How do I copy and p...
[Closed] How do I copy and paste on an iPad?
16 Users
I have uploaded a picture into my Picasa album. There is a little box showing some of the URL that I need to copy. I touch it and get the option to copy it. It type a post and try to paste in the link but only get the option to select all.
I did manage to paste one link but that was when there was no other text entered on the posting.
I am clearly not iNtuitive in the way I use the iPad
Posted : 02/11/2012 12:03 pm
I think your problem is more that copy and paste is crap on iOS, especially between apps.
Posted : 02/11/2012 12:06 pm
You can do it,
It's like "copy" but in reverse..
Hold finger in the URL address bar and you should get the text highlight in blue, then the option to paste should indeed come up..
At least it does on mine, I've just done it to check, and yup.. it works.
Posted : 02/11/2012 12:11 pm
I have got the copy working but when I try to paste it don't seem to let me.
I touch the screen first time and the keyboard appears. I touch it again and just get a little blue circle.
I am becoming iRate
Posted : 02/11/2012 2:01 pm
Touch and hold for copy again for paste.
Posted : 02/11/2012 2:03 pm
Touch and hold works for copy.
When I try it on this forum for paste I either get the little blue circle or, it there is some text already typed, I get select/select all
Posted : 02/11/2012 2:19 pm
iWCA.
Ok, so it's a little complex, we understand, took me about 0.00000006 of a second to work it out 😆
If you touch the screen "normally" a big blue box comes up and the options copy/select/select all come up, give the one you want a touch..
ohhhh "touch me".
Then, then wherever you want to paste the item, press on the screen and I get a small magnifying circle show itself, then I get an option to paste..
Now then iWCA, if you are copying an address or URL, do the same thing only do it (ohhh errr) in the URL address bar..
i(cough) assure you this is the only way it works.
The reason you are getting the keypad up is probably you are tapping twice perhaps, maybe you hit the home key and it's gone back to the search menu.. dunno, not there over your shoulder.
HTH, if it doesn't, feel free to use your new iPad as a coaster/frizbie/table leg correction device/1970's dance floor accessory (turn it on frst so you can see all the preeety colours appear as you dance upon it)
Posted : 02/11/2012 2:35 pm
LOL should this guy really have an ipad ?
Google brought me up 1000's of replies.... try that 🙂
Posted : 02/11/2012 2:37 pm
Don't be so iSmug. You're right though, should have gone for an Android device.
Posted : 02/11/2012 2:42 pm
LOL i'm not, i don't have one either. But seriously... wouldn't you search for it instead of asking a forum ?
"How do i turn the kettle on"
"How do i play E minor on a Trombone"
etc etc.
Posted : 02/11/2012 2:46 pm
To be fair, you do get institutionalised after you've been using STW for a while. Going anywhere else on the internet is far too scary, so I tend to ask questions here first, before going anywhere else.
Posted : 02/11/2012 2:49 pm
I'd like to see the answer to this or did you mean Eb?
Regards
Plum
Posted : 02/11/2012 3:17 pm
I don't get the b00dy paste option appearing!
I understand the principle of cut and paste, I just never get anything allowing me to click on the word PASTE.
[sulk]
Posted : 02/11/2012 3:33 pm
This may sound a bit fundamental but I suspect you haven't copied the text in the first place
Posted : 02/11/2012 3:37 pm
The cursor should be blue. Touch the cursor and you'll get the paste option.
Pasted from my iPhone. 😉
Posted : 02/11/2012 3:38 pm
Touch and hold on the text to copy. Select 'select all' and it'll select all. Select 'select' and you get little blue blobs to highlight what you need to highlight. Once highlighted 'cut copy paste' comes up. Select 'copy'
Then do what I said above. You can copy pics too
Posted : 02/11/2012 3:41 pm
Have you tried turning it off and on again?
Posted : 02/11/2012 3:49 pm
iWCA don't sulk theres a bouy, be brave, be strong, be a Man, stand tall, head high, breath in & out and in & out.
Then follow themthere hints above ^^^^^.
I suspect too that you've not copied whatever it is you are trying to copy "properslike"
T'is the only thing I can think of now..
Tell you what...
Copy some text here of the problem and let us lot have a go at sorting it out for you... ohhhh.. hang on....
Do you look like this yet??
Posted : 02/11/2012 3:50 pm
Have a look at this WCA
http://forum.agilebits.com/index.php?/topic/4494-ipad-paste-option/
Posted : 02/11/2012 3:55 pm
There are plenty of online tutorials - apple site and elsewhere - suggest you review some
Copy paste works fine.
