How to Hang a Hammo...
[Closed] How to Hang a Hammock
10 Users
Many moons ago I picked up a great double hammock from Mexico which has sat in the loft unused for several years. We've recently moved and finally have the perfect couple of trees in the garden for a hammock.
The question is how best to attach it to the trees? Ideally I want to:
- not ruin the hammock looped ends (made of cotton I believe
- be able to quickly put up/take down without phaffing with knots
- be able to adjust the height quickly/easily
Had a quick google and want to avoid buying some expensive accessories I've seen on a couple of hammock sites.
Best options seem to be [url= https://www.hammockheaven.co.uk/product/tree-bands-pair-2/ ]Tree Bands[/url] then one of [url= http://www.gooutdoors.co.uk/camp-orbit-wire-bent-gate-p400493 ]these[/url] carabiners on each end of the hammock to attach to the bands.
Any better/easier/cheaper ideas?
Posted : 17/01/2017 11:32 am
I think that combination looks great. The tree bands are a really good idea, as it's very easy to damage the tree using rope. They're a visually retreating colour, as well.
Posted : 17/01/2017 11:38 am
endless slings* and carabiners from a hardware store. Most'll be rated way above what you need - even if you try for a bit of comedy hammock "action" nudge, nudge, wink, wink.
EDIT *this may not actually be what they're called. Basically a nylon webbing loop.
 core
I bought a cotton hammock off eBay last year and hung it between two trees in the garden.
My solution is a bit agricultural but it works - 2 loops of webbing strap wrapped around the trees, then a carabiner to link those to the hammock.
Posted : 17/01/2017 11:40 am
some 50mm width tie down straps?
You can use the ratchet to adjust the length and tension and also they have hooks so you can attach the hammock?
Posted : 17/01/2017 11:43 am
Worth noting that tension on the straps could be multiplied by a factor of around 4 for a hammock, depending on the angle you sling it.
Say 150kg for 2 people x 4 = 600kg straps required for a static load. If you get "dynamic" that will increase.
Posted : 17/01/2017 11:54 am
When I had a hammock in the garden I just ran some rope round the tree trunk (with slack to allow for trunk growth) and a loop to attach the hammock with a carabiner on the ends of the hammock.
Posted : 17/01/2017 12:29 pm
I used a couple of screw in hooks from B&Q, previously used for hanging an indoor swing for the kids from a door frame. Then the hammock itself attached to these with carabineers.
Posted : 17/01/2017 1:24 pm
We had one on holiday, el cheapo thing from Decathlon. I just lashed it up with rope and a slip-knot, worked fine.
Posted : 17/01/2017 2:42 pm
Was the slip knot to get you in the mood for relaxing?
Posted : 17/01/2017 3:29 pm
Well if you did go for Whoopie Slings, you wouldn't regret it. They aren't much dearer than a couple of cheap carabiners and some webbing to be honest.
[url= http://www.aboveandbeyond.co.uk/Products/0705422505996/whoopie-slings?utm_source=froogle&utm_medium=feed&utm_campaign=froogle-campaign&gclid=Cj0KEQiAnvfDBRCXrabLl6-6t-0BEiQAW4SRUMbwySxMBdDXS_JDd-wIJEBoQIcc-AARy7A35AzKAlcaAhRd8P8HAQ ]DD Whoopie Slings[/url]
(you'd still need something to go around the trees. A short amount of webbing with something for a toggle is best).
However, I used just webbing for ages. If weight isn't an issue, then you can knot a load of loops into it, for easy adjustment. Just clip your preferred loop into the carabiner.
Posted : 17/01/2017 4:11 pm
