OCR help
[Closed] OCR help
14 Users
I've got an image which I want to run through some OCR software. I've tried a few online tools now and they kinda work but are inaccurate. What I'm converting is code rather than real words (which might be contributing to throwing out the online converters) so it needs to be accurate. Short of me going through it and checking manually, has anyone got any recommendations for [i]reliable[/i] OCR tools? Or even, has access to something a bit more robust than random website who would be able to process it for me?
Cheers.
Posted : 07/10/2017 5:41 pm
If you can paste it into MS One Note that'll do ocr, not tried it on code though.
Posted : 07/10/2017 5:49 pm
For code I'd be inclined to just type it in. You'll probably waste more time getting the OCR to work properly and fixing errors.
Posted : 07/10/2017 5:51 pm
Ooh, that's handy, I didn't know that. Doesn't work in this case though (it was considerably worse in fact).
I've never used anything that's been fantastic or not required significant work after :(. Have you tried Google Drive yet? I would expect them to quite good really seeing as how good they are at finding random text in my photos
Bugger that. It's not program code, it's code code - it looks like it could be Base64 encoding. (The purpose of the exercise here is to work out what it is and then try to decode it.)
Posted : 07/10/2017 5:53 pm
Is it a good sharp image, with good contrast, etc? If not, that's probably one reason why OCR is struggling. If not, can you enhance the image? Some OCR (I think) will favour letters that make dictionary words, whereas your code will be random, so you may need a very basic OCR that doesn't try to be clever. But I suspect any wrong characters at all will make the code unrecognisable, and 100% correct OCR is rare.
Posted : 07/10/2017 6:09 pm
Trying Google Docs, it's been spinning for about 10 minutes so far.
The image isn't bad, suppose it's all relative.
Sure. I just hoped technology had moved on since I last tried anything like this.
Posted : 07/10/2017 6:14 pm
Don't fancy your chances. I've only ever used acrobat pro to ocr it's never 100% can be decent though. Image quality/orientation/straightness/sharpness is usually a big factor. But even very high Res stuff can fire up loads of errors. I think some typefaces are probably easier that others.
Posted : 07/10/2017 6:42 pm
I do a bunch of OCR processing on scanned pdfs at work - a mixture of type and handwriting - there's a fair bit of short-hand in there (trading strategy codes ie. strikes, instruments etc). It utilised Tesseract-OCT and is pretty accurate - though it can struggle with some non-alphanumeric characters (ie. bracket types can be a PITA).
Not sure if there are any online instances you can use though.
Posted : 07/10/2017 6:54 pm
Modern OCR algorithms tend to work on recognition and then comparison to a dictionary. Great for words, but not so great for random characters.
Posted : 07/10/2017 7:19 pm
Post it and let the nerds on here have a go.
Posted : 07/10/2017 7:20 pm
https://imgur.com/Ekf2s8V
Posted : 07/10/2017 8:30 pm
There are errors.
qANQR1DBwU4D/TlT68XXuiUQCADfj2o4b4aFYBcWumA7hR1Wvz9rbv2BR6WbEUsy
ZBIEFtjyqCd96qF38sp9IQiJIKUNaZfx2GLRWikPZwchUXxB+AA5+qsGELBvRa
c9XefaYpbbAZ6Z6LkOG+eEOXASe7aEEPfcdxvZZT37dVyiyxuBBRYNLN8Bphdr2zv
z/9Ak4/0LniJRk?5/2UNE520a-31cvIT?mfGajv?hk?q?cav??Kiin3hv7+V?88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=MpRf
It's 85-90% there I think.
