Okay this may be the most boring topic on the internet today but what's the most efficient method of heating water for cooking e.g. pasta?
- Boil kettle, less gas/more electric
- Use gas to heat from cold
- Use hot water from tap (GCH), bring to temp on hob
- Other?
Depends on how good each of them are......
I think a decent microwave might edge it. Get it boiling quickly then leave it to stand for 5mins then finish it off with another blast.
I'd never cook with water out of a combi boiler though otherwise I think that would win.
efficient: Gas from cold as you're only heating the water you need and the pan. Too many energy conversions with an electric kettle. GCH hot water means you have to heat a cylinder of water and/or all the pipework. UK hot water is also a bit dodgy for cooking- we found dead things in my mum and dad's hot water (not radiator) header tanks
From a purely energy perspective. the watts required to boil the water will remain constant regardless of the heat type. When cooking over the hob, there will be heat escaping to the atmosphere around the pan base where as a kettle will be 100% efficient - the only undesirable heat transfer which will occur is the body of water, through the kettle wall and to the atmosphere.
As to the cheapest method - your gas is likely to be ~2.5-3p/kWh and your electricity 12-13p/kWh - the hob will likely be cheaper to run.
What if you have an electric induction job?
Ground source heat pump
Kelly kettle. Sticks* are free!
*or waste wood/cardboard etc
I boil the water in the kettle. It's quicker. No idea of comparative cost .
Really high end magnifying glass. Might take a while though.
What I tend to do though is pre boil a couple of cups worth of water in the kettle depending on how much pasta I'm cooking, and finish it off on the hob as normal, throwing in some extra tap water as nesesary.
Dunno how good or bad that is in terms of power efficiency but it's more time efficient..
On a slight tangent, one thing that annoys me, not that it's my problem, but my dad will fill a kettle half full to make a cup of coffee.
Why! It takes longer and uses more leccy!
What Are you planning to buy with all the money you save once you solve this issue ?
Still saving for a manatee shower curtain.
Scruff is correct, kettle is most energy efficient but gas is cheaper per kW/h. FWIW I use kettle to get water to temperature then put it on the hob to get a rolling boil.
Induction hob is still less efficient than a kettle unless you have insulated pots. Assuming the kettle is plastic of course.
Iirc a microwave is about the most efficient way of heating just about anything with a significant water content.
Nope the kettle wins. What ever did we do before Google and bored people with bandwidth?
https://www.treehugger.com/clean-technology/ask-pablo-electric-kettle-stove-or-microwave-oven.html
Oh and completely unrelated as you wouldn't heat water in a toaster unless you're a loon but, well, it seemed like a vague excuse to post this video again.
A kettle is more efficient if you disregard producing and transmitting the electricity.
I split 50:50 and sit on the fence but enjoy the quicker time to get water ready for pasta - half in the pan and half in the kettle 🙂
EDIT - actually it's more like 70:30 kettle:pan as the kettle is so much faster
What do you mean by efficient? Energy efficient or speed?
My Dad used to teach electricians. In teaching lessons about power, he'd calculate the heat required to boil water, and then because the kettle is a resistive load you can calculate the energy delivered by multiplying the time taken by the rating of the kettle. They are about 98% efficient apparently. Because when electrical things are inefficient, where does the energy go? Heat.
Of course generating electricity from gas is only what, 40% efficient, but when you boil a pan of water tons of heat escapes up the sides, so I reckon the kettle still would win even including from source.
Sounded more like kettle for the win. In which case - how can I keep a kettle going long enough to cook my pasta in it?
Nope, still more efficient whatever way you slice it.
Kettle first then pan.
However Mrs Panic insists that pasta cooks faster from cold.
So I have to use a pan on the gas.
Mrs panic is correct, but only if the cooking from cold method I s compared to the cooking from boiling method, just using a pan on the gas to heat the water.
If comparing the Cooking from cold method, to cooking from boiling method (using boiled water from a kettle) then the kettle to pan method is much faster.
But how would a domestic version of a jetboil pan on the small gas burner compare to a kettle? Reckon it must be pretty close?
Electricity has been decarbonised significantly (revised EST conversion factors have elec coming down and gas going up...). If you live in Scotland there’s a fair chance your electricity was generated by hydro or wind.
gas is a fossil fuel. It’s on its way out.
boiling in a kettle will be the most efficient.... (less losses as heat source is located within the kettle and the walls can be insulated (which you can’t do if the heat source is external)).
oh, I’d love to see you try getting boiling water from a GSHP pp! 🤣
Quooker and then onto hob.... instant.
