How much water does...
[Closed] How much water does a washing machine use per wash? Does anyone know?
I know theres probably a thousand variations but our washer gets stuck before the spin cycle. The book says possible problem with the outlet. The hose is all fine so I want to run the machine into a bucket to see if its the drainage etc. BUT, how big a bucket will I need? Normal carwash size, barrel or needs to go into a sink or you'll flood the house out? Cheers.
Posted : 13/10/2014 9:29 pm
over a full wash anything from 40-60 litres.
Posted : 13/10/2014 9:50 pm
50 litres or so for the newer machines, more for older ones.
Posted : 13/10/2014 9:51 pm
Ours about 50l, i know this because i had the same problem and had to sit there and watch it do a full wash into 2x25l bins.
Posted : 13/10/2014 9:53 pm
I am so glad I asked! Never imagined it would be that much. Thanks for saving the house from looking like a scene from 'the perfect storm'!! Cheers.
Posted : 13/10/2014 9:54 pm
Odds on that sock you are missing is stuck in the outlet filter or some other part of the drainage.
Posted : 13/10/2014 10:03 pm
Probably worth checking the filter if you haven't already.
Posted : 13/10/2014 10:05 pm
