Linux/python dudes ...
[Closed] Linux/python dudes - how do I extract this data?
7 Users
I have a long log file containing temperatures that is updated every 10 mins - lines are formatted date/time/temp1/temp2.
For example: [i]06/12/2014 20:50:01 56.500 15.000[/i]
I can extract temp2 using tail -c6 but I want to extract temp1 and put it into a variable and not sure how. Well I do have one idea: I could use [i]tail -c13[/i] to get both temps and then [i]head -c6[/i] to get the first temp but it seems a bit clumsy. Would [i]len[/i] be any help?
Any thoughts?
Posted : 06/12/2014 9:08 pm
Spilt()
Posted : 06/12/2014 9:11 pm
awk is your friend.
$temp1=awk '{print $2}' <tempfile
$temp2=awk '{print $3}' <tempfile
although you could use cut as well.
edited to include execution quotes and filename. Not sure if you want to run it from a script or not.
edit: which didn;t work. 😉
Posted : 06/12/2014 9:12 pm
Where are you trying to do this? In a shell script? Or in some Python?
Posted : 06/12/2014 9:16 pm
I'd prefer to do it in Python. The latest data is added to the end of the data file (not the beginning) every 10 mins.
I'll check awk.
Posted : 06/12/2014 9:23 pm
 sas
Use a bash array:
$ line='06/12/2014 20:50:01 56.500 15.000'
$ vars=($line)
$ echo ${vars[2]}
56.500
$ echo ${vars[3]}
15.000
Edit: Even easier in Python
temp1, temp2 = line.split()[-2:]
print temp1, temp2
Posted : 06/12/2014 9:24 pm
Right so you need to grab the line using tail then.
Top of my head so syntax may need correcting.
$temp1=?tail -1 tempfile |awk '{print $2}'?
$temp2=?tail -1 tempfile |awk '{print $3}'?
entities are formatting badly there but you need an execute single quote after the = and at the end of the line
Posted : 06/12/2014 9:33 pm
Thanks guys [thumbs up gif ... if there was one]
Posted : 06/12/2014 9:44 pm
backticks don't work on here.
with that format, I'd just use awk in bash commandline or script.
Posted : 06/12/2014 9:46 pm
@Samurai
Perhaps this?
[code]
temp1=$(tail -1 tempfile |awk '{print $2}')
[/code]
The "$" at the start looks like you've been hacking on perl too long....
And don't use backticks as you can't nest them.
Posted : 06/12/2014 10:02 pm
Sorted - running a bash script:
echo $(tail -1 tempdata.dat |awk '{print $3}') > watertemp.dat
and then using watertemp.dat in an existing python script to create a php file that my phone gets the temperatures from with a json request and sends them to my pebble phone 🙂
Saturday night fun.... it was either that or watch crap TV.
thanks all
Posted : 06/12/2014 10:51 pm
Pretty sure you missed a step:
Output the log file to your printer, allow the printed paper to fall onto a wooden table, the capture an image of it with a web cam, the feed the image into optical character recognition, and use that data to create a copy of the log file.
(Or you know, just do some RegEx in Python)
Posted : 06/12/2014 11:10 pm
Didn't think about that Graham.... just got a new printer as well!
Posted : 06/12/2014 11:22 pm
[i]temp1=$(tail -1 tempfile |awk '{print $2}')
[/i]
php. I've been building phishing pages for the last few weeks.
Posted : 07/12/2014 12:09 am
