New Washing Machine...
New Washing Machine Required
[#12680416]
Budget around £800, regular size. Family of four.
What in the hive mind opinion will be most efficient and more importantly reliable.
Old one AEG model lasted seven years, before its proved uneconomical to repair (according to the local expert).
Not interested or able to fix it myself.
Thanks in advance.
Posted : 09/01/2023 8:32 pm
Can't fault Miele appliances. You'll get a washing machine for that money. Ours was bought in 2000, never missed a beat. Family of five; sometimes on more than once a day.
Posted : 09/01/2023 8:57 pm
Thanks DS, looking now..
Posted : 09/01/2023 8:59 pm
Basic big Bosch. The cheapest model for the size you want. Less to go wrong on something that gets a hammering. Ours is just over ten years old (family of five) and it’s had a new belt and door seal which were easy and economical repairs.
Posted : 09/01/2023 9:02 pm
Miele are ruddy good but at a price premium
I like Bosch as recommended by my local repair chap - he recons of the normal price stuff its the most reliable  Half your budget will get you one
Posted : 09/01/2023 9:05 pm
Miele are built to last 20 years but high initial outlay. Currently have a Bosch one which is serving well. If you’re in a hard water area then I would probably buy Bosch/Siemens and expect to replace every 10 years - that way you get all new rather than clogged up Miele hanging on…. Otherwise if budget allows then Miele are undoubtedly the best.
Thanks people, off to look at Bosch:)
Posted : 09/01/2023 9:10 pm
Bosch/Siemens/AEG all seem to use the same components internally whenever I've looked (same part numbers).  Have had them last over 10years and they work well.  As above Miele aim for 20years life but that doesn't necessarily mean they won't go wrong.  They do work very well though
Posted : 09/01/2023 9:23 pm
Also have a look at Ebac, UK brand with long warranty and designed to be repaired, brought one last year and very pleased with it. Local appliances engineer also highly recommends Beco
Posted : 09/01/2023 9:53 pm
Our LG is nearly 12 and apart from needing a new seal once when the old one developed a small hole has worked fine. We have 2 kids and it is on most days.
I chose it because it has a direct drive motor with an inverter, like modern industrial machinery, so has no drive belt or motor brushes by design so has fewer mechanical components to wear out.
It has a slightly larger diameter but shallower drum so doesn't need to spin quite so fast for the same drying effect.
My gamble has paid off so far and keeping my fingers crossed I haven't just jinxed it.
Had a second hand Bosch before and broke it changing brushes because a few drips of water got into the control panel when I tipped it on its side to get at the motor. Went it went to spin a loud bang and flash happened as the electronic panel blew. Oops!
Posted : 09/01/2023 10:07 pm
I vote Bosch, they are fantastic value for how long they last (+12yrs currently).
Posted : 09/01/2023 10:19 pm
Sort of related, my wife bakes for a charity that provides birthday cakes for kids who wouldn't otherwise get one. She's just been asked to bake one for a kid who really likes washing machines.
Posted : 09/01/2023 10:24 pm
I'll third (or fourth?) Bosch.   Ours is still going strong after about 15 years so far!  Had to replace one water inlet valve at about 4 or 5 years I think.
Its had a hard life too, in use most days of the week.
Would also consider Ebac when this one dies, as I heard a few years ago that Bosch aren't built like they used to be.
Ebac also still makes machines with a hot water inlet - a rare thing these days.  Never really understood why most manufacturers stopped doing them?  Must be more economical to use pre-heated water than heating a drum full electrically on the fly?
Posted : 09/01/2023 10:39 pm
Happy with Bosch but would look into Ebac too.
7-year parts and labour guarantee
Posted : 09/01/2023 10:45 pm
Miele. The cheapest (well, least expensive)/base models are 100% fine. They have an outlet store in Abingdon (stock list available on-line) with some decent discounts, too, if you don't mind slightly scratched/dented/ex-demo.
(Our plumber recommended Beco for a cheaper machine, apparently they're the filter-down brand of Bosch, so you get older Bosch tech and build for a fair chunk less money.)
Posted : 09/01/2023 10:46 pm
apparently they’re the filter-down brand of Bosch,
Don't think that's true. I thought Beko was a huge Turkish brand in their own right
Posted : 09/01/2023 10:49 pm
Bosch here, had to get the water inlet valve replaced under warranty after 2 months . Other than that its been faultless
Posted : 09/01/2023 10:53 pm
Our Samsung washing machine is now 15 years old. At the time I bought it as it was the cheapest washing machine with a 3 year warranty. I think at the time it was £300 against £1000+ for a Meile. I know for certain I will never spend Meile money for any white goods.
