Motion Sensitive Ma...
[Closed] Motion Sensitive Mains Socket
9 Users
Hi everyone,
Further to my "Squirrels in the loft" thread, I'm now trying to create a squirrel deterrent [sounds almost military!]
The idea: motion sensor turns on radio to blast out Rock FM and scare squirrels away.
The problem: where do I get a socket which turns on and off with motion - does such a thing exist? I image it to be something like a timer socket like you'd use when wanting a lamp to turn on in the evening, but with an IR sensor instead.
Can anyone suggest where I can get the above or bodge an equivalent?
Thanks a lot!
Col
Posted : 06/12/2010 10:16 am
Just use a PIR wired up to the radio instead of a bulb.
something like this? http://www.virtualvillage.co.uk/pir-sensor-for-home-security-003921-001.html?utm_source=googlebase&utm_medium=shcomp
Posted : 06/12/2010 10:19 am
Google ?
http://www.pvrdirect.co.uk/productinfo.aspx?catref=BYRRS52
Posted : 06/12/2010 10:46 am
Be aware that squirrels may get out of bed earlier than you and that Planet Rock at full blast at 5am may wake other members of your household.
Maybe a lamp to start with and see if that works?
But I guess, like most things, they'll get habituated to whatever you do and your best bet will to find how they are gaining access and put mesh across it.
Posted : 06/12/2010 10:48 am
Posted : 06/12/2010 11:29 am
I'm not sure rock music is the best deterrent, as squirrels are known to like partying......
I would go for a proper squirrel deterrent :
http://www.primrose-london.co.uk/squirrel-deterrent-100-mains-powered-p-1892.html?source=googlebase
[i]Squirrels in the loft
- If you have power in the loft, use the Rat and Mouse deterrent 4000 and position it in the middle of the loft (has a 2m cable).
- If there's no power supply, use the battery-powered Outdoor Squirrel repeller.[/i]
Posted : 06/12/2010 11:39 am
Sounds like you need an autonomous target acquiring paintball sentry.
Posted : 06/12/2010 1:06 pm
Could you not just put some nuts in the bottom of a food processor, and stick the motion sensor next to it.
Posted : 06/12/2010 1:11 pm
You need the De-Pelter Turbo!
Be prepared for a lot of stinging!
Posted : 06/12/2010 1:16 pm
