New laptop has 2 ha...
[Closed] New laptop has 2 hard drives. Why?
Do I keep my operating system on one, and saved stuff on the other? or fill one, and then start to put stuff on the other or what?
At the moment, one seems to be not doing anything
Posted : 26/04/2009 9:46 pm
Do you mean one HD with two partitions?
Posted : 26/04/2009 9:52 pm
It seems to be two HDD's New to vista, but they're named c and d
Posted : 26/04/2009 9:53 pm
I think you'll find it's just two partitions on the same physical drive.
Do with them what you will.
Personally I put personal files on the D drive and just use the C for applications.
Posted : 26/04/2009 9:57 pm
probably 2 partitions on the same drive.
Posted : 26/04/2009 9:58 pm
[url= http://farm4.static.flickr.com/3411/3477915000_5907f0980d_b.jp g" target="_blank">http://farm4.static.flickr.com/3411/3477915000_5907f0980d_b.jp g"/> [/img][/url]
Just it says 2 drives at the top, so are they just partitions?
Clicky for bigger
Posted : 26/04/2009 9:59 pm
Yes, probably two partitions. Put all your files on the D drive and use the C for apps. If something goes wrong, you can format the C drive without losing all your files as they'll be on the D drive.
Posted : 26/04/2009 10:00 pm
So can I move the My documets and all that to D?
Posted : 26/04/2009 10:07 pm
yep. Don't just drag them though, right click on my documents, click properties and then the move button to move my documents where you want it.
Posted : 26/04/2009 10:16 pm
May possibly be two HDDs. Was looking at a Fujitsu laptop the other day that had two drives and a RAID controller.
But at that size I'd say they are partitions. Look in Disk Manager to find out.
Posted : 26/04/2009 11:25 pm
Larger storage too.
Posted : 26/04/2009 11:37 pm
It may have 2 hd, some of the larger alienwares have 2 drive bays, for a bit of fun replace the drive with the OS on with a big CF card in a hdd adaptor will boot like brown stuff off the shovel and keep all the other stuff on the second drive
Posted : 27/04/2009 12:45 am
Yes, looks to be two partitions, normal reason for this is that you put all your personal stuff on drive D and then if anything goes wrong and you need to reinstall windows you can do so and it will wipe drive C and leave D alone and so reduces risk of loosing important stuff.
Posted : 27/04/2009 12:49 am
Posted : 27/04/2009 12:54 am
Should be similar on Vista, but on XP you do right click on my computer then
=>manage>storage>disk management
This will present you with a table and a diagram of how your drives are partitioned and which drive letters occur on which physical address.
Posted : 27/04/2009 4:11 am
Are you staying up all night just to ensure you dont miss anything? ๐Ÿ˜‰
Posted : 27/04/2009 6:05 am
Screenshot shows ACER as C drive and DATA as D. I bought an Acer lappy for my wife and that was configured the same. 2 partitions on the same physical drive.
Posted : 27/04/2009 11:21 am
Nope, I had an early night on saturday night and that totally buggered up my sleep pattern so it was 5:45 before I got to sleep ๐Ÿ™‚
Screenshot doesn't suggest whether it's two seperate drives or one partitioned, it just states theres two drive letters of a set size each? However 111Gb is an odd drive size so I suggest 225 (close to the sum of the two) is more likely so I agree its likely to be 2 partitions.
Posted : 27/04/2009 11:32 am
It's probably a 250gb drive and the 25gb is lost in formatting two partitions on it.
Posted : 27/04/2009 11:47 am
Yup, that was my thought, just seems like a lot of loss - I cant remember whats typical for that sort of size drive ๐Ÿ™‚
Posted : 27/04/2009 11:51 am
Depends on the file system. It's about right though.
500gb formats down to about 464 and a Tb formats down to about 928gb. (Personal experience) using NTFS
Probably worse if you use FAT32.
Posted : 27/04/2009 11:59 am
<spinal tap> Cos it's one better </spinal tap> ๐Ÿ˜€
Posted : 27/04/2009 3:03 pm
Would that actually work then...?
Posted : 27/04/2009 3:48 pm
Drive sizes are always different in real life to what they are advertised as. Manufacturers takes one gb to be 1000mb, Windows (correctly I believe) takes it as 1024.
Posted : 27/04/2009 4:09 pm
Thanks for the help all!
Posted : 27/04/2009 6:30 pm
just to complicate things a bit, the biggest capacity iPods have two harddrives in: the 160Gb Classics had two 80Gb, for example.
Posted : 27/04/2009 6:58 pm
There'll also be some space lost for the hidden recovery data partition.
Put your data on the secondary partition for the reasons stated above. Also back up all your files as you're moving them over, it's an easy time for stuff to get lost.
Posted : 27/04/2009 7:47 pm
it's just partitions on the same hdd
mine's [url= http://davidpowell7521.fotopic.net/p57830476.html ]almost exactly the same[/url]
Posted : 27/04/2009 7:58 pm
Ta.
Posted : 27/04/2009 7:59 pm
Right, it looks like it's 1 drive with 4 partitions.
I have an external HDD that's on our wireless network that I can back up to. I can't move the PAUL folder onto D, just the individual folders in it, can I make the C: partition bigger?
[url= http://farm4.static.flickr.com/3601/3481534514_4c944ed838_b.jp g" target="_blank">http://farm4.static.flickr.com/3601/3481534514_4c944ed838_b.jp g"/> [/img][/url]
Posted : 27/04/2009 10:16 pm
Yup, 2 large, 2 small. Thought it looked a bit odd for 2 partitions, was just a hunch though.
You'd need something like Partition Magic to change partition sizes.
Taki...
Yes you could use a CF card but the sizes are very limited and it'll keel over after less time than a harddrive due to flash memory having a lower lifespan of writes.
Posted : 28/04/2009 2:59 pm
