Monitor input switc...
Monitor input switches
One monitor, one MacBook Pro 13" (with four thunderbolt ports), one PC with mini DP outputs.
I just bought a monitor switch, set it up and the output on the MBP flickers and goes off every few seconds. Reading a bit suggests this is because I'm using a thunderbolt to mini DP adapter dongle. Other switches that seem to support thunderbolt directly are hundreds of quids.
Anyone done similar without spending hundreds?
Posted : 26/09/2022 6:48 pm
 5lab
does the monitor itself not have several input methods? just use 2 of them (even if one is VGA) and press the button on the monitor
Posted : 26/09/2022 6:51 pm
Thanks for chipping in but that wasn't what I asked.
Posted : 27/09/2022 4:13 pm
I’ve not done this with a MacBook but I use a little thunderbolt/usb-c docking station to power my laptop and to split out two HDMI pots and one display port connection (amongst other things). I use the two HDMI connections to drive my main monitors without issue and believe the display port output is just as reliable. Suspect you can pick up a similar one for less money if you’re just after the one display port output.
https://amzn.eu/1lGwEqr
Posted : 27/09/2022 4:44 pm
Have a small dell DA-310 usb-c hub that I use from work to give an hdmi and a displayport. It’s very stable but struggles to pass through my 34” ultra wide resolution. It’s been widely recommended.
That may stabilise the signal into your switch. Previously I used a hdmi switcher for my two laptops. I now use the ultra wide with PIP with the work laptop taking usb-c for 3/4 of the screen and my vintage MBP mini display port to another HDMI in the top corner. It was, however, fine with the hdmi switcher and a normal monitor before that.
Posted : 27/09/2022 10:31 pm
I use a Sony av receiver. Also for sound too of course. Bit overkill perhaps.No guarantee it would work either.
Posted : 28/09/2022 12:16 am
