Help! Why do my dra...
[Closed] Help! Why do my drains smell?
Both the bathroom and the en suite drain into the same soil stack ( 2 toilet, 2 sinks, 1 bath, 1 shower). The drains are not running slow but they do gurgle a bit and they can smell, especially after heavy rain. After last nights downpour it stunk like the khazis after a 5 day heavy metal festival.
Is it “blowing back” or air locked somehow?
How do I fix it?
Posted : 11/09/2012 11:13 am
Call a plumber! then moan on here how much tradesman cost.
Posted : 11/09/2012 11:14 am
Posted : 11/09/2012 11:17 am
There should be u bends on all the internal drain plumbing to stopsnmells coming back up the pipes along with a vent pipe tot he roof, check its not blocked and fliush a load of soapy water down the drain, also lift any access hatches in your garden and check for flow.
Posted : 11/09/2012 11:18 am
More often than not it seems to be the vent stack (either blocked or non-existent)
Posted : 11/09/2012 11:19 am
Where does it smell?? Actually in the bathroom/ . Also are they at 1st floor level or ground floor?
Posted : 11/09/2012 11:29 am
Smells are upstairs. Drains were running free when I lifted the man hole a couple of months ago. We’ve tipped all sorts of chemical cleaners/unblockers down them over the past few weeks.
Sounds like the vent stack could be blocked hence the gurging u-bends on the sinks, bath and shower.
How on earth does a vent stack get blocked?
Posted : 11/09/2012 11:52 am
Your nemesis has done it to grind you down?
Posted : 11/09/2012 11:56 am
Leaves, dead bird/rat, windblown rubbish....
Had a big curry night at Chez HTS recently? 🙂
I'd agree that its probably your vent stack blocked. Is it an external Stack ? A lot of them have bosses or access plates on them just before they disapear underground. Pop that off and get some drain rods from a Hire shop (speedy, hss etc). Give it a good rodding.
However, beware of contamination. Its not pleasant when one clears quickly.
Posted : 11/09/2012 12:01 pm
Too many vegetarians?
Posted : 11/09/2012 12:10 pm
True, but the veggie diet tends to make things fast 'n' loose thus avoiding blockages in the first place. Time to get some rods and some long rubber gloves. 😕
Posted : 11/09/2012 12:33 pm
If you've got a bidet that you never use in your bathroom the trap has dried out.
Posted : 11/09/2012 1:01 pm
I haven't and it smells in both bathrooms.
Posted : 11/09/2012 1:03 pm
both bathrooms
Ooh, get you Mrs Bucket.
Posted : 11/09/2012 4:16 pm
…and all of our cars have heated wing mirrors.
Posted : 11/09/2012 4:21 pm
