Now *that* is an al...
[Closed] Now *that* is an allen key
31 Users
It does appear you need to have virtually no finger nails to hold it though.
Posted : 10/09/2013 1:17 pm
 LoCo
I now have key envy
Posted : 10/09/2013 1:18 pm
to beat all the other pedants, shirley my dear "that is a hex key"
[url= http://www.pirate4x4.com/tech/billavista/PR-Kingpin/ ]Proper working one![/url]
Halfway down the page, as image isn't working properly (or intermittently)
Looks a little photoshopped. Is it a real thing?
Posted : 10/09/2013 1:20 pm
Awesome! Why is it that all small objects look brilliant when massive, whilst all large objects look great in miniature!?
What's the difference between a hex key and an allen key?
Posted : 10/09/2013 1:21 pm
this one looks less impressive but more real;
McMoonter has two of them 😉
Posted : 10/09/2013 1:22 pm
[i]What's the difference between a hex key and an allen key? [/i]
An Allen key is a hex key made by a specific manufacturer.
[quote=njee20 ]
The same difference between an iPad and a tablet, an iPhone and a smartphone, a Hoover and a vacuum cleaner.
same as a philips head and cross head screw driver?
Posted : 10/09/2013 1:24 pm
Man with tiny hands successfully bends hexagonal piece of licorice candy.
annebr - Member
Nope, [url= http://en.wikipedia.org/wiki/List_of_screw_drives ]philips and cross heads are different designs[/url]
oh my pedantism is on form in this thread!
TBF I thought Philips and Pozidriv were the same thing, apparently an updated design!
Posted : 10/09/2013 1:26 pm
Ta, everyday is a school day 🙂
Posted : 10/09/2013 1:32 pm
Fasthaggis, I think my biggest Allen key is only a 14mm. If this was an adjustable spanner thread, I may have a contender.
Posted : 10/09/2013 1:37 pm
And this is a decent sized bolt:
Posted : 10/09/2013 1:39 pm
How do we know that's not made by Allen ?
Posted : 10/09/2013 1:40 pm
Mcmoonter, bigger than this?
Posted : 10/09/2013 1:44 pm
If that one is made by Facom, I have its twin.
Posted : 10/09/2013 2:03 pm
If only I was in work now!!
Visiting service engineers from the states refer to the above as "hex wrenches" for some reason
Posted : 10/09/2013 2:04 pm
Because they're tools.
Posted : 10/09/2013 2:07 pm
A wrench (or spanner) is a tool used to provide grip and mechanical advantage in applying torque to turn objects—usually rotary fasteners, such as nuts and bolts—or keep them from turning
I guess these here hex key thingummies fall within that definition of wrench (or spanner).
Posted : 10/09/2013 2:08 pm
Yes but why not KEYS
No need to be insulting about foreigners
Posted : 10/09/2013 2:10 pm
Merkins also talk about ****ing on a wrench...
EDIT - oh, filtered... well you'll have to imagine what it was...
Posted : 10/09/2013 2:13 pm
They have Hex keys that size in Highland Industrial Supplies in Inverness to buy off the shelf. What a shop for a bit of browsing!
Posted : 10/09/2013 2:14 pm
I was impressed with the 10mm hex key I bought recently!
Posted : 10/09/2013 2:43 pm
I've worked in several workshops (inc the one i'm in now) that have Hex-Keys and adjustable spanners in 'man-sizes'
We build huge refrigeration plants for Navy ships and submarines here, and some of our compressors need huge hex-keys for servicing.
Posted : 10/09/2013 2:47 pm
I love the fact that for huge nuts/bolts (as I cm across) you'd expect there to be some fancy tool to tighten and loosen them....but no, it's just a bloody great spanner exactly as if someone took a normal 10mm spanner and pressed the 'enlarge 10x' button.
Posted : 10/09/2013 5:22 pm
speed12 - Member
For ginormous nuts and bolts, its common to use a hydraulic jack to temporarily stretch it, screw the nut up by hand, then release the hydraulic jack, thereby placing the bolt/stud under tension.
Either that or a little flogging spanner and a humunguous hammer.......
Posted : 10/09/2013 5:43 pm
You're not British are you? 😉
Posted : 10/09/2013 6:16 pm
Its not big he has small hands
Posted : 10/09/2013 6:19 pm
I used to enjoy using slogging wrenches, designed for whacking with proper sized sledge hammers, you didn't want to miss.
Posted : 10/09/2013 6:22 pm
googles big tools 😆 😮 😯 😡 😳
Posted : 10/09/2013 6:23 pm
I had to buy one of a similar size for doing some work on a vw golf mk1 gearbox
Posted : 10/09/2013 6:39 pm
In my old place of work there was a 70 odd mm spanner. Commonly known as the comedy spanner
Posted : 10/09/2013 6:51 pm
I found a picture of a couple of massive spanners:
Posted : 10/09/2013 7:01 pm
needs a ball end
Posted : 10/09/2013 8:56 pm
An iron mongers in Birmingham (Whites IIRC - are they still there?) tried to sell me and Allen Key like the one in the OP, maybe bigger. For a £5. He actually had two of them and was clanging them together and hollering like a town cryer. I was tempted until I found out the cap head screws it fitted into were about £100 each.
Found a giant spanner in a scrap yard in brum too. You could hold it like a guitar. Embossed with the brand name 'King Dick'
Posted : 10/09/2013 9:18 pm
I like the big nuts and bolts on the bridge as you pull into Charing Cross Station.
Posted : 10/09/2013 9:35 pm
