The Mrs has lost her specs and needs a replacement pair as soon as possible.
If you have your prescription do the big chains (specsavers etc.) make the lenses in store?
Posted : 13/02/2011 1:37 pm
Ring and check, some Specsavers do them to pick up within the hour, others will send them to a larger branch to pick up later in the week.
Also, you may find they will only use an up-to-date prescription, if its over a year old you might struggle as they will be worried you will return the lenses.
Not sure if they can do lenses to non-specsaver frames either?
Posted : 13/02/2011 1:45 pm
Depends upon your prescription.
Posted : 13/02/2011 1:46 pm
I get mine from vision express, if it is a standard lense they can make them in 1 hr, last lot i had made were done in 40 minutes but it was a quiet thursday morning.
Posted : 13/02/2011 2:15 pm