Posted : 07/10/2017 9:00 pm
qANQR1DBuU4D/TlT68XXuiUQCADf§2o4b4aFY8cHumA7hR1Hvz9rbv2BR6UbEUsy
ZBIEFtjYqCd96qF38SP9IQiJIKlNaZfx2GLRHikPZHChUXXB+AA5+lqSG/ELBVRa
c9Xef aYpbbAZ6z6LkOQ+eEOXASe7aEEPfdxvZZT37dVyiyxuBBRYNLN8Bphdr2zv
z/9Ak4/0LnLiJRkos/2unEszoa+3lcvlrnmfeajvRhkxqocavpoKiin3hv7+vx88
uLLem2/fQHZhGcQvkqZVqXx8SmNu5gzuvujv1HHj9muDGBYOMkjiZIRI7azVnoU9
3KCnmpR60vOArDRASSuGl9fioSvze+q8XqxubansgdKkoD+t8/AukcktznLfu1L2
YBS+dzFDH5deSHFSo7JkecAS4N89jAU9K+f7PTASeSCBNETDd49BTOFFTUUavAfE
gLycprcnLs3EriUgvL30zpRAp1 chnu6sa32JkTBbriDoA3vpnqG3hxqfnyolqAka
MJJuQ530b9ThaFH8YCE/VqUFdH+bQtrAJ6Npjlxi/xOFfOlnhC/bBH7PDLX8FNaX
HdlLQRPQdrmnUskKznOSarxq4GjpRTQo4hpCRJJSaU7tZ09HPTZXFG6iRITOwa47
AR5nvkEKOIAjUSHaDKiJriUULdtN40XeCUVXFSjR32ebZ76U8aLPAK87GZEYTZBX
dV+lHOhuyT/y1 c2Q/E5USePP4oKHF4uqquPee10PeFMBoACvuGyh2XD/18Ft/S3Y
HlebvdicqsooabK3jEfdGExce63zDIo=
=MpRf
Errors here too 🙁
ZBIEFtjyqCd96qF38sp9IQiJIKlNaZfx2GLRWikPZwchUXxB+AAS+lqsG/ELBvRa
c9XefaYpbbAZ6z6LkOQ+eE0XASe7aEEPfdxvZZT37dVyiyxuBBRYNLN8Bphdr2zv
z/9Ak4/0lnliJRk05/2UNESZ0a+3lcviTMmfGajvRhkXqocavPOKiin3hv7+Vx88
ullem2/fQHZhGcQvkqZVqXx8SmNw5gzuvwjV1WHj9muDGBY0MkjiZIRI7azWnoU9
3KCnmpR60V04rDRAS5uGL9fioSvze+q8XqxubaNsgdKkoD+tB/4u4c4tznlfw1L2
YBS+dzFDw5desMFSo7JkecAS4NB9jAu9K+f7PTAsesCBNETDd498TOFFTWWavAfE
gLYcPrcn4s3EriUgvl30zPR4P1chNu6sa32JkTBbriDoA3VpnqG3hxqfNyOlqAka
mJJuQ530b9ThaFH8YcE /VqUFdw+bQtrAJ6Npjlxi/x0FfOinhC/b6w7pDLXBFNaX
HdlLQRPQdrmnWskKznOSarxq4GjpRTQo4hpCRJJSaU7tZ09HPTZXFG6iRIT0wa47
ARSnvkEKolAjWSHaDKiJri uWLdtN40XecWvxfsjR32ebz76U8alpAK87GZEyTzBx
dV+lH0hwyT/y1cZQ/ESUSePP4oKWF4uqquPee10PeFMBo4CvuGyhZXD/18Ft/53Y
WlebvdiCqsOoabK3jEf dGExce63zDI0=
=MpRf
no idea if there's errors, i'll let you check! acrobat. probably sees the likes of those lower case "el's" as upper case "eye's" so need to be careful of things like that.
Posted : 07/10/2017 9:05 pm
Yeah, I did it with errors too, hence the question in the first place.
Posted : 07/10/2017 9:07 pm
That Acrobat one looks to be the closest yet. In fact, at a glance I think the only errors are extra spaces.
I'd need to check it manually to be sure, but that's a great start. Thanks.
Posted : 07/10/2017 9:09 pm
check my edited comment, need to keep an eye on that and other such possibilities, zeros and o's for example. etc..
Posted : 07/10/2017 9:11 pm
Aye, ta. It doesn't decode into anything sensible so that might be the case.
Posted : 07/10/2017 9:12 pm
no worries, good luck!
Posted : 07/10/2017 9:16 pm
Just an update to this if anyone cares.
Someone else typed it in manually. I compared it electronically with Joe's OCR effort and highlighted differences, which made it easy to check mistakes. I believe I now have an accurate copy - if it's wrong, then we've both got it wrong in an identical manner.
Thanks again. (Now I just need to try and decode the bugger.)
Posted : 08/10/2017 3:37 pm
how many differences did that comparison pop up?
Posted : 08/10/2017 3:40 pm
And another question just out of sheer curiosity, what would you expect that amount of code to decode to? just the same amount of legible text, alot more/ less?
I know if you get code like that for an image there's always millions of it. so i wouldn't expect there's much actual info behind that code?
Posted : 08/10/2017 3:45 pm
There was one mistake in the manual transcription (next to last line, can't imagine why...!) and four I think in the OCR (not including the two rogue spaces I'd already spotted).
I thought it was Base64, which would return a block of text half the size of the original. But it'd seem I'm barking up completely the wrong tree.
The thing is a puzzle that's been posted on a Facebook group (for "escape room enthusiasts") with no preamble or context other than "what do you think?" It could be a bloody Magic Eye picture for all I know.
Posted : 08/10/2017 3:59 pm
Incidentally, here's the corrected output, if anyone is feeling inspired.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=MpRf
Posted : 08/10/2017 4:06 pm
cool, 4 plus spaces is not bad at all, better than I usually get from text I've ever needed to OCR, good stuff.