Posted : 09/01/2023 11:05 pm
Thanks all, been checking reviews all evening.
Wife will have the deciding vote on drum size etc. Cant complain as its her that uses it mostly.
Posted : 09/01/2023 11:38 pm
Beko always get good reviews in recent Which website/mag reviews and I note At least 2 above have said professionals have recommended them. I've got a Bosch which has been fine but if it failed tomorrow then it's probably a Beko replacement if the price is right. Also possibly I'd be looking for something that can work with a time of day tariff, by either from built in smart controls or more basically on/off from the plug.
Posted : 09/01/2023 11:50 pm
Had a Bosch machine completely disintegrate when the metal casting housing the motor and drum broke and completely destroyed itself - not covered by any warranty even though it was only a few years old. Got a non-integrated Hotpoint based on AO reviews - it sits inside a cupboard so badge-snobbery is irrelevant.
Posted : 09/01/2023 11:51 pm
I’ve always gone Bosch everything, haven’t been let down yet.
I particularly value the 14 min cycle (even though in reality it turns out to be 20 min) on mine, perfect for chucking in gym/cycling kit for a tiny load quick wash
Posted : 10/01/2023 1:11 am
+1 for Miele. Had a washer dryer of theirs for 20 years. 5 years into a new one and all good. That is an amazing life for a washer dryer. Also try online places like appliance city for big discounts on Miele kit.
Posted : 10/01/2023 2:49 am
our bosch is ancient and still going strong despite my best efforst to break it in new and interesting ways (setting it solid with soap flakes was a giggle)
BUT
For god sake before you naturally throw the instructions away find out how to turn off the *finished* alarm
Posted : 10/01/2023 9:58 am
Hiya,
I have been using Hotpoint's for a few years. If you look at the warranties alone they make sense.
JeZ
Posted : 10/01/2023 10:20 am
Please please tell me how to do this, it drives me insane. Once would be fine but the bloody thing just beeps and beeps endlessly.
But yeah I'll add a vote for Bosch. Ours is now 11 years old and the only thing replaced has been a door seal and that's just because it got a bit manky rather than failing. All of our other white goods are Bosch (dishwasher, tumble dryer, fridge/freezer). The only thing that has ever broken on any of them was something on the fridge which was causing everything to freeze, turned out to be something to do with a polystyrene thingy in the back which was fixed under warranty.
Posted : 10/01/2023 10:27 am
 MSP
I have had a LG for about 12 years now, live in a very hard water area so use a descaler every few months.
Posted : 10/01/2023 10:36 am
For the beeps, find the model number inside the door and search it up with the words ‘finish beep’
Mine at https://www.diynot.com/diy/threads/turn-off-the-end-of-cycle-alarm-for-bosch-waq283s0gb.340352/
Posted : 10/01/2023 10:43 am
I have 2 x Beko that I bought in 2018 for £220 each - no issues whatsoever. You could easily buy 3 within your budget and I'm struggling to see how one washing machine can be 4 x better than another!!
My feeling is that the added electronics in todays appliances make them shorter lived - the bosch dishwasher and washing machine I had previously both died from electronics failure.
Posted : 10/01/2023 10:46 am
our samsung ecobubble is 6 years now, its a good machine but we 90% use daily wash, the circuit board is known to start pausing mid cycle.. lots online, anyway thought i may need one soon. as it kept pausing/stopping in november decemeber
but ran a few dark wash / cotton wash cycles in recent weeks, and now daily wash works again..
plus with the ecobubble it feels like a ryanair on time arrival when its finished,
Posted : 10/01/2023 10:51 am
After Bosch machines that didn’t last as long as expected we bought an LG. Brushless motor with 10 year warranty and A+++ rating. It weighs the washing before adding water and adjusts the program accordingly. It’s been absolutely faultless despite me washing filthy work clothes, cycling gear and dog bedding. I clean the filter out every now and then when I remember - it plays a lovely little tune when it’s finished - once! Excellent results at 20 degrees. Hope this helps.
Posted : 10/01/2023 11:01 am
We had a Bosch from new (mid priced model) which did good service for probably about seven years or so before its bearings went, and I discovered the "sealed tub" design meant you couldn't replace the bearings for 50 notes or so but instead had to replace the whole sealed unit for something like the cost of a complete new machine.
So we ended up scrapping a mostly fine machine for no real reason. Soured me on Bosch a bit sadly ☹️. I appreciate we'd probably had our money's worth, in some sense, but that sort of designed obsolescence isn't tractable these days IMO.
Have since gotten a used Miele. It's a bit "well loved" and I've had to replace a brush on the motor twice but it's a lot easier to work on than the Bosch was, and the fact that it's designed for a 20 year life encourages me that it should be possible to fix for fair while to come.
