Joiners....Interior...
[Closed] Joiners....Interior designers...Help with my shelves.
15 Users
I am building some shelves into an alcove. I am fine with all the building stuff, but I am have a design conundrum.....Should the shelves be evenly spaced ?
The bottom of the shelves is the floor, I have then gone up 30 cm per shelf after the skirting board and continued with 30 cm shelves and it does not look right to me ( just roughed atm )
Is there a rule of thumb for the distance ie should the lower shelves have a smaller spacing than the upper shelves ?
I plan on filling the floor to first shelf with firewood eventually.
I will post a pic when I sort it out ( read this as take away my dodgy test paperbacks 🙂 ), you will notice an odd style of building the shelves but the brief from the mrs was...STRONG...then everything else.
An example photo would be great.
cheers
Posted : 30/08/2015 5:00 pm
with doors the hinges are not even as when you look from head height an even gap looks uneven
I suspect this is why yours look uneven
i did mine at random heights but i have LPs some big books some little books etc so I wanted to maximise space
Once filled it is irrelavnt IMHO
Posted : 30/08/2015 5:14 pm
Any successful design must be fit for purpose so the first thing to consider is what you intend to put on your shelves and space them to accommodate the tallest object. I have shelves either side of my chimney breat, 4 evenly spaced on the left and 3 randomly spaced on the right. They look fine because the top and bottom shelves at both sides are at the same level.
Posted : 30/08/2015 5:21 pm
As sandboy says, what are you putting on them?
Shelves will generally look better if they get closer the higher you go. Narrow them down by a couple of cm per shelf, depending on what they're carrying and the space available. Try not to have a top shelf appreciably narrower than the rest; better to leave it out altogether.
Random can look good, but stick to big stuff down below, for practical as well as aesthetic reasons.
Posted : 30/08/2015 5:33 pm
Yip, I am probably overthinking.
But it s a big job to get wrong. Wife has been waiting a long time for book shelves.
Posted : 30/08/2015 5:42 pm
The bottom shelf could do with being lower; you're going to have a big gap under it. Anything just placed on the floor will then look untidy.
About the height of the shelf where the books are, you could have a wider shelf for a vase of flowers, darts trophies etc and then taper off as you get higher.
The "golden ratio" in nature, art and design is 1:1.618, though the rule of thirds is easier to calculate. Interpret that as you will...
http://www.digitalartsonline.co.uk/tutorials/creative-lifestyle/creating-art-using-golden-ratio/
http://www.goldennumber.net/art-composition-design/
Posted : 30/08/2015 6:12 pm
Ignore this[quote=suburbanreuben ]The bottom shelf could do with being lower; you're going to have a big gap under it. Anything just placed on the floor will then look untidy.if this [quote=righog ]I plan on filling the floor to first shelf with firewood eventually.is your plan
Posted : 30/08/2015 6:15 pm
Ignore this
suburbanreuben » The bottom shelf could do with being lower; you're going to have a big gap under it. Anything just placed on the floor will then look untidy.
if this
righog » I plan on filling the floor to first shelf with firewood eventually.
is your plan
Indeed! I didn't see that bit.
Posted : 30/08/2015 6:43 pm
Thanks for all the positive replies to my ridiculously middle class question 🙂
I have a heap of wood for the job, so I can play around with the positions etc.
Good stuff
Posted : 30/08/2015 6:47 pm
How about something like this?
Posted : 30/08/2015 6:49 pm
suburbanreuben About the height of the shelf where the books are, you could have a wider shelf for a vase of flowers, darts trophies etc and then taper off as you get higher.
yes thanks I was thinking of having a wider shelf, contemplating a tv, but it's a bit...NOT A BOOKSHELF...if you know what I mean.
Posted : 30/08/2015 6:50 pm
Thanks tiggs I have that exact same pic, that's the kind of thing I was thinking of.