Yeah - gshp will have a COP of around 3.5-5 depending on design and install quality so approx same cost as gas to get water to 40-45 deg C. Try getting it any hotter (55 ish) and your COP will drop significantly so no advantage over a kettle. And you’re only halfway at that point.
Not a huge amount of wind around today, gas is going to be around for a few years yet as a backup. Old king coal is doing well the last few weeks, wholesale gas price is quite high.
https://www.gridwatch.templar.co.uk
Whilst that may be true its still a finite resource which is the point that was being made. And if its not windy most of Scotlands energy will be nuclear.
We don't have an electric kettle cos they're ugly, but boiling water on the (induction) hob on "boost" mode is more or less as quick.
We could switch to methane. Harness the power of cow farts.
Depends very much on which bit of ground you use for your heat source.
Bits of Hawaii, Iceland or Yellowstone Park might yield impressive results
Common misconception, most of the methane produced by a cow comes out as burps. At least that makes the collection method cleaner albeit problematic if you want them to continue generating.
WHAT? Is that a thing?
Much better than that from a modern CCGT plant, although you do then have transmission losses.
A modern condensing boiler will be ~90% efficient, and it won't have any transmission losses, however you will have to heat the water in the pipe between your boiler and your tap, so it depends how much water you're boiling. You could always recover this so it was only thermal losses into the pipe itself by turning the boiler off and running the rest of the hot water out of the tap... Also, it won't boil the water, only bring it to 60°C or so.
Of course if you use a kettle on a sunny, windy day it'll be drawing a significant amount of energy from renewables.
And if you wanted to be efficient you would get a heat pump to heat your water rather than just using electricity for heat.
I’d never cook with water out of a combi boiler though
Why? There's no header tank, it's coming straight off the cold supply then heated, you're then going to boil it in a pan which is going to kill any bacteria (that are no more likely to be lurking in your hot pipes and taps than the cold)
Surely induction best here - Gas hobs throw loads of waste heat into the room. You're not going to cook in the kettle so you lose a load of energy transferring the hot water into the pan to cook. Some kettles are insualted, but not all, so you've got losses to the room through the kettle walls. Yes, you have losses from the pan walls but an induction hob will boil a lot quicker than the kettle so the losses are over a shorter time.
Hot water from the tap to start is often very wasteful depending on how long the pipe from the hot tank is - you potentially waste more hot water than you use as the stuff that sits in the pipe after you turn off loses it's heat the house.
I look forward to your evidence for this assertion.
Mostly. But you can buy biomethane, produced from sewage sludge and food waste. The gas grid also has significant potential for hydrogen distribution.
Its true.
If you are going to use only a pan to heat the water to boiling point. Then the pasta will be ready sooner if you put it in straight away to the cold water. Rather than wait till the water is boiling before putting it in.
Makes total sense really, as the pasta is getting the absorption and starting to cook way before the water is boiling.
Its true.
That's not cooking faster though; just starting earlier
presumably if you just left some pasta in water at room temperature it would eventually 'cook' (ie become soft enough to eat)?
so maybe that's the most efficient way?
Whoa tiger. You're introducing a whole new world of issues there. Up until the point where it starts to boil you've only got your c m delta T to worry about.
If you're encouraging it to rolling boil then the latent heat of evaporation comes into play. And you don't want that. No sirreee.
I look forward to finding it, I know I have it in a book but a quick skim isn't showing it up. Anyway, in the meantime I found this:
https://protonsforbreakfast.wordpress.com/2012/12/16/which-kettle-to-choose-gas-or-electric/
Which confirms electricity is by far the most efficient at source. What that doesn't take into account is that, compared to the USA, we have far more efficient generation with more renewables and higher effiency of thermal generation (CCGT, nuclear etc.) per capita meaning the overall efficiency will be higher so I would expect electricity to be further ahead of gas on his chart.
I do have the material somewhere as I remember it coming up in my Energy Efficiency and Sustainability module I did a few years back. Gas is cheaper but terribly inefficient. Hydrogen can only be added in limited amounts otherwise a) you would need to change all your appliances or at least the burners like when we moved away from coal gas and b) the grid infrastructure isn't gas tight enough for hydrogen, it leaks like a bitch and is a total pain to work with. Pretty sure it can do nasty things to plastic pipework as well. Which is a shame as it would be great if we could just pipe that instead.
Also, whoever said there aren't transmission losses with gas, not sure how you think it keeps it's pressure otherwise.
Isnt it shared on the grid?
