Need a bit of IT ad...
[Closed] Need a bit of IT advice, please
7 Users
Currently scanning lots of documents to laptop in the form of searchable pdf files. This is my attempt to go paperless!
Backing up via a freecom external hard drive. I can't really afford to lose the documents so should I back up once more using another external hard drive? Is there a better provision against data loss?
Also concerned about security as use laptop to access the Internet. In this case should I only hold sensitive files on external hard drive and make sure I disconnect when I connect to the web?
Any advice most appreciated.
Posted : 10/04/2009 9:52 am
Yes and Yes and Burn to a CD (Solid State).
You may also consider exporting as TXT. As all formats go out of date.
Posted : 10/04/2009 9:56 am
If you are concerned about security then the first thing I'd do is look at encrypting the PDF files with a password. You can probably do this as you generate them as PDFs have various built-in security restrictions.
Also you might want to think about an off-site back up.
This could simply be burning a DVD of the documents and giving it to a trusted friend (or solicitor, or safety deposit box).
Or you could use one of the many online backup services where you upload your files to a secure area on the web. e.g. http://mozy.com/ or http://www.carbonite.com/
Posted : 10/04/2009 9:57 am
Thanks both, some good advice there
Red Thunder - TXT=text?
Posted : 10/04/2009 10:10 am
Aye.
plain text files.
You can always format at another time.
Posted : 10/04/2009 10:18 am
the problem with text files is that while it will record the text of the document, it wont record it's nature - e.g. signed, company headed paper, invoice structure and fields etc.
pdf is so ubiquitous that for all intents and purposes there will always be pdf readers available.
Posted : 10/04/2009 10:23 am
Agree with Stoner.
PDF is so ubiquitous that readers and converters will be available for many decades to come.
Another thing to consider: if these are legal documents etc then make sure you leave details on how to get them, passwords etc in your will.
Posted : 10/04/2009 10:38 am
Never rely on PDF readers etc. for the future. I'm sure they will be around for yonks.
I'm having a problem right now with old Lotus Organizer files.
The old way to store documents is in the printed format or chisel them in to your nearest cave wall 😉
Posted : 10/04/2009 10:45 am
Also if you decide to record to DVD/CD make sure of the life of the media as the dye used in them can degrade over time. Some of my recorded DVDs have started to become unreadable after about 4 years or so. I believe that sony media is guaranteed for 30 years, my friend told me this so not sure how true it is.
Ivan
Posted : 10/04/2009 10:52 am
 Haze
Get another external/removable drive, sync the 2 together.
Posted : 10/04/2009 10:58 am
Things have moved on a bit though since the days of Lotus Organizer.
The entire internet is using PDFs and it is an open standard that is published by ISO (much like ASCII text).
It's not going anywhere for a long time yet.
True. Archival DVDs improve on this greatly but are much more expensive.
Only really useful if you then take the second drive off-site. No point in having two drives if they are both destroyed in the same fire/flood/tornado whatever.
Posted : 10/04/2009 11:26 am
 Haze
Hence the "removable" comment! 😉
Posted : 10/04/2009 6:27 pm
Back up to two external hdd's, incase of mechanical failue. Another copy to offsite dvd or other semi permanent media (print, fiche, tape etc), which should be regularly refreshed(say annually). No chance of pdf's disappearing for a long while, and there would certainly be a conversion/transfer process available, but it is always a good idea to also have a backup of the application to read the source.
Posted : 10/04/2009 6:35 pm