Sounds interesting, absolutely no use to you there, I know nothing about code. I did one of those escape room things once, was alright, I found it quite hard though. I unwittedly cheated my way out the cells they locked us in through brute force, I thought that was how we were ment to get out, woman came in absolutely puzzled, how'd you get out there? 😆 I asked her if that was the fastest anyone had every got out the cells!
Posted : 08/10/2017 4:12 pm
As I said, I've no idea whether it's actually code, it just looked like it.
I'm slightly addicted to escape rooms, I did my 13th one on Friday with my [s]minions[/s] apprentices from work. They did well.
I've got an opposite "jail-break" tale. I did one where you start all handcuffed together. You're supposed to get the key fairly early on in the proceedings but we missed something obvious so completed the entire room chained up to each other! Worse, the GM was inattentive and didn't notice we'd got out, so we were wandering around the corridors and reception still chained together...
Posted : 08/10/2017 4:17 pm
I was wondering, because it's been posted as an image, that would maybe possibly suggest that it isn't ment to decode digitally, so possibly some visual decoding you can do on it to find a message? nothing pops out though, i don't really see any obvious patterns.
Posted : 08/10/2017 4:22 pm
I'd agree. But I couldn't see anything of use either, which is why I resorted to this tactic.
Oh, how did you 'brute force' the room, incidentally?
Posted : 08/10/2017 4:42 pm
5 mins with google will tell you A) what it is, and B) what it says.
This may or may not be cheating.
[i]Hint: it's encrypted[/i]
Posted : 08/10/2017 4:52 pm
Cheers.
Like I said earlier, it looks like Base64 encryption to me. But it decrypts to gibberish so it presumably must be something else.
Posted : 08/10/2017 5:01 pm
They lead us into the room blindfolded, put us into 3 cells. I was looking about everywhere to get out, was actually just going to climb out at first, but I thought that unlikely to expect people to do that. Next I was looking at the electricity box high up, as I saw the cells were magnetised(just as well I didn't start on that, I nearly did! ), but then I spotted this half sawn plumbing pipe on the wall, i looked through it and saw a button at the other end, the rawl plugs on the wall holding the thing in where a bit wonky so I assumed you just had to shove this thing and press the button. bingo, all 3 cells opened, woman came running in! 😆
Apparently we were ment to do some sort of trick with 3 ropes and a basket and get a pole of something from somewhere, never quite got it exactly, but it involved all of us working together. Overall it was alright though, good laugh, was only a small part of the game, so it never spoiled it. We eventually got out with a few minutes to spare. was close though, if I hadn't done what I did I doubt we'd have made it in time.
Posted : 08/10/2017 5:05 pm
Hah! I've done that room, I know exactly what you're describing. I was actually in the same cell as you when we played.
Posted : 08/10/2017 5:10 pm
I never even registered the basket and ropes!
Posted : 08/10/2017 5:12 pm
Which venue was it at? They've got a few locations.
Posted : 08/10/2017 5:13 pm
In glasgow, just behind paisley road west, in some auld industrial unit. Think they've got other rooms in the city centre aswell.
I don't think they anticipated my kinda lateral thinking! 😆
Posted : 08/10/2017 5:14 pm
That sounds more fun than the Base64 thing :), need to see if we have any here
Posted : 08/10/2017 5:17 pm
It's worth a go aye, don't think I'd gor for drac level 13 times mind you 😆 , but aye, I'd try another room.
Posted : 08/10/2017 5:18 pm
Could it be base64 but with the final 4 characters acting as some kind of key/offset?
Posted : 08/10/2017 5:20 pm
Yeah, the one we went to was Manchester. But this is probably a conversation for a separate thread. (-:
I've no idea how, but I think you're right, those last 4 characters are "special" somehow. The trailing = at the end of the body text is distinctive Base 64 filler, there shouldn't be anything after it.
Posted : 08/10/2017 5:27 pm
seosamh77 - Member
drac
cougar rather, why I called ye drac there I'll never know! 😆 apologies!
Posted : 08/10/2017 5:42 pm
[quote=fifeandy ]5 mins with google will tell you A) what it is, and B) what it says.
I'm amazed it took you that long - though the OCR exercise was rather wasted in that case, given the first 12 characters are sufficient.
Posted : 08/10/2017 5:45 pm
 poly
-- fifeandy has told you what it is, and where to find what it says.
Posted : 08/10/2017 5:46 pm
 beej
Double hint: It's VERY encrypted.
Posted : 08/10/2017 5:50 pm
Damn it.
Ok, so I know what it is now at least (I actually thought this earlier and discounted it because of a lack of a private key).
