Orange 5 (Do you th...
[Closed] Orange 5 (Do you think a 50mm stem will work?)
11 Users
do you think a 50mm stem and 710 bar combo would be a good choice for a 5?
Posted : 04/10/2010 6:42 pm
 rhys
My 40mm stem and big earl bar works a treat
Posted : 04/10/2010 6:56 pm
will it not make the cockpit feel cramped?
Posted : 04/10/2010 6:58 pm
How tall are you and what's the frame size? I run a 70mm stem on my 16" 5 and am 5'7" in my best heels, cockpit feels perfick for me. I did contemplate a 50mm, don't see why it wouldn't work.
Posted : 04/10/2010 7:17 pm
 rhys
5'7 on a tall day. 16" frame. Admittedly saddle is right back as it always was on an online seatpost. Changed the type of stuff I was riding so I ditched the xc length 90mm stem. Thought my climbing would suffer but not in reality. Made a big difference on super steep stuff. Get a £22 Hussefelt one off CDC or the classifieds and try it out.
Posted : 04/10/2010 7:22 pm
im 5ft 10 i8inc frame size.
Posted : 04/10/2010 7:32 pm
It depends on what height/shape you are. Just buy a cheap stem and whack it on to try it. Or take it to your LBS and ask nicely to try a few different stems.
Posted : 04/10/2010 7:33 pm
As above you can only really tell by trying a couple, if you have a friendly LBS I'm sure they'll loan you one to try.
Gut feeling is that a 50mm might be a bit short at that height on an 18" frame, but I know nowt!
Posted : 04/10/2010 7:42 pm
i'm 6ft on an 18" five. I have a 70mm, tried a 60mm and it was great going down but a bit short on the climbs. Bars are 711mm
Posted : 05/10/2010 4:14 pm
am 6' with an 18" 5
I run a 50mm stem but needed a Thompson lay back seat post for XC duties.
why run such a short stem when I have to run a layback.
cos its just brilliant on the downs. used to run a 65mm stem which was fine, this is better
Posted : 05/10/2010 5:05 pm
My advice would be that whatever bike your using, you should have a 50mm stem and bars to suit. That way your weight is in the right place for riding fast.
Posted : 05/10/2010 5:25 pm
I am 5ft 11 and i ride an 18inch Orange 5 AM
and have a wide bar with a 65mm sunline zero rise stem.
I have thought of using a shorter stem as above it puts
you in the right position and great for attacking the trails
and descents.
Think you put the same question on bike radar
I answered there under a name called Black
Posted : 05/10/2010 7:17 pm
what geetee says, I use 50mm with 685 bars and one spacer between clamp n headset and its bang on. I also have a layback post which when raised opens up the reach for xc just right for me.
Posted : 05/10/2010 8:25 pm
i'd be inclined to run either 70mm stem with those bars or 750mm bars and 50 mm stem. which is what i'm running on a 456 - i'm a similar height to you too.
Posted : 05/10/2010 8:59 pm
have tried of few bar widths and stem lengths on my 18" five and settled for a 50mm stem 710mm bar as this combo suits my local regular route of long techy but not very steep UPS and steep,long,rock gardens and 2/3 foot drops on the DOWNS.
