IT Guru's...pl...
[Closed] IT Guru's...please recomend a good file searching tool...
5 Users
Looking for a search tool that I can put paths to several server locations in.
Eg: need to find a file, means I have to browse to, & search, up to 5-6 different locations. Is there a tool that I can put all the locations in & have it search each location automatically ?
Cheers.
Posted : 09/03/2010 9:07 am
windows search, just stick a semi-colon between locations?
Posted : 09/03/2010 9:14 am
"Agent Ransack" is worth a look..(you can save criteria including multiple directories)
Posted : 09/03/2010 9:18 am
Do people just like having extra software knocking around that's not needed ? 😉
Posted : 09/03/2010 9:22 am
 IA
I assume you're talking windows?
Posted : 09/03/2010 9:38 am
Posted : 09/03/2010 9:47 am
coffeeking...it wont let me use the locations joined by the ";".
Tells me its not a valid folder... 😐
fubar, Agent Ransacker works a treat. IT dept will probably remove it thought. 🙁
Posted : 09/03/2010 10:07 am
Show me what you're entering in the search location box
To save searches:
Let search complete.
File>save search
This saves the criteria as a shortcut to wherever you like. just double click the icon to open the search box again with the same criteria specified.
Posted : 09/03/2010 10:18 am
I suspect that ck's approach may need you to have mapped the drives to letters first. I'm only guessing though.
Posted : 09/03/2010 10:26 am
Yep, sorry, it does require mapping but that's quick and "permanent" once done.
Posted : 09/03/2010 10:35 am
Eg:-
\\xxxxxxxx6\cad\library; \\xxxxxx1\tech\DWG\Product\Actuators
maybe geoffj is right, & they need to be mapped drives.
Posted : 09/03/2010 10:42 am
Yup, geoff is correct, I'd forgotten windows search wasn't UNC compatible; map them all to drives each (with reconnect at logon) and then just enter the drive letters "c:\;d:\" etc. Then do the file-save search and save it to your desktop or wherever for future rapid searches.
Posted : 09/03/2010 10:44 am
