Interesting way to ...
[Closed] Interesting way to save bricks when building a wall
26 Users
No need for double thickness or supporting columns etc. Apparently it takes less bricks than a straight wall and certainly saves trying for all that perfect alignment. From now on all my walls will be wavy.
Posted : 28/01/2021 6:56 pm
I love those walls, and yes they do take less bricks.  I think setting them out could be a pain though!
Posted : 28/01/2021 7:00 pm
The offset on the top course looks wrong, you'd expect a 50% overlap..
Posted : 28/01/2021 7:04 pm
Ahhhhhh,,, so that what Persimmon Homes brickies are trying to achieve
Posted : 28/01/2021 7:07 pm
Less bricks than a straight wall? YEAH RIGHT!
Go on..... Someone explain that, then! (without using technical terms like "stretcher", "frog" and "course" to try and hide the blatant disregard for the laws of physics.)
I call B.S.
Posted : 28/01/2021 7:12 pm
Where is the like button?
Biophillic design for the win. Again.
Posted : 28/01/2021 7:15 pm
There’s strength in arches
Posted : 28/01/2021 7:16 pm
Go on….. Someone explain that, then!
I call B.S.
You can't build a single depth straight wall as it's unstable, so you'd normally have to build it two courses deep, or have pillars every metre or so.
Because curves are so much stronger than straight lines, you use less material for the same given strength.
Presumably you need more bricks in a straight wall to stop it falling over in the wind.
The curves give it lateral (?) Stability.
Simon the straight one requires double thickness
Posted : 28/01/2021 7:17 pm
I call B.S.
im guessing they mean a straight wall with double thickness? the wavy single is stronger than double straight?
EDIT! wow! started typing and 5 replies in before mine hit the site?😄
mowing the lawn in those curves will be a pain. Not sure I'd get the sit on mower in there.
Posted : 28/01/2021 7:19 pm
 aP
Actually that wavy wall is half a brick thick and traditionally a free standing wall would be either a brick thick or brick and a half thick. Gives you the opportunity of using some really elegant brick bonds as well.
A half brick free standing wall would have to have regular piers at decreasing intervals as the wall height increases. Gets more complicated if you put expansion joints in as well, as you might then use sleeved wall starters and if your engineer is very keen bed joint reinforcement.
I suspect that wavy wall won't meet crowd loading though...
(Edit due to aggressive phone auto correct)
Posted : 28/01/2021 7:24 pm
That's lovely - but, yes, a PITA to mow around!
Posted : 28/01/2021 7:30 pm
I’m less worried about the mowing than the boundary disputes 🙂
Posted : 28/01/2021 7:36 pm
I'm pretty sure the same brickie did my house tbh (I'll never be able to do DIY in a straight building- spent too long adapting to building shelves that fit in 100 degree corners and don't leave a gap against wobbly walls)
Posted : 28/01/2021 7:39 pm
 grum
Reminds me of my favourite Andy Goldsworthy piece.
Posted : 28/01/2021 7:46 pm
I’m pretty sure the same brickie did my house tbh (I’ll never be able to do DIY in a straight building- spent too long adapting to building shelves that fit in 100 degree corners and don’t leave a gap against wobbly walls)
My flat sits on a basement that must have been built during a mortar shortage!
Posted : 28/01/2021 7:48 pm
Go on….. Someone explain that, then! (without using technical terms like “stretcher”, “frog” and “course” to try and hide the blatant disregard for the laws of physics.)
I call B.S.
Posted : 28/01/2021 7:54 pm
Corrugated iron.
Posted : 28/01/2021 8:05 pm
Corrugated iron.
A good point very well made.
Posted : 28/01/2021 8:11 pm
Yep, and car panels esp front wings
You can build in strength by folds amd creases
Posted : 28/01/2021 8:16 pm
Also see Orange bikes
Posted : 28/01/2021 8:20 pm
 aP
Very quickly - straight walls have to be wide so they don't fall over.
Posted : 28/01/2021 8:21 pm
Very marmite look, personally I really don't like them.
Posted : 28/01/2021 8:26 pm
Oh. I see. Makes sense now.
That was me talking out of my arse earlier.
Posted : 28/01/2021 9:11 pm
Cardboard too
Posted : 28/01/2021 9:24 pm
 Esme
Oooh . . . a Crinkle Crankle Wall !
Posted : 28/01/2021 9:27 pm
What this thread needs now is some input from a top Quantity surveyor who may be able to count a few bricks as a day job😉
Posted : 28/01/2021 9:29 pm
*fewer.
Posted : 28/01/2021 9:37 pm
Which Goldsworthy piece is that grum?
Posted : 28/01/2021 9:57 pm
He got a job at Tesco, stacking shelves, I'm reliably informed.
Posted : 28/01/2021 10:00 pm
Counting bricks or tins of beans all the same really hope he gets on ok👍
Posted : 28/01/2021 10:07 pm
