If, ahem, a friend came up to you and he had found himself [i]accidentally[/i] cultivating a WifeIrritator [i]TM[/i], what would you recommend he use to avoid the Ed Oxley look? Cost is a key point here as the growth may not make it beyond his wedding anniversary.
Wahl? cheapo chinese ebay junk? FlyMo?
10 scottish pounds from [url= http://www.theglamourshop.com/wahl-100-series-clipper/?gclid=CKuXsY7u0bUCFVDMtAodlQwAQQ ]the Glamour Shop[/url] - what's not to like?
[i]This 11 piece mains operated home haircutting kit gives you all the tools & accessories needed to give a stylish, complete haircut at home, easily. The thumb adjustable taper lever gives you multiple cutting lengths without changing guide combs. The four guide combs allow you to cut hair to the desired length confidently.[/i]
What, you mean you've become both ginger AND a rather over-rated front row forward overnight? Good work, Stoner!
EFF off overrated!! 🙂
GINGER 😯
more a smorgasbord of ginger, brown, black and grey ( 😯 'kin hell that start happening? )
Anyway, wahl looks a safe'ish bet. But he cant have a mains one geoff, as [s]I[/s] he probably needs the sanctuary of the shed to do it in
£10 on ebay
http://www.wahlstore.co.uk/wahl-groomsman-rechargeable.ir?cName=personal-care-hair-trimmers
I find my cheap trimmer get clogged up after a few uses the easiest way to clean has been to blow it out with an airline.
I've had a couple, both came from TK Maxx's bargain bin. First was Wahl, was great until the battery died (but still works so long as it's plugged in), second I think is Remmington or something.
My airline is right next to the Head & Shoulders, above the aspirin and under the mirror too.
Another TK Maxx buyer here, although I could have done with a strimmer last week to remove my six month overwinterer.
Cougar - Moderator
Can that invert your nipple? If not it doesn't count.
Beards are in at the moment it seems. There appears to be a lot of hairy men in my life at the moment
Beards have always been in. Fashions come and go, style lasts forever.
[url= http://thechapmagazine.co.uk/content/section_manifesto/index.html ]See Rule 10 of the Manifesto. [/url]
