HOTPOINT WD860 wash...
[Closed] HOTPOINT WD860 washer drier fault code
4 Users
Hi anyone know what fault code F13 means on the above machine?? Wont function at all, is powered up and display is on, you can enter programs but wont start??
Posted : 20/02/2009 7:16 pm
 GJP
No but ou have my sympathy - I spent a good hour late last night clearing up after my aging machine spewed its contents all over my kitchen and then dining room floor ... Arghhhh .....
Posted : 20/02/2009 7:27 pm
I'm not certain but on my Hotpoint dw, i had a fault code which i cant now recall which was the water level safety switch in the base. essentially if the machine floods into the base of the machine there is a float switch which stops the machine from running. pull off the bottom cover and feel inside the the pressed steel frame, if its full of water then drain it with a sponge (soak it up!) it takes a while but does work!,having said that it may not but it is easy to check!.
Posted : 20/02/2009 9:10 pm
try diynot.com, they've got an appliances section and a resident washing machine engineer by the looks of things.
Posted : 20/02/2009 9:21 pm