Touch once - you get three options, <select, select all, paste> - if you hit <select> you get the little blue section and the two balls (front and end of selection) - you can drag these around to move the selection. You can also hit <select all> option - this is the one I use to get all the BB code to copy image urls/code for STW for example. When you are done hit the <copy> or <cut> (ie the black box)
Now once you have done that go to where you want to paste - touch the place - move around the cursor if you have to - then hit the <paste> option (ie again the black box)
Posted : 02/11/2012 4:58 pm
jambalaya - Member
POSTED 42 MINUTES AGO # REPORT-POST
That is copied and pasted. When I try to do that in the IMG dialog box I don't get the paste option
I am guessing that in Picasa when I highlight the link and select copy, it doesn't really copy the link text. If I select the embed image link it does copy the text
<table style="width:auto;"><tr><td><img src="https://lh6.googleusercontent.com/-3z4hnWkea0c/UJOyhZlZSlI/AAAAAAAADeM/dGrgsQAEGu0/s800/image.jpg" height="800" width="598" /></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From Ankle</td></tr></table>
Which is very interesting but still doesn't help be post up pictures.
Posted : 02/11/2012 5:46 pm
To be fair, if I go into the img box I can't copy and paste either....
Posted : 02/11/2012 5:50 pm
I don't use Picasa so cannot be sure - try pasting into notes and see if it has picked up the text you were expecting ?
I gave up on this same thing last time i tried to post pics from my iphone, now just copy the url and paste it into the text.
However, thinking about it could you kind of do it backwards by pasting the url and then typing the image brackets round it?
[img]paste url in here[/img]
Posted : 02/11/2012 5:56 pm
@WCA it's beer o'clock so off to the pub (posted from the iPad 8) )
[img][url= http://farm9.staticflickr.com/8336/8147304737_7d2eceb73f_z.jp g" target="_blank">http://farm9.staticflickr.com/8336/8147304737_7d2eceb73f_z.jp g"/> [/img][/url] [url= http://www.flickr.com/photos/78861811@N06/8147304737/ ]Surrey Hills[/url] by [url= http://www.flickr.com/people/78861811@N06/ ]JambalayaPhoto[/url], on Flickr[/img]
Posted : 02/11/2012 6:01 pm
You do it [url= http://lmgtfy.com/?q=How+do+I+copy+and+paste+on+an+iPad ]like this...[/url]
Posted : 02/11/2012 6:04 pm
All the smart arses are in tonight aren't they?
So go on then, try and copy and paste from the img tag box in Picassa/Photobucket etc. Betcha can't 🙂
Posted : 02/11/2012 6:20 pm
@boblo - I think we've established its a problem with the picasa/photobucket sites when used with the iPad, flickr works fine as you can see
Posted : 02/11/2012 6:22 pm
Um, I use Photobucket exclusively for posting photos on here, and I don't have problems with it, but there are occasions on other sites or pages, where, for some peculiar reason, the copy function doesn't work properly.
It happens on here sometimes as well; if I've pasted something into this box, then want to copy a quote from a post back up the thread, as long as the keyboard is showing, I can't actually tap on any text to highlight and copy, I have to select another tab then come back, so that the keyboard has disappeared, then I can select the text. I used to be able to do this, but it's possibly something in iOS 6.
Actually, stet that, I've just realised that you can select just by tapping the keyboard key in the bottom right, which closes the 'board. I knew there had to be a quick answer. Anyway, some sites simply won't allow c'n'p, like Facebook, which you just cannot even highlight text on.
Generally, I find iOS c'n'p function to work perfectly well, I particularly like the 'magnifying glass' facility that you get when you tap and hold, so you can see small text more easily to select end points.
Posted : 02/11/2012 7:56 pm
Thanks 🙂
Posted : 03/11/2012 6:37 am
in picasa ive found the best way is to use the links at the bottom right if your taking the photos from the actual website rather than any app
select your size and image only
then copy the url box
the copying of the lightly greyed out box never worked for me either.
Posted : 03/11/2012 6:40 am
This one is cool
[img] https://picasaweb.google.com/viewer#photo/115660383436295169415/5794781330112166785/5802422543144237458 [/img]
Tried that on my phone. I normally use Flickr so I guess it may be a Picasa thing ?
Posted : 03/11/2012 8:29 am
1) Purchase second iPad
2) Photograph whatever you want to copy
3) Email photo to original iPad
You may want to consider buying a 3rd iPad for data storage purposes 😉
That said, they are rather lovely.
Posted : 03/11/2012 2:02 pm
