How does one recove...
[Closed] How does one recover/reset a router password?
14 Users
Say someone was muppetish enough to forget his router password...
...any easy way to reset/recover it?
EDIT: this would be the one others need to log onto the WiFi bit.
Posted : 31/12/2010 10:13 am
Press the reset button.
Posted : 31/12/2010 10:14 am
As above - with a pin
Posted : 31/12/2010 10:15 am
i simply turn my router over where, helpfully, the manufacturer placed a sticker containing important info like passwords...
BT one we had had a sticker, current Thompson one also has a sticker - I had reason to look at it yesterday for exactly the same reason you describe 😉
Posted : 31/12/2010 10:18 am
No, if I reset with a pin, it still keeps the password needed to log on to the WiFi bit doesn't it?
No, this would be a password I set myself...that I cannae remember.
Posted : 31/12/2010 10:20 am
You need to access the router admin page. For this you wil need to find ip address of your router.
Run IPCONFIG from a windows command prompt on pc, the address of the default gateway will be your router. Enter this IP address into a web browser and you should get to the router admin page, the WEP key will be in there somwhere.
Posted : 31/12/2010 10:23 am
if you press the [b]reset[/b] button it and here's the clue it [b]resets [/b]its self to the default setting.
admin
password
But if you reset it, it will revert to the default factory password, which will be printed on the back or in the instructions.
Posted : 31/12/2010 10:24 am
There'll be a way to restore it to the factory settings using some combination of button presses on it.
RTFM or google it.
if you press the reset button it and here's the clue it resets its self to the default setting.
Then my iPhone wouldn't automatically log on to the wireless network when in the vicinity would it?
Ermmmm....[whispers]....mac
Posted : 31/12/2010 10:25 am
Bruneep & jon
The reset button does not restore to factory settings on some models.
The ip for the router will probably be sommit like 192.168.1.1 or 192.168.0.1. Type that in to a browser address bar and it should prompt you for the userid / password (the one printed on the back, if you;ve reset it)
Posted : 31/12/2010 10:27 am
so what is the router make and model?
Posted : 31/12/2010 10:28 am
It's a Belkin N-wireless Modem Router
Model F5D8633-4
Sorry, I'm not much good at this stuff.
Every year, I forget a bleedin' password on something important.
There are yoofs in the house who may go crazy if they don't get on facebook etc soon on their iPods :-S
Posted : 31/12/2010 10:31 am
DD - good to see someone has a greater sense of security than I....
last thing I can think - you'll know the make and model of your router so may be worth googling the 192 code used to access it for maintenance / setup - that's what the guys at apple tech help had me doing yesterday when they helped me through with borked WI-FI - I now know how to get in and change things such as passwords...
code will be (i think it's 'generic', someone more PC savvy than I will doubtless point out if I'm wrong)
192.168.1.*** - the stars being the 3 digits that are specific to your router make / brand.
If you are on a mac, and (presumably) connected to the router by wire, go to System Preferences - Network and there's a heading 'Router' - that gives you said code.
Hope that helps......
edit - too slooooooooooow - still - you got the idea now!
Posted : 31/12/2010 10:35 am
http://www.belkin.com/support/kb/kb.asp?a=2900
7 seconds
Deadly.
Assuming you can access the WiFi via your mac already then the password should be saved in your keychain.
Go to Finder > Applications > Utilites Folder > Keychain Access
Select System from the right hand pane. Hopefully your router SSID, the name that you gave your router, should be listed in the main window somewhere.
Double click on it.
Check the show password box.
Enter your system password, assuming you remember that 😉
Hit allow if a window pops up asking for keychain access.
Hopefully your password should be displayed.
Posted : 31/12/2010 10:36 am
So you can log onto your router but just not the WiFi? If so you can change the WiFi password once you're logged onto the router (as someone else posted it will be the default gateway IP on your mac). If you don't know either you'll need to reset it but that will lose all it's config so make sure you have your ISP details ready as well...
Cant you put in the cd rom and get it that way?
Posted : 31/12/2010 10:37 am
This is like dealing with my mother-in-law?
 nbt
I would connect via a cable and then go to http://192.168.0.1/ and change the wifi password from there...
Posted : 31/12/2010 10:38 am
nbt wins!
Posted : 31/12/2010 10:39 am
 j_me
If you're on a mac to recover your WEP key do the following:
Use Finder to locate "KeyChain Access"
Launch "KeyChain Access"
Double click the WiFi link you want
Click Show Password
Enter you mac root password
et voila
Of course this is all completely useless if you've already launched in gung ho and reset your router. HTH.
Posted : 31/12/2010 10:40 am
Jamie FTW!
If you ever decide you like men... 😉
bet he hasna got a cable tho.. 😉
I'm now changing it to JamieFTW2010 😀
Posted : 31/12/2010 10:41 am
gung ho
The last time I went in gung ho, I hurt my bits.
deadlydarcy:
Jamie FTW!
An invoice will be with you shortly. 8)
Posted : 31/12/2010 10:44 am
Do what most clueless people do, go and buy another one. 😆
Or swear n curse and ask a 14 year old to fix it, or a hit it with a hammer.
Posted : 31/12/2010 10:49 am
