oh and the identical HTML rendered correctly from the old server, so it must be something in the headers...
Date: Fri, 04 Mar 2011 21:51:43 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Thu, 03 Mar 2011 00:07:59 GMT
Accept-Ranges: bytes
Content-Length: 7219
Connection: close
Content-Type: text/html; charset=UTF-8
200 OK
It's a character encoding problem - your server is saying it's unicode. Either rework your html to unicode or change the AddCharset/AddDefaultCharset setting in Apache config.
You could try something like this in your .htaccess file:
AddCharset iso-8859-1 .shtml .html
or declare the character set in the HTML template you use. That would have the same effect.
Actually, I think declaring it in the HTML template is better practice but I'm prepared to be shot down in flames over that...
Rachel
ah, thanks
like I said the same HTML rendered correctly on a different server...
I always use...
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
I've capitulated and used & pound; 🙁
as it goes, your character renders a bit oddly on this website too Simon. 😀
*hee hee*
ow ow my sides have split!
