Modeo rattles..... ...
[Closed] Modeo rattles..... Is it terminal?????
9 Users
I know all oil burners rattle a bit, but this is only when idling with the clutch depressed. Car is a 2.0l TD 2003 with 85k on the clock.
Any ideas gratefully reciieved
Posted : 12/05/2010 12:13 pm
 5lab
DMF on its way out. Common problem, will need replacing at some point, best to do the clutch as well, about a grand all in
Posted : 12/05/2010 12:17 pm
DMF ??????
Posted : 12/05/2010 12:21 pm
dual mass flywheel
Posted : 12/05/2010 12:22 pm
 5lab
yep, dual mass flywheel. known problem on the diesel mondeos of that era, particularly the 130bhp models. do a search online you'll find loads. the longer you leave it, the more likely it is to lunch your starter motor.
Posted : 12/05/2010 12:34 pm
 tron
What 5Lab said, sounds very much like the Dual Mass Flywheel. Next thing will probably be the clutch slipping. More of a known problem on every diesel they've ever been fitted to than just Mondeos (and that's most "modern" diesels).
My advice is to sell it ASAP as it's a very costly job to replace.
Posted : 12/05/2010 12:36 pm
It could be that the n has come loose.
Posted : 12/05/2010 12:40 pm
I've lost count of the number of people who told me I had a DMF problem on a car that didn't even have a DMF.
Posted : 12/05/2010 12:46 pm
I seem to remember a mechanic mate saying you can get a kit
to convert from DMF, effectively fixes the flywheel as per a normal one
Posted : 12/05/2010 12:48 pm
 tron
You can switch to solid flywheel, but you lose some refinement and there's a question of where the forces (big torque spikes) the DMF was soaking up are now going.
IIRC a solid flywheel is about £70, plus a clutch kit - £70? then labour - on the old Mondeos you had to drop the subframe to do the clutch, then realign it. Made it about a £500 job.
Posted : 12/05/2010 12:50 pm
Mine rattles as per your description but its always done it so I recon its just a loose heatsheild or something.
Posted : 12/05/2010 12:58 pm
mine too, stuck on a psp atm, there is a pipe with a rubber gasket designed ironically to reduce vibration noise that does the opposite as it gets older. search the mondeo forum, can swop out with a metal one.
Posted : 12/05/2010 1:59 pm