A colleague with too much time on his hands measured the energy consumption of microwaves VS their cooking times.
They use more energy running the power supply and clock 24/7 than they used for cooking!
No idea if that still holds true now that appliances on standby have to use <1W, but a clock isn't technically a standby mode, it's on!
I usually fill the kettle with enough water and while that's getting up to temp I stick half an inch of water in the pan and put that on to heat. So when I pour the boiling water in the temperature doesn't drop. A pinch of bicarb, a bit of salt and in go the home-grown runner beans.
Yeah, but we export to the grid to England. Well, that’s what my mum told me when I was a kid so it must be true. 🤣 it wasn’t hydro electric for nothing y’know
On my bikepacking travels I’ve passed more than a few (SSE) hydro schemes (and seen a fair few wind farms).
I look forward to finding it, I know I have it in a book but a quick skim isn’t showing it up. Anyway, in the meantime I found this:
Which kettle to choose: Gas or Electric?
Which confirms electricity is by far the most efficient at source. What that doesn’t take into account is that, compared to the USA, we have far more efficient generation with more renewables and higher effiency of thermal generation (CCGT, nuclear etc.) per capita meaning the overall efficiency will be higher so I would expect electricity to be further ahead of gas on his chart.
Even with half of our electricity supply from nuclear and renewable sources, the UK electricity carbon factor is roughly twice that of gas. With the US, you have significant variations from state to state, with some more than 60% renewables, and others heavily reliant on coal.
In fact there's no definitve answer to this question: the experiment is highly sensitve to many factors, including the size and shape of the boiling vessels, time of day, time of year (waste heat contributing to household heating), and fuel mix for the electricity supply. A far bigger influence is being precise with the quantity of water required.
Whilst it's true that electrons don't care which country they came from, it's not unreasonable to point out that Scotland generates most of its electricity consumption from renewable sources
We'll worded Sir!
The other thing to note is that if you are cooking when the central heating is on then the heat lost from the pan goes into the room meani g the central heating has to work less hard to keep the house warm. This might exactly net out, in theory..
I'm super stoked in anticipation for the what kettle for boiling ??? water threads.
If only I'd pointed that out three posts earlier...
All well and good except you’ve just put on the extractor fan to remove the steam/cooking smells and it’s all gone out the window...
and does nobody eat pasta in the summer?
oh came across latest figures for carbon emissions. Elec was 0.519 in 2012, proposed is 0.233 (gas is 0.210 for ref).
elec still 3-4 x more expensive though.
oh, and Al, yer a pedant.
I'm sure most of us boil a kettle then transfer the water to the less efficient pan
Hang on a minute, shouldn't there be a thing called an electric pan?
Whilst it’s true that electrons don’t care which country they came from
The electrons came from the country where they mined the metal ore to make the cables.
Hang on a minute, shouldn’t there be a thing called an electric pan?
Induction hob innit.
I was trying to find a hole in what you said, I gave up.
i always use hot water from the cylinder that is heated overnight on cheaper economy7 electricity to fill the saucepan.
its a new cylinder and very well insulated so its piping hot even though it was heated 12 hours before.
got to be cheaper than using the kettle with electricity thats over twice the price
Not necessarily. You have to run the cold water out of the pipes first. Then you end up with pipes full of hot water which then gets cold, thereby wasting energy. Our kitchen is two floors below the tank and you have to run out loads of water to get it hot. However if your tank was next door to the kitchen it might still work out. You could figure it out if you wanted. Time how long it takes to fill a litre bottle to get the flow rate, then time how long it takes to run the water hot - you can then find out how much heat you've wasted.
In our house it'd be about 6-7l of water you'd have to run out to get hot water, so if you only needed 0.5l of water for a pan your economy 7 would have to be 12 times cheaper than the kettle.
There is such a thing. Used to be very popular too.
its not wasting energy unless i decide i want a bath not shower and turn the daytime immersion on (i can in theory have a late bath and not turn the day immersion on and let the tank heat back-up overnight) because i have used enough hot water during the day to limit the amount of hot water available for a bath. tank is about 2.5m away from tap. all i'm doing is cooling the 120ltr tank down by adding 1-2 litres of cold which will mean it will cost more to heat overnight as the temp will drop by a fraction but the amount will be tiny.
my yearly energy bill is £480 so i must be doing something right.
How much ENERGY are you saving? We have already covered the bit about gas costing less than electricity.
Also, using tanked water for cooking. Gadz...
Kettle is way quicker and more convenient for boiling water for family pasta, you lot can argue over fractions of pennies while it's boiling.