I'll have a look again after tea.
Posted : 08/10/2017 5:51 pm
[quote=Cougar ]Ok, so I know what it is now at least (I actually thought this earlier and discounted it because of a lack of a private key).
Which probably makes google the only realistic attack vector.
Posted : 08/10/2017 5:58 pm
Well, it's got a PGP header. Encrypted document. Guess it's not just a signature or public key. Without the private key, it's no go.
p.s. is googling the detail likely to get you on a watch list? 😉
Posted : 08/10/2017 6:04 pm
... yes, which is where I'm at now (and hence why I discounted it at first). Having to hack a PGP message seemed far too obscure given the context.
Posted : 08/10/2017 6:07 pm
Does seems a daft puzzle to give without the key to decrypt it. Unless its some sort of trap and anyone that breaks it will get a knock on the door from men in black suits.
[i]Edit: There's no need to hack it, the plain text is in a presentation[/i]
Posted : 08/10/2017 6:12 pm
what's a pgp message aye why would you get a knock on the door for decrypting it?
Posted : 08/10/2017 6:16 pm
Cracked it.
Google gives this particular message as an example of PGP, but no translation. I've just found it -with- the translation in a NATO presentation.
[i]Outside of a dog, a book is man's best friend. Inside of a dog, it's too dark to read.[/i]
Thanks all. That took me far too long.
Posted : 08/10/2017 6:22 pm
I didn't see your edit till after I'd found it, FWIW.
Lol, good, more fun for you the less help you needed to find it 😀
I learnt recently at a team building exercise the answer to most of these types of puzzle is just a quick google away - although this one seems a bit daft in that google seems to be the [u]only[/u] way to solve it
Posted : 08/10/2017 6:27 pm
That was 3rd hit on my google - it's clearly a standard example PGP encoded message given it seems to be used in various different presntations on encryption/steganography, though strangely most don't give the plain text.
Posted : 08/10/2017 6:31 pm
[quote=fifeandy ]although this one seems a bit daft in that google seems to be the only way to solve it
I'm sure lots of supercomputers and lots of time would be an alternative approach 😉
Posted : 08/10/2017 6:34 pm
Well Cougar does have access to lots of computers.....
Posted : 08/10/2017 6:35 pm
I learnt recently at a team building exercise the answer to most of these types of puzzle is just a quick google away - although this one seems a bit daft in that google seems to be the only way to solve it
Yeah. MD5 is a good example of that, MD5 is fairly readily brute-forced (it's designed for speed) but the most efficient way of cracking it is to Google it.
I found the same thing, the only place I found which game you the actual translation was that one document, which seems odd but hey. (It was further down than third on my results, maybe 5 or 6.)
Posted : 08/10/2017 6:39 pm
Either the one with the plaintext was the original source and the others all borrowed it from that, or there's some other original source we didn't find. I suspect some of those presentations will have used it as sample PGP message without any idea what the plaintext is.
edit: a bit more googling suggests that certainly isn't the original source, that message appears in https://books.google.co.uk/books?id=AAnzJXtXQTUC from 1999 (though that may not be the earliest)
Posted : 08/10/2017 6:45 pm
Got a reply from the question setter,
[i]In my mind the answer can be put into a 5 letter combo lock. But the fact that you were able to track down the origin & even decode the encryption is utterly impressive.[/i]
I've replied,
[i] If the answer is "crypt" or something, I'm going to kill you in your sleep.[/i]
Posted : 09/10/2017 12:42 am
mh77 - Member
Pretty Good Privacy https://en.wikipedia.org/wiki/Pretty_Good_Privacy
A tool for encrypting and signing documents. Can be integrated into mail software to encrypt messages. Fell out of favour as it's a pain in the backside to faff about exchanging keys.
As for the knock on the door, the above nato presentation is an example of the kind of stuff authorities think people use encryption for. Though we all use encryption effectively all the time as the web uses it heavily. Still though, not knowing at the time what's in the message, if it turned out to be bomb making instructions or something.. ! 😮 😀
Posted : 09/10/2017 7:54 am
Cheers kenny. Aye the encryption idea these clowns in the gov have is ridiculous. I used to work with a guy that was in the TA, doing bomb disposal, he came in one day and asked me to print a file for him, schematics for bomb disposal! Aye security is good in the army eh.. Pretty sure you could have used them to make a bomb if you were that way inclined.
He left me with a cheers mate, make sure you delete those files eh? 😆 just aswell i'm an honest sort!
Posted : 09/10/2017 10:55 am
[quote=Cougar ]But the fact that you were able to track down the origin & even decode the encryption is utterly impressive.
He's not heard of google then? 😆
Posted : 09/10/2017 3:54 pm