Posted : 30/08/2015 6:51 pm
If you want to be really fussy about it then I would add a low filled in 'base' section at floor level, maybe about 3" high so that your logs don't sit directly on the floor. The base section gives the whole things a little more of a solid feel and provides a defined area to where the logs sit. it's a small detail but I think it will finish the whole thing off.
As for shelf spacing, the first thing would be being sure they are spaced to be fit for purpose but if you were going to have some narrowly spaced and some wider the narrow spaced ones would generally go at the top. Notice in tiggs121's picture that although the shelves are evenly spaced the big heavy looking stuff is on the lower shelves and stuff get generally smaller/lighter as you work your way up. Stuff looks more solid if the bulk is at the bottom.
Posted : 30/08/2015 7:00 pm
Thanks MW. I was thinking the same about the base, my pic really is a just a rough in,nothing has been screwed in yet, your idea would give it the look of being a built in Bookcase rather than just shelves.
Posted : 30/08/2015 7:21 pm
Made these this week for a customer, equal both sides of the breast. They were 375mm apart, customer laid out positions
[img] https://picasaweb.google.com/110336799564334484644/20150830?authkey=NiFhlS8a3lQ#6187712435419292562 [/img]
Posted : 30/08/2015 9:01 pm
Can't get the pic to post sorry, I'll email it if you want
Posted : 30/08/2015 9:13 pm
The shelves in our alcoves are like Tiggs picture. Big/heavier things tend to go on lower shelves and small/light items on the top.
Get rid of the wood on the wall too. Fix the supports onto the wall, fit the shelves the plaster over the supports. Paint the shelves to match the wall, stain or varnish it just looks much neater. Under shelf lighting can look very nice with slimline fittings but make sure you put the wiring in place before hand.
Posted : 30/08/2015 9:26 pm
Yes Funky Monkey E mail in profile it works
Posted : 30/08/2015 9:29 pm
That will be behind ( sort of ) the plaster you wont see it anyway it's just so they are strong. Hence all the cut away plaster/
Posted : 30/08/2015 9:31 pm
Posted : 30/08/2015 9:33 pm
Ours are supported on 1 inch strips of wood with shelves slightly thicker and they have supported my substantial weight without even a creak. It looks like you have solid brick work so no need to over engineer it.
Posted : 30/08/2015 9:36 pm
Feel free to post them if you can. They're held up with a 15x15 batten run on 3 sides. I routed a 16x16mm slot into the timber and slid them on. Timber is 38x225 rough sawn crap, aka scaffold planks sanded down and dressed off with 80g, nothing more. I would have preferred to plaster them in but customer was happy to have them this way. The backs of the alcove were slightly wider unfortunately. I suggested oil to finish
Posted : 30/08/2015 9:46 pm
FD do you live in my house ? it looks remarkably similar 🙂
Craig I here what you are saying but I was plastering the room anyway and the brief was they had to be strong.
EDIT: Ah not your house FD !!!!
Posted : 30/08/2015 10:04 pm
Any wood that you plaster over make sure it has been properly dried out and ideally sat in your home for a weeks to minimise it expanding and cracking your plaster.
Posted : 30/08/2015 10:29 pm
Lower the bottom shelf and run the skirting along the front so the top of skirting is level with the top of first shelf. Then space from here on up.
Posted : 30/08/2015 11:09 pm
Muppetwrangler +1. A base makes it look more finished.
Posted : 31/08/2015 12:28 am
Look at chests of drawers. The drawer height diminishes upwards. There is a guide ratio for this but I can't find owt.
It looks better diminishing anyways...
Posted : 31/08/2015 5:30 am
A bottom shelf would protect your flooring from the logs
Posted : 31/08/2015 7:44 am
Bottom Shelf? Is that what they're being referred to these days?
Got a similar project to be done at some point in my house except the missus wants the shelves to be random heights. Will probably just use shelf strips to keep it simple...
Posted : 01/09/2015 1:38 am
