05/2016 1:21 pm
@Adam then pay a specialist who has the tools and has done it before - OP had his changed by Apple already so its not that hard. I do appreciate the concern about messing it up, did my Mini first and getting into it with a wallpaper "slice" as recomended was the worst bit, that and a screw which wouldn't budge - fortunately I was able to cut the plastic with a kitchen knife and release it - bodge city 😯
@seaso my point was that RAM alone made virtually no difference to my wife's MBP. It's my view if you have at least 4GB that will be the case. My 2009 Mini and friends 2008 MBP had only 2gb so then going to 8 and 4 respectively did make a difference. Even with 4gb if you look at activity monitor memory pressure for email/safari/basics its low and the chart is green. I think it would pretty much be a waste of money for @beamers to stick in another 2+8=10 or 4+4=8
Posted : 18/05/2016 1:34 pm
I upgraded the RAM from 4Gb to 8Gb on my 2011 MBP and there was a noticable difference in terms of number of programs I could keep running but it wasn't mind-blowing.
Putting an SSD in was like having a brand new machine.
Posted : 18/05/2016 1:44 pm
^^^ this
Posted : 18/05/2016 3:41 pm
It depends how intensely you use your computer tbh.
Posted : 18/05/2016 3:56 pm
It does of course and although my keyboard gets a good workout on STW that's not using much processor or the RAM 😀
Posted : 18/05/2016 4:21 pm
So while the experts are here - I've got a late 2009 macbook (white - well off white now) not a pro, what is the max ram you can put in there? I've currently got 4GB, but I'm sure I read a while ago I could go up to 8GB, but I've had a google & cannot find any info to confirm this.
Posted : 18/05/2016 5:56 pm
@PJ if you get serial number from "About this Mac" there is a tool on the Crucial site which will tell you. FYI Apple often understate max RAM - no idea why
EDIT: just use this ... [url= http://uk.crucial.com/gbr/en ]Linky[/url]
As above imho you'll better off spending money on an ssd - £65 for 250gb or £110 for 500gb
Posted : 18/05/2016 6:27 pm
OK so I have run the black magic test and am getting between 79 and 92 for write and a steady 85 for read. What does this tell me?
Posted : 20/05/2016 8:53 am
@JJ - I think its telling you that the drive is pretty slow. I've just run it again on mine and its showing 45 for write and 33 for read. [url=
dude[/url] (video content) swapped his drive for a SSD and he's getting getting 217 and 264!
Rewind that video to see the steps he goes through to change the drive. I'm tempted to have a go at it.
@jambalaya - Where do you source your drives from?
Posted : 21/05/2016 9:08 am
@john those numbers are ok. An SSD upgrade will transform your machine anyway but if its slow its not becasue of the disk. @beamers yours are rubbish (as per Mrs B's MBPro) as you/we suspected (johns machine is running at c2-3 times your disk speed)
Drives bought off internet - mine in France from RueCommerce but any decent seller will do. I go for Samsung 850 Evo's (Pro's are Sata 3 which will run in your Sata 2 machine but you won't see the benefit). I would suggest buying a usb caddy too £15-ish as it helps setup and you can re-use your old disk if you want
If you are going to do it make sure you have a full Time Machine backup - there are then a few options
SSD should be formatted via Disk Utility or a start up mode utility - OS journaled extended, guid partition (ie bootable). I tend to call mine Macintosh SSD - so I don't get confused
1) Use SuperDuper or Carbon Copy Cloner (free trial) to create a full clone of the drive in your machine - SSD in caddy, this will take hours
You can test this by booting from the ssd before you put it in the machine (lookup startup key options on apple support site). When you know it boots put it into the computer. Old one will still work in caddy if required.
2) create a usb thumb drive boot disk (needs about 5gb stick I think, mine is 8). Again apple start up modes has a tool to do this. Then put new ssd into machine and boot from usb into startup mode, you can then do a restore from time machine or a fresh osx install from internet and copy what files you want from backup
The advantage of restore from time machine or clone is all yoir accounts, passwords, setup info is copied over - you just have a much faster machine but otherwise "identical". I have done all 3 varieties (clone, time machine, fresh) only did fresh as my daughters disk died and she only had a backup from a year ago so we weren't too bothered to get a complete copy.
As you saw plenty of online videos and how to tips. Its useful to have an tablet or phone handy to rewatch videos when the mac is in pieces ! Torx needed, plus the fingers and eyesight of a young Chinese factory worker.
Posted : 21/05/2016 9:57 am
Thanks for all of that info - most helpful indeed. I'll post up if / when I go for it.
Posted : 21/05/2016 10:19 am
Obviously check other sources for advice etc as I'm just some bloke off a bike forum and wouldn't want to be responsible for the death of your iMac 😳
475 / 508 aee the results today from Mrs B's 2012 Mac Book Pro Samsung 850 EVO 500GB - bit surprised as I know Sata 2 throttled it to 250 max, what do I know ... turns out the machine is Sata 3 !! Bootup from "cold" is 25 seconds
Posted : 21/05/2016 11:46 am
Well, obviously.
You seem like like a trustworthy chap though and I've not had any duff advice of this fine forum yet - and I've been asking questions since it all started.
Posted : 21/05/2016 12:53 pm
Thanks to everyone on this thread. It inspired me to get off my arse and upgrade The memory of my late 2009 iMac
Now 12Mb instead of 4... Easiest memory upgrade I've ever done. The mac mini was a mare.
Much better. Had slowed to a crawl...
Wish I could speed up my five year old iPad ...
Posted : 21/05/2016 5:17 pm
@Strato cool, now for kicks BlackMagicSpeedTest 😉
Posted : 21/05/2016 9:27 pm
@stoatsbrother - What did you put in? Did you just stick another 2 x 4GB on top of the 2 x 2GB that were already in there?
Posted : 22/05/2016 7:28 am
@jamba you are hereby forgiven some of your other sins 🙂
Posted : 22/05/2016 8:26 am
8) (edit: my experience of forgiveness is that it has a short half-life)
@beamers you don't [b]need[/b] matched pairs or even (i think) and even number of chips - if you have 4 slots you can do 2+2+8 in my experience one 8gb chip was cheaper than 2x4 In theory matched pairs are faster but in practice it makes no difference to our usage
Posted : 22/05/2016 9:43 am
so where am I now? Tonight I wanted to open a word doc, it took about a minute to open, same with email. Browser opens quick and loads pages fine, but then back to a Microsoft product like excell and it takes forever???
Posted : 22/05/2016 11:17 pm
@jj - I have the same issue with mine. Once its up and running its fine but I have to wait ages for MS Office programmes to load up.
I downloaded [url= https://itunes.apple.com/gb/app/memory-monitor-speed-up-your/id748212890?mt=12 ]Memory Monitor[/url] for mine which threw up the following result:
Its got 4 GB of memory in it at the moment and pretty much all of it is in use!
@ Jambalaya - thoughts?
Posted : 23/05/2016 8:17 am
That's a good thing. OS X is designed to make use of all available memory, no point having it and it not being used!
Posted : 23/05/2016 8:34 am
^^^That makes a lot of sense!
Posted : 23/05/2016 8:56 am
Mac OS X will pretty much use all the memory you have available - it doesn’t necessarily mean you have too little. It has a lot of functionality to keep things in memory that would just be pulled from (slow) disk otherwise.
Mind you, when what’s basically a jumped up text editor is taking up 1.5GB, then the World is a messed up place… #bringbackvi
Rachel
Posted : 23/05/2016 9:05 am