Posted : 10/01/2023 11:13 am
Miele. Ours laster over 20 years and was only "retired" recently when the neighbours gave us their Samsung free as they were moving. I liked the robustness and design. They will all wash at 40C and spin at 1200 RPM. The technology is in the detergent. Buy one up from the base model.
I second the Abingdon outlet store. Ours came from there in about 1996 when we lived locally! It was serviced twice by a proper Miele engineer who said he had one customer with a 40 yo model still running.
Posted : 10/01/2023 11:19 am
our LG just spat a load of plastic into the filter after around 13 years of service.
I think it's the bearing and the back part of the drum that's gone, however, it's going to the recycling/fixers yard.
we've a hoover on it's way, it may not be as good, time will tell, but it met the relatively cheap/efficient requirements we have.
if it lasts 5-6 years I'll be happy.
Posted : 10/01/2023 12:13 pm
Bosch.
That's us all the way. Almost all our kitchen whitegoods are Bosch. Had very good service, etc etc.
Siemens AEG seemed a little pricier last time I looked (although that was a fridge).
Caveat with Bosch... From memory:
Some Bosch are German made with good QC. Get one of these. Usually mid-tier upward, depends on what sort of unit, can't remember all the details, sorry.
Some (the cheaper tiers) are not. YMMV on those.
Posted : 10/01/2023 12:24 pm
I would buy Indesit washing machines because they're cheap and they seem to last forever. On my second one in 24 years, but the first we only sold with the house because it was easier... At < £300 don't really fit your budget though 😉
Posted : 10/01/2023 12:33 pm
I splashed out on a Miele.
It came with a full 10 year warranty.
It washes really well and is very efficient.
However, the touch screen display went after a year so not bomb proof.
If I had known about them at the time I might of went for an Ebac.
Posted : 10/01/2023 12:37 pm
Why bother with Meile? There’s nothing in a modern LG machine that can’t be DIY’d in an afternoon.
Who wants to be using the same mouldy washing machine a decade from now? You’ll need to change door seals etc anyway.
https://www.hotukdeals.com/deals/lg-front-load-washing-machine-with-stain-care-white-4066194
Less than half the cost. ^^
Posted : 10/01/2023 3:07 pm
@gooner69 As my comments above, ours is the LG 10.5 kg upgrade, identified with the rectangular filter door and the induction motor (10 year guarantee), which can be found in the post above from @Flaperon. It’s been faultless!
Posted : 10/01/2023 6:36 pm
I just go for cheap ones, I've had 3 machines since 1991 a Candy lasted 12 years, hotpoint lasted 11 years and the latest is a beko which is currently 8 years old now all been heavily used.
Can't see the point of expensive ones, all mine have been 250-300 max, I just pick whatever is on offer with good reviews on AO or similar these days. Same for fridges and dishwashers. Never had a problem with any cheap white goods from Indesit, Hotpoint, LG, Beko or Candy
Posted : 10/01/2023 7:24 pm
Siemens here. We are on our second one. First one lasted 11 years. Bought from a Euronics centre, life time call out and labour free, 5 year warranty from Siemens.
Same internally as a Bosch or AEG.
Posted : 10/01/2023 10:38 pm
Someone mentioned AO earlier in thread. So we looked there and found a budget option that is reviewed really well onsite and at Good Housekeeping. Its a lot less than we could have spent so if it goes wrong after the warranty runs out (5yr labour 10yr parts) we can get it repaired/replace again.
I reckon the overall cost of these machines comes out at about £100 a year whatever you buy. Once you factor in servicing etc on the expensive ones.
Posted : 11/01/2023 8:29 am
 bfw
I just bought a reduced F&P washer drier from a local supplier £750 (supposedly reduced from £1k), its amazing up to the total crap Samsung we had. Its so quiet, quick and sensible, like being able to open the door without switching it on (which doesnt sound much but it is, especially when the pooh washing machine then plays a 45 second tune at you because you need to switch it off, rather than say switching itself off!!).
The machine was a Fisher + Paykel WD8060P1 98136 Washer Dryer for £729 delivered.
Posted : 11/01/2023 11:55 am
Depends on; the temperature of your normal wash (a lot of folk use low temperatures with Bio powders), the run of pipe from your boiler to the machine, what the machine does with the cold water in the hot pipe before the hot water flows, whether you have solar heated water, how often you run boil washes, etc
Good summary article here:
https://www.whitegoodshelp.co.uk/cold-fill-verses-hot-fill-washing-machines/
Posted : 11/01/2023 12:39 pm
Nah. If that was the case then my £200 machines should have died over 2 years ago!
Posted : 11/01/2023 12:46 pm
